Question about Timex Easy Set Alarm T47902 Watch for Men
T47902 where to buy watch band
Cannot find the leather watchband for T47902 anywhere
SOURCE: shorten watchband
I have a similar watch and removing the links are not easy. There are pins in certain links that have arrows on the inside of the band. I used a push pin to remove the pins in the direction of the arrows. Snip the end of the push pin with a wire cutter or pliers so that it fits into the hole and tap the top of the push pin with a small hammer until the other end of the pin is exposed enough to extract it with a set of needle nosed pliers. Repeat for other side of link. When the pin is extracted, twist the link inward and it should snap out.
Remove the link and reverse the procedure, placing the pin in the opposite direction as it was extracted. You may have to tap it gently with the push pin and hammer to get it to go into the holes flush.
It takes a little while and some patience, but if you can get someone to hold the band for you while you tap the pin, it will be easier. Also, if you remove the spring loaded pin from the band fastener so the band can be laid out straight, it will also be easier. Good luck!
Posted on Jun 28, 2008
SOURCE: I need to replace my
First put the pin in the bottom lug of the watch ( the pins is in the band already). Then take a small flat head screwdriver ( found at Radio Shack, or any electronics store). If youn can, take a small file and file out the inside of the flathead so that it looks like a "U". put it over yhe pin and press down as youslide the pin into the lugs hole on top. If you can't cut the srewdreiver out, just take the flat side of it and press down on the pin and push in accordingly. Without "U" shaping the screwdriver, it may take a few tries. Good Luck!! If you still have problems please let me know!!
Posted on Aug 03, 2008
SOURCE: Buy and replace new watch band ?
I just replaced the band on a women's ironman watch, so I know it is tricky, but can be done. First remove the old band using a small flat blade screwdriver and determine that the spring bars that came with the new band are the right size by comparing with the old ones. My new ones were too large. Then, use a pen to make marks on the back of the watch case in alignment with the spring pin holes . Put a spring pin into the band and position the band on the watch the way it will be attached, with the pin just above the marks. Use the small flat blade screwdriver to insert one of the spring bars into its hole and align the other side of the spring bar with its mark on the case. Compress the spring bar and slide it down until it roughly aligns with its hole, then, push the band sideways toward the hole and wiggle the band until the pin seats. Apparently the hole alignment is very tight and, without that last step, the pin simply will not seat. After spending a lot of time with the first strap, locating the spring pin hole by trial and error, I used a magnifying light for the second strap to allow me to see the spring bar hole, making the process a lot faster.
Posted on Apr 26, 2009
SOURCE: purchase watchbands for the timex 1440 sport
My son's watch (WR 50M) broke... so I have a strap, if you'd like it.
He loved this watch and it would cost about the price of a new one to repair, so I'm buying him a new one. He's had the same watch for years... bless, huh?
If you anywhere I can purchase another WR 50M - 1440 Timex, I'd be most grateful.
Posted on May 20, 2010
  • 172 Answers
SOURCE: Trying to change leather watch band. This watch
The easiest way to insert and remove watch band pins is with a band tool. This small tool has a very small, thin fork on one side, usually made of tempered or hardened steel, that you use to spear one end of the watch pin; you can then quickly and easily apply the leverage needed to pull one end out of its mounting hole. Many watch pins have a small collar at each end designed to catch this forked end. These inexpensive tools are sold at most jewelry supply houses or come as part of a "watch maintenance kit" that can be purchased online or at Harbor Freight. However, you can also solve your problem without this tool.
There are two approaches to removing stubborn band pins without the right wrench. First, you can use a sharp knife blade (a screwdriver blade won't work) to try to grab the end of one of the pin to try to pull it out of its mounting hole. Band pins without collars are usually designed to pull a bit more easily from one side than from the other; if you're not having any success on one side of a pin, try the other. In addition, you might want to wear leather gloves--using this procedure, it's almost certain that the knife blade will slip out of control at least once or twice, and there's a serious risk of accidentally cutting yourself unless your hands are protected. Further, you may gouge a notch in your knife blade, damaging its smooth edge. Still, if you need to preserve the band pins, this is a common way to go. Finally, if you put too much pressure on the mounting hole in a plastic watch case, you run the risk of tearing out the hole. In that case, the watch is now useless as a wristwatch, because you can't attach a new band to it.
On the other hand, if your replacement watch band comes with replacement pins, you don't need the watch pins that are currently mounted in your watch. If that's the case, use a pair of nipper pliers to cut the pin in half. You can either push the old band out of the way, or you can even cut it off to get better access to the pins. If you cut the pin approximately in the center, it should be easy to pull each half out. Conversely, if you cut the pin very close to one edge, you may have a bit of a challenge pulling the short end out--but it's still quite do-able.
I always change out the band pins when I change a wristwatch band, so I have become increasingly fond of cutting the old pins in half and pulling them out if I can't easily get them out with a band tool. Doing so minimizes the risk that I will damage the pin mounting holes in the case. Even in a metal case, elongated mounting holes will not hold a pin as securely, making it easier for the band to spring out and the watch to fall and get damaged.
Posted on May 18, 2011
Need the replacement strap for Timex watch M805
Timex Watchband - watchbands.com
www.watchbands.com/Departments/Timex-Watchbands.aspx
Original Timex® Replacement watchbands and straps designed to fit Casio, Seiko ... Currently the Timex bands we have are below. Leather Timex Watch Bands.
Jan 01, 2016 | Timex Watches
Officina Del Tempo OT1028 I purchased this watch in Aruba and am trying to find a replacement watchband, rubber or leather not having much luck online.
Questions, Troubleshooting Help & Support Page 4 - Fixya
www.fixya.com/troubleshoot/page-4
Officina Del Tempo OT1028 I purchased this watch in Aruba and am trying to find areplacement watchband, rubber or leather not having much luck online.
Officina Del Tempo Power Lumicron Chrono Gel 49 mm Watch
www.amazon.com/Officina-Del-Tempo.../B003BQ5E...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Officina Del Tempo Power ... Ipurchased the "Power" model from Barneys in West Hollywood in 2008. ... It took two weeks time and a $150 bill which I believe is high for replacing the band and ... I love the design and feel of the watch so much, I am compelled to get the ...Missing: ot1028 ‎aruba
Officina Del Tempo Mens Watch ' eBay
Dec 26, 2015 | Watches
Do you have a black leather watchstrap in stock 233 LSSN?
No. I do not sell watchbands, and neither does Fixya. However, almost any retailer that sells watches is likely to have watchbands in stock, and may have a close match. A leather shop may be able to make a custom band for you.
Jul 03, 2015 | Skagen Strap Mens Watch 433LSLC
Need replacement leather 26-28mm black leather band for diesel wide band with no stich
Thanks for contacting FixYa.
If its just a standard leather band, you can get those almost anywhere on the internet. My suggestion would be www.watchbands.com
If it is a particular style band for Diesel that you are looking for I can guarantee you can get from them, but you can contact Diesel here:
http://store.dieseltimeframes.com/webapp/wcs/stores/servlet/ContentView?langId=-1&storeId=33053&catalogId=21503&page=contactUs
Best regards, Jewel
Sep 04, 2010 | Diesel Leather Strap DZ4131 Aa Watch for...
Purchase watchbands for the timex 1440 sport
Apr 25, 2010 | Timex 1440 Nylon watch
Changing a Rolex metal watchband to a leather watchband
Put the watch face down and examine the point where the band is connected to the watch case. you will find two holes and through them you will see sprinbar ends insertyed into watch case lugs. Take the tiny screwdriver and push the springbar end inwards,then do the same at the other lug reaching them through those holes.
Then repeat the same at the other end of the band.
Measure the distance between watch case lugs- this will be exact size for your new leather band.
Rate me, plesae.
Mar 23, 2009 | Rolex Daytona 116528 Wrist Watch
Where can I get a new band for my LaCrosse Radio Controlled Watch
Follow this link and choose whatever you want:
http://www.google.com/search?ie=UTF-8&oe=UTF-8&sourceid=navclient&gfns=1&q=watch+bands+online
Rate me, please.
Mar 20, 2009 | Watches
Versace watch
call an authorized retailer in your area and they will be able to order a band for you. Here is a link for the website http://www.vertime.com
Sep 22, 2006 | Versace 27473-008-00 Wrist Watch
Timex Easy Set Alarm T47902 Watch for Men Logo
67 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
