Question about Bosch 23 in. SHU 8805 Built-in Dishwasher
Dishwasher starts filling with water, then doesn't go any further. Timer works tho
Repairman says it is the motor as it will drain the water out but that is all.
djnick989
  • 1067 Answers
SOURCE: Bosch Dishwasher won't fill with water
Certainly *sounds* like the float is stuck in the over filled position
or possible a bad float switch, if the float is stuck in the up or full position, the d/w will not fill with water and the drain motor will often run all the time
Posted on Jan 23, 2008
  • 25 Answers
SOURCE: Dishwasher will not fill with water
Bosch D/w Have a float switchin the base pan of the unit you can access by removing the toe kick, if there is water in this base pan it turns the drain pump on and will not do anything else. So until the water is removed either vacume it out , or let it evaporate or however the unit will only drain
Posted on Jan 25, 2008
  • 1462 Answers
SOURCE: dishwasher stopped working full of water
sounds like sticking in cycle hence not advancing thro to drain.
there can be more than one cause. for a start, check heater and thermal cutout in series with heater. check also that the main pump is ok. after you have run it a while, check if main pump is warm to the touch even if not rotating. if this is the case, then fault can be with the pump capacitor - a cheap part and easily repleced
Posted on Jul 06, 2008
  • 1462 Answers
SOURCE: My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Posted on Nov 26, 2008
fphandyworks
  • 56 Answers
SOURCE: BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
Posted on Jan 05, 2009
Dishwasher will not drain
Hello there and welcome to fixya
Please check the following carefully
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it. Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced. Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Oct 05, 2011 | Neff 24 in. S5409X0 Built-in Dishwasher
Indesit de3542 starts to go but stops after about 30 seconds
That is a discharging problem. What you can try initially is turn it off and unplug the power cable for about 2-3 hours to release any static charges. Then plug it back in. If that doesn't work, there's an internal electronics component that needs to be check. Discharging is a capacitor problem. There might a burned or bulged capacitor that needs to be replaced.
Oct 04, 2008 | Dishwashers
Hello. after washing water still inside of machine. MAYTAG QUIET SERIES 300.
Hello there and thank you for choosing fixya
Drain line/air gap
Pump
Belt
Motor
Timer
Jun 29, 2011 | Maytag Dishwasher
Dishwasher doesn't drain last cycle
Hi
If the water doesn't drain from your dishwasher, check these:
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 05, 2009 | KitchenAid Dishwashers
Wont drain hear clicking noise
Hi
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 03, 2009 | Electrolux Kenmore 24 in. Built-In...
Water wont quit running
HI, if you are getting water with the power to the d/w off, you will need to change the inlet valve. the valve is locate uner the d/w in the front left corner.
You should have a shot off valve under the sink or in the basement (if applies).
Sound like the valve has gone bad and is stuck open.
I hope this helps you. If I can assist you further with part # or anything else, please leet me know.
Thanks
Vic
May 31, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Water doesn't drain. Lines not plugged, solenoid: OK ge dishwasher/ model no. gsd4920z02bb
Hi
If the water doesn't drain from your dishwasher, check these: Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Thanks
Rylee
Apr 26, 2009 | GE Dishwashers
Kenmore 665 dishwasher will not drain
Hi
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 08, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Have new Hotoint dishwasher that wont drain. Drain not clogged !?
Hi
If the water doesn't drain from your dishwasher, check these: Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Drain line/air gap Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again
Please do rate the solution as "FixYa" if found useful and revert for further assitance.
Thanks
Rylee
Apr 05, 2009 | Dishwashers
Dishwasher fills with water... wont wash
usually if the motor is not kicking in then it is a blocked/seized wash motor or a broken wire somewhere from the timer to the motor. either will mean a stripdown. try checking out the motor first.
Jun 13, 2007 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Bosch 23 in. SHU 8805 Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
