Question about Bush 42" LCD TV 1920x1080, 50 Hz, Freeview HD, HDTV, LED Backlight, 3D
Bush television switches it's self of and on again and not allow you to change channel or volume
Problem occurred after pressing Netflix button and standby button a couple times
    Top Expert:
  • Bush Master
  • 75,311 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Apr 05, 2015
    New Friend:
I think that the tv is trying to return to its last state and can't log itself into Netflix or something along those lines and it's confusing its brain. I pressed the power off button while I had Netflix on and it's just switching itself on and off now. Mines 4 months old so it can't be wear and tear.
Posted on Apr 04, 2015
5 Suggested Answers
sharptech1
  • 29 Answers
SOURCE: tv lost picture and sound
TRY UNPLUGING SET FROM THE WALL FOR 1 MINUTE. PLUG SET BACK IN AND CHECK. IF PROBLEM PERSISTS TAKE IT TO A QUALFIED SERVICER. UNIT PROBABLY HAS A DEFECTIVE MAIN TOTAL ASSY.
Posted on Jan 12, 2009
SOURCE: MY BUSH TELEVISION MODEL IDLCD27TV006 HAS POWER TO
Just had same problem today. Presumably you've seen the more recent solutions on other web sites regarding replacing the C330 capacitor. It appears to be an over-temperature issue. After trying to press all sorts of buttons, removing plug for a time, leaving off for a time, it just started to work again but I don't know how! The tv stands beside a radiator and this may have been on for a while and caused this problem. Will monitor situation before diving into its innards.
Posted on Dec 31, 2009
sonicboomele
  • 1557 Answers
SOURCE: Bush BTU250DTR digital TV recorder. Will not turn
although the lights are working on the remote there is still no proof that its infra red led is not blown in some cases there solder point can come loose the first thing you have to do is conferm the remote is the problem as the ir receiver in the tv could be damaged first try buying a cheap universal remote and see if the tv responds if it does then you will have to have the remote serviced the cost is around @35-45 there is also i site on the net that sells secound hand remotes www.replacementremote.com you could try there but before you waist money conferm it is the remote
merry christmas
Posted on Dec 22, 2010
gopakumarg43
  • 75311 Answers
SOURCE: bush tv combo TV/VIDEO BTV19sil
If there is not a button marked 'Menu' You must have its remote control to adjust anything.
Posted on Oct 25, 2013
Bush tv combo TV/VIDEO BTV19sil
Oct 24, 2013 | Bush Televison & Video
I need a sky remote code for a bush s642f
Hello
Sky remote codes for Bush TV are:
246 263 377 037 064 065 310 300 383 399 391 402 547 292 239 312 609 322 339 515 236 389 035 191 232 245 288 714
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button
OK
Jun 28, 2011 | Televison & Video
Toshiba 42h82
1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Oct 21, 2008 | Televison & Video
Volume and chanel number stays displayed
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Mar 22, 2008 | Philips 32PF5320A 32 in. LCD Television
CHANNEL INDICATOR WON'T CLEAR
This is a setting in the menu set-up somewhere or simply press the display button on the remote control unit.
Jan 21, 2008 | Televison & Video
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
TV controls not working
ARGOS SELL SPARES FOR ALL REMOTE CONTROL DEVICES ON THE ARGOS SPARES SITE. PRICEY BUT WORTH IT!
Oct 07, 2007 | LG 15LW1R 15 in. LCD Television
42LC2DR
You need to press the button on the top right of the control ( the TV button) once and that will allow you to control the tv once again. Problem occurs when you accidently push VCR or DVD button which means remote control will try a different frequency to operate a VCR or DVD that isn't there. Hope this helps.
Aug 18, 2007 | LG 42LC2D 42 in. LCD HDTV
Bush LCD15TV001
press the channel up and down together the menu will come up then you can use the volume up and down to toggle on what you want.if that does not work you will have to call the tech to lift off the eeprom from out of the set and resolder it back,so that the tv could reset it self.good luck.
Apr 12, 2007 | Bush 1433BLU3 14" TV
Bush 42" LCD TV 1920x1080, 50 Hz, Freeview HD, HDTV, LED Backlight, 3D Logo
95 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
