Question about Bosch Water Heaters
Palomar model PTG-74PVN-2
After a short period pf time we no longer have any hot water. You said to try to disconnect the control from the unit itself. I did, now I have no hot water at all. What next?
4 Suggested Answers
gary1121
  • 332 Answers
SOURCE: Paloma PTG 74PVN Tankless Water Heater
did you check the filters on the the water valves, i am not exactly sure about your codes that are shoeing but if you could read it and post them, i know on some of the units 76 means there is low water pressure and the filters are behind 2 caps one on each side above the shut off valve take off the caps and remove the screens, clean them and replace them ,, make sure you turn off the water on both side first or you will get wet
Posted on May 29, 2009
SOURCE: PTG-74PVN
I suggest you call tech support. I had a similar problem, and after walking me through a few tests, they determined it was likely a motherboard problem and are sending a new one. At 2 1/2 years, your unit should still be under warranty...
Posted on Sep 12, 2009
  • 67 Answers
SOURCE: Indoor Paloma water heater showing error message
that is the water inlet temperature sensor fault.. check and clean scale from sensor or have it replace by a qualified technician
Posted on Aug 12, 2010
I have a Paloma PTG-74PVN-1 high volume tankless water heater installed in 2007. Recently, I am having hot water temperature problem, no error code is displayed, but it can not heat the hot water beyoun...
Even though you are not getting an error code, there are may be some diagnostics in the controller that can identify whether it's an electronic (controller/sensor) or a heat exchanger issue. I would contact Rheem tier-2 support.
Jul 01, 2014 | Rheem Paloma Tankless Water Heaters...
I have c7 code
it is a communication problem between remote control and tankless unit
Temporary fix:
1 Turn off electricity to tankless and remove cover. Find two terminals that remote control connects to.
2 Disconnect remote control wiring. Turn electricity back ON.
3 Open hot water tap and see if unit works as expected.
4 Without remote, tankless will heat water to default 120 degrees F and will run without the remote.
Contact Rheem they may send you another pcb board.
Nov 11, 2013 | Rheem Paloma Tankless Water Heaters...
I have a Paloma PTG-74PVN tankless natural gas water heater. It was installed 3 years ago and has worked great until 2 days ago. Currently, the water heater will run for approximately 10 minutes, i.e....
Try turning the thermostat uo a small amount and see if this makes a difference. I suspect the control board is bad but I would try adjusting t-stat before I spent money on board or service call. Thank you
Dec 16, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
My water heater cuts of after 30 seconds and shows C2, 11 code
sounds like your gas lines are too small or not enough pressure... or you may have to clean the rods
Jan 13, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
The control unit needs to be reset when I loose power
have two boilers one a rheem the other raypak, the raypak keeps turing off i have to push the reset button. what could be wrong
Dec 30, 2009 | Rheem Paloma Tankless Water Heaters...
My paloma tankless keeps failing with a code of
SINCE U DIDN'T PROVIDE A MODEL NUMBER, THE BEST I CAN DO IS GIVE U THEIR PHONE NUMBER:
1 800 873 3507
Dec 08, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a paloma ptg-74pvn and the digital temp. display keeps shu
How reliable is your AC? With the digital r/c connected, every time the heater recovers from power outage it's in the OFF default state. If you can not fix the power issue, disconnect the remote control. The w/h will recover in the ON state.
Nov 13, 2009 | Rheem Paloma Tankless Water Heaters...
PTG-74PVN
Sep 01, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Model PTG-74PVP-2 Error Code A0 21. No hot water.
check to make sure the air vent is clean and that the front cover is on properly
Aug 10, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
May 18, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Water Heaters Logo
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
