Question about Cycling
Error message 1
Edge 482u bike has an error msg of error 1. Is there a way to clear it? What does it mean?
jhull
  • 10 Answers
SOURCE: What does error #49.4c02 Mean? How do I clear the
49.XXXX PRINTER ERROR
To continue turn off then on
No error message will be in event log.
A critical firmware error has occurred that caused the processor on the formatter to abort operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or homegrown applications. On rare
occasions, the formatter is at fault, which is usually indicated by a 79 Service Error.
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off and then back on.
3. Try printing a job from a different software application. If the job prints, go back to
the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC.
5. Turn the printer off.
6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
7. Remove all EIO devices from the printer.
8. Turn the printer on.
9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each
device.
10. Replace a DIMM or EIO device if you determine that it causes the error.
11. Remember to reconnect all cables that connect the printer to the network or computer.
12. If the error persists, replace the firmware DIMM.
13. Replace the formatter and calibrate the printer. See Calibrate now.
Posted on Mar 19, 2009
Typus
  • 69 Answers
SOURCE: Error message on TI-83. What does it mean?
It means that you have put the wrong things together. E.X. String>Equ(x,y) when x dont equal a Yvar. and y dont equal a string number (StrZ, Z=#'s 0-9)
Posted on May 13, 2009
SOURCE: Error Msg
its a waste toner catredge full indication error.replace the waste toner catredge.
Posted on Jun 18, 2009
ginko
  • 19396 Answers
SOURCE: Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Posted on Jul 05, 2009
bikebird
  • 29 Answers
SOURCE: need edge 482u manual
Here ya go.
www.fitnessquest.com/images/exercisebike_edge482om.pdf
Posted on Jul 07, 2009
Plug in the bike will run fine for a week then comes up e-1.will do it more all the time
Sounds like battery is worn out. It holds a charge for a while then dies. Remove battery, take it to Batteries plus for testing and/or replacement
Nov 12, 2014 | Fitness Quest Edge 482U Upright Exercise...
I HAVE A EDGE482U EXERCISE BIKE I PLUG IN MY CORD BUT NOTHING HAPPENS ,,WHAT DO I DO?
Check the batteries. Make sure the contacts are clean and dry. If that does not help call their custumer service toll free number. Hope this helps.
Jul 09, 2014 | Fitness Quest Edge 482U Upright Exercise...
I keep getting a msg saying carterage error on my printer
If you DID NOT use a HP cartridge you get the error message.
If you did use a HP cartridge. Unplug the printer. Wait 2 minutes.
Plug in the printer. If same error message. Remove cartridge and reinstall. Make sure no clear tape is left on cartridge contact face.
Jul 11, 2012 | HP Officejet 4355 All-In-One InkJet...
Bodyfit exercise bike by Sports Authority manual. Where do I find the manual?
This program http://workoutguru.us/ contains every possible exercise, and muscle building tips (including exercises with your bike). Just follow it, and be persistent. Do not forget to take before/after photo's :). best of luck
Oct 20, 2011 | Fitness Quest Edge 482U Upright Exercise...
I need an owners manual
i have a vitamaster 1000xt exercise bike and need to know how to lower the seat
Feb 26, 2011 | Fitness Quest Edge 482U Upright Exercise...
C7280 error msg 0xc18a0101
You press # * at the same time...... with the navegation arrows you go up to system configuration, with the arrown you navegate until you see error report...then you clear the error report.....then you turn off the printer...unplug everything from it.. unplug ac adapter from the wall wait 1 minute... then plug power back....turn on printer an Voila...is working
Jul 22, 2009 | HP Photosmart C7180 All-In-One InkJet...
The monitor on the EDGE 482U Upright Bike does not work. The only buttons that work are enter and recovery.
I contacted their customer support after putting the bike together two times. There was no indication in the manual that there was a motor inside the base. Customer support offered to replace the motor. I am returning it to the store for a refund.
Dec 28, 2008 | Fitness Quest Edge 482U Upright Exercise...
Cycling Logo
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
