Question about Lasko 5132 Ceramic Compact Heater
Quick Flipoff
I have had the heater for a few months, and now when I press the power button, it beeps and doesnt come on.
Re: Quick Flipoff
The air intake vents in the rear were clogged with dust. They needed to be brushed and vaccumed.
Posted on Jan 01, 2008
Re: Quick Flipoff
I just took one apart with the same beeping problem. It wouldn't come on at all. I was going to clean the input filters although they didn't look like they really needed it. As I took off the 8 screws and removed the back cover to the unit, the thermocouple popped loose as it was apparently hot glued to the back cover somewhere near the top. I checked the fan and it moved fine, no apparent connection problems and set the unit back upright and plugged it in and it worked. The only thing that changed in removing the cover was that I spinned the motor fan manually to check the bearings and I broke loose the hot glue holding the thermocouple. Either the thermocouple doesn't like being operated in an upright mode (not likely) or the fan unit incorporates an RPM feedback to the controller to shut down the unit should the fan sieze up (more likely). Either way, it's operating again.
Posted on Nov 28, 2008
0 characters
3 Points
I installed a new Honeywell RTH74/75 series thermostat and it has the incorrect day displayed.
Yes it will reset itself when you do that, it really should not be too hard to figure out the day.
Apr 14, 2015 | Honeywell Electronic Programmable...
Remote doesn't work
well depending on brand and make there could be lots of resons for this first remote stuffed get new, or it's batteries are low and need replacing as remote signal will get weaker as batteries die, could have lost signal to rewciever box if has one like some gas heaters have wich they have a learn button on reciever box you push this button you need something thin as it is in a thin little hole to get to these buttons once pushed and reciver made some beeping sounds which sometimes when you let go of button after 5 sec's then press the on or mode button on remote it will beep again meaning signal is recieved or the reciever box has flat batteries in it which need changing then usually sometimes once batteries changed you need to learn in anyway if memroy gone from being flat to long, most remotes have their own manual or are in heater manual so if you have read up first to know what your looking at you shouldn't need a mechanic for this but if you unsure then i would contact one to fix most of the time it would probably be easier to contact mechanic i know this may coast you but whats a couple of hundred to be warm through winter also if it's not a portable heater and you can find a service agent get it serviced and mention control they will take care of ti for you and your heater will be more efficient for you through winter it is important to have heaters service i recomend once a year if you want it to work the same every year as it doesn't take long for them to start loosing efficiency usually only a couple months of running will start to clog up and if thier is a fan on heater its important to have them cleaned regulary for air movement i've seen a fan start to block up after a month it's basically like you vacuum sucking up dirt, dust and lint constantly while its running and is always alot worse if you have indoor furry pets
Nov 19, 2010 | Heaters
My Vulcan system keeps switching off. I have to go into the attic and press the reset button and sometimes the lockout button so it will re-ignite.once the house has heated to its selected temperature it...
i would say this a sencor on the heating side shutting down too quick and not coming back on check you manual at the back there should be fault finding in there
Aug 12, 2010 | Heaters
Heatrunner 33553 doesn't work
I had tried unplugging the unit for a few minutes but that didn't work, so I unplugged it for a few hours and it re-set to a working condition.
Feb 03, 2010 | Heatrunner 33553 Heater
Locked Rinnai Avenger 25TR heater
If its Displaying a Little key Picture, all you have to do to unlcok it is Hold the Up and Down Button until the heater beeps and it will be unlocked.
Jul 28, 2009 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Child lock
Press and hold it for a few more seconds
Sep 11, 2008 | Heaters
Child lock
Press and hold down on the lock button and wait for a beep.
Aug 07, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Rinnai Avenger 25TR Model Gas Heater
I just fixed this problem for my parents. All you have to do is hold the up and down arrows that sorround the power buttom for 3 seconds at the same time and the key symbol should dissapear and make a slight beep. Then you should be able to use the heater as normal =]
May 03, 2008 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Similar model compact heater will not "power up" after storage
they is no reset internal the electronic circuit is deferctive some electronics parts need no be changed. i have fixed one and modify it to be more reliable.
Oct 01, 2006 | Honeywell SureSet HZ-339BW Ceramic Compact...
Lasko 5132 Ceramic Compact Heater Logo
357 people viewed this question
Top Lasko Heaters Experts
Level 1 Expert
Steve Oakes
Are you a Lasko Heater Expert? Answer questions, earn points and help others
