Question about Janome Magnolia 7330 Sewing Machine
Feed dog problem
Brand new machine feed dogs won't raise again
  • Janome Master
  • 7,365 Answers
Take the machine back & get another one or ask them to have the machine fixed.
Posted on Apr 29, 2014
  • 106 Answers
SOURCE: feed dogs
If the machine has a 'darn' facility and this is selected the feed dogs 'will' stay down.
Other than that(without looking) i would guess a good clean and a dose of lubrication would not go amiss.
Try removing the needle plate to see of there is any compacted "fluff/lint" or indeed anything else stopping the dogs rising. Take off the bottom access cover have a good clean out and oil.
Best of luck
Rob
Posted on Mar 28, 2008
bargainbox
  • 1388 Answers
SOURCE: Bernina Activa 131: Feed Dogs won't come back up
Raise feeddogs with switch, then turn handwheel one full revolution to re-engage the gear......unless something is jammed, that should do it. Do you have your manual ?
Posted on Nov 30, 2008
SewTechWayne
  • 186 Answers
SOURCE: Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
Posted on Feb 08, 2009
  • 13 Answers
SOURCE: How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
Posted on Aug 28, 2009
  • 6 Answers
SOURCE: Feed Dogs on Janome 1600P
I recently purchased a Janome 1600P-DB and in order to do free motion quilting I had to cover the feed dogs with an index card. I also cut a small section out of the card to allow for the thread and needle to move freely. Standard tape was used.
Posted on Oct 21, 2009
Singer 4423- brand new. Followed youtube tutorial, lowered feed dogs (buttonhole setting) with no problem; now unable to raise them. Followed suggestions to another user with the same problem- no luck
go google and type in --user manual for singer sewing machine model 4423---and download the pdf version
you could always talk to the singer shop for advice or join a sewing club to get expert tips to get the best out of your machine
Mar 22, 2017 | Singer Sewing Machines
Feed dogs lowered can't raise material not feeding thru
Is your machine mechanical? If so, sounds like the feed dogs are stuck in the lowered position. Needs good cleaning and oiling.
Perhaps this will help:
The feed dog knob won turn don think anything is broken haven used the...
Dec 30, 2015 | Sewing Machines
How do I raise the feed dos
Consult your owner's manual. There is a switch, lever, or knob somewhere on your machine that raises the feed dogs. If they are stuck in the down position and your machine is mechanical, could very well be it has seized due to lack of cleaning and oiling.
This may be helpful:
I can't get my feed dogs to raise. Is there a screw adjustment?
Chances are, your feed dogs raise just fine, but here's the problem. In addition to raising it with the lever, button, or dial, you have to bring the hand wheel TOWARDS you (ALWAYS towards you for ANYTHING) at least one or two revolutions before it will raise and snap into place.
This is true of every machine of every model, by the way, and I have a friend that brought a brand new Brother dirt-cheap from WalMart that was being sold as defective because the feed dogs wouldn't raise. She got it home, flipped the lever, turned the hand wheel two revolutions, and . . . VIOLA! She got a perfectly good brand new machine for practically nothing!
Jul 06, 2014 | Singer 7444 Mechanical Sewing Machine
I have a singer 543 the feed dogs won't move.
I suggest getting out your manual and looking up lower and raising the feed dogs. When the feed dogs are lowered they don't move. You could have lowered them without realising it.
Mar 18, 2013 | Sewing Machines
Singer 4423 feed dogs won't come back up
The slider on the back of the machine that raises or lowers the dogs is incapable of dislodging the thingamajig when it is gently lodged on the shaft.
Oct 17, 2012 | Singer 4423 Sewing Machine
Feed dogs won't move
No info on the sewing machine make or model. It sounds like something is binding up, is bent, or is tangled in the machine. Look around the front and back of the sewing area for a switch to lower the feed dogs.
Good luck
Oct 05, 2012 | Sewing Machines
Feed dogs won't raise and lower on my memory craft 9500, how can I fix this problem?
when your machine on your machine movable arm pushing a switch liver which will raise your feed dogs you can do one thing when your arm moves to the normal possision just given your finger to the upside movable are you see one long switch bar is there just push and see machine feed dogs will come out actualy that action to be done by arm only,you call one MC expart to resoved your problem permenetly.
Apr 21, 2012 | Janome Memory Craft 9500 Computerized...
My feed dods have droped down how can we ajust them to raise them.
Usually when you slide the knob to drop the feed dogs they drop immediately. But when you switch the knob back to raise the feed dogs, they won't come up until you rotate the handwheel one revolution in the forward direction.
Apr 25, 2011 | Janome Memory Craft 9000 Computerized...
Feed dog
don't know how i did it but it is working now. thanks anyway.
Apr 01, 2008 | Singer 7430 Sewing Machine
Janome Magnolia 7330 Sewing Machine Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
