Question about ASUS Computers & Internet
Asus M51T doesn't power up.
I have Asus M51T and it doesn't power up. Green led on, dvd is working, after a while fan turn on, but thats all, no sounds and screen is black. I check the voltages, seems ok. I supply it from battery and main but nothing was changed.
IB4G2008
  • 3587 Answers
SOURCE: Black screen, blinking led
actually, unless the control board is identical(which it isn't) that would be a bit of a stretch.. Let's see..can you let me know what is the model number of your set?
Posted on Feb 24, 2008
lenny297
  • 133 Answers
SOURCE: Toshiba 1410. Won't turn on
Sounds like a dead battery, You need to try it with an alternative battery, most laptops won't aeven switch of if the battery is damaged, also try ro pull out the motherboard and find for dry joints. i.e. any lose transistor or capacito and try to re-solder it, the put the laptop back together,
Posted on Feb 28, 2008
SOURCE: Vizio P42HDTV Power on Diagnosis
Please check the U29 8 pin little surface mount mosfet it has this letters > FDS4935 > > In this part inputs 13.2 volts which is ok for the near 12 vdc but it > outputs 1.250 vdc i am 100% sure that this is all the problem > > check it out, and tell me if you´re agree with me > > On this output pin it feeds the audio Ic, the 7809 and the tuner side board > which needs de 12vdc too and its getting only the 5vdc part > > what do ya think?? > > Richard
Posted on Apr 13, 2008
SOURCE: Viewsonic N3260W made loud pop and will not turn on.
We got the part in today and the hubby fixed the tv. It is as good as new. We are very happy with our $62 purchase.
Go to http://store.ramplus.com/fsfspopfrpos.html
FSP228-3F01, FSP Open Frame Power Supply Replacement for Viewsonic N3260W - 32" LCD TV
It worked like a charm and took about 10 minutes to put in new part and put tv back together.
Posted on Jan 23, 2009
SOURCE: Advent 7113 doesn't detect mains
It is highly posible that the jack in your laptop where you plug the main dapter is making a false contcat due to a problem in the welding of its connectors to the main board or to corrosion. Check if the rentral plug is not loose or if the plugs seems to be loose when you plug it.
If it is so, you need some expert technician to solve the problem by re weilding it or replacing it.
Posted on Jan 27, 2009
Asus AT3NT A-1 motherboard. after plugging in the power supply green LED comes on ok. switch on computer DVD drive LED flashes on as normal, CPU fan comes on as normal, it all seems ok, but no Video...
May be your RAMs are faulty. Or your VGA is faulty.
Remove RAMs and clean the RAM slot. Re-insert the RAMS. Restart the computer and check.
If it doesn't work, replace RAMs and see.
Sep 11, 2011 | ASUS AT3N7A-I Atom Dual-Core 1.6GHz/...
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
My pc is not turning on, the internal green led switches on at powering the machine. tuerning the power button the first time initiates the processor fan to run but stops instantly. nothing else happens...
Faulty motherboard or power supply. Best guess is a fault in motherboard causing excess current and it then shuts down. Try unplugging all peripherals except for graphics card, including the drives. If still nothing, try a different graphics card, different power supply. If still nothing, try a different m/board.
May 16, 2010 | ASUS P5PE-VM Motherboard
Cant get computer to
Disconnect everything from the motherboard except the power supply, CPU and power switch.
Turn on the computer. You should hear 3 beeps because you removed the memory.
If you don't hear any beeps, check the power supply. Check all the connections. Did you connect the 4 pin power? Did you skimp on it? A common mistake is to get a cheap, high-power supply. Just because the box says it's 1000 WATTs doesn't mean that will carry a steady load.
Still nothing...
It's either a bad motherboard or processor. If you have another processor that is supported on that board and you know it works, try it. If it boots return your CPU for a good one.
Unfortunatly, if it doesn't boot with a known-good processor that just proves the board is bad; it doesn't prove your CPU is good. You may have more issues.
Mar 08, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
On Asus p5b-mx motherboard no beep no lcd no bios only fans and l
Check your Video Card. Perhaps Bad driver or a malfunction
Dec 11, 2008 | ASUS P5B-VM DO Motherboard
Ps3 nodisplay, although I reset output video
minhpham have to tried to insert any disc like moves, song differnt game frm call duty.
and if it dosnt work let me knw.
abdz
Sep 16, 2008 | Sony Playstation 3 (PS3) Console
ASUS M2N-SLI deluxe
for start
lets remove everything non essential to start up the pc.
Try with only one memory.
recheck psu connectors.
Jun 09, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus 945 motherboard is in stand by mode. When I power on , the LED of mother board is glow The cpu fan just jurking and stop. And the LED of motherboard is still now glow.
Hi kausik, that green led you see on the motherboard is just letting you know there is power to the board. (This is normal).
You'r CPU fan jerking & stopping is a bad thing & has nothing to do with standby mode. Your CPU fan needs to be replaced.
There are a bunch of Asus 945 boards, just click the link to see.
http://support.asus.com/download/download.aspx?SLanguage=en-us
If you are able to remove the fan from the heatsink than you may be able to buy a fan from here.
http://www.tigerdirect.com/applications/category/category_tlc.asp?CatId=99&name=Cooling-Products
Most people replace both heat sink & fan.
Have more questions, feel free to ask.
Good Luck!
Mike
Apr 18, 2008 | Intel Motherboard
Asus k8v-mx motherboard
BIOS of your motherboard is crashed. M/B needs to be replaced
Jan 12, 2008 | ASUS K8V-MX Motherboard
Computers & Internet Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
