Question about LG Refrigerators
Unplug replug light goes out and fridge seems to stop working until I unplug it and then plug it back in. It then seems to be working but goes out again after about 5-10 minutes
  • 531 Answers
SOURCE: Fridge worked perfect for 3yrs, one day i took
you may have a big problem not sopose have the door open so long better you call service
Posted on Apr 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: Not cooling, unpluged for few hours, it worked fro couple of weeks, stopped cooling again 2 days ago, I unplugged for few hours, It is working now
Your defrost system is bad. Replace the defrost thermostat and defrost heater in the freezer.
Posted on May 26, 2009
SOURCE: my refrigerator and freezer is not working too well. it stopped getting cold and then i transferred the food to the refrigerator in the garage and unplugged the kitchen. about a week later i plugged i
i have a maytag two door fridge it's not working the fan is working but it's not getting cold fridge or freezer can you help me sometimes it tries to cut in makes some kind of sound for a couple of sec and stops again
Posted on Jun 15, 2009
xptareq2000
  • 1447 Answers
SOURCE: fridge doesn't work
check ac fuse or connector
Posted on Sep 10, 2009
SOURCE: Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Posted on Oct 19, 2009
Control panel on front stops working, only freezer lights are lit, freezer and fridge stop cooling.
when half of the display goes out, it is giving you an error code telling you what is wrong with the fridge.Unplugging it simply resets the computer until the error comes back typically within a few hours.
without knowing what is lit up, it is difficult to help you so I would recommend putting the error code "which bars are lit up" in a comment so we can diagnose further
Feb 03, 2018 | LG LFX25960ST Stainless Steel French Door...
My LG front-loading washer WM2501H drum light comes on at the end of the cycle and won't shut off. Additionally the control buttons cease functioning. If I unplug the machine and plug it back in, the...
I am having this same issue. I have to unplug and replug back in every wash. Very annoying. Especially because I am short and can't reach the plug without a step stool.
Sep 12, 2011 | LG WM2501H Front Load Stacked Washer/...
Amana side by side water in the door wpn't shut off. If I open the freezer door it will shut off. I have tried to unplug it and replug but that doesn't help. Model # ARS2667BS.
it sounds like the touch pad button is stuck in so it's like someone is always pushing on it,when the door opens the contact in the door switch stops the power to the board,when you close the door the power goes back to the board.you can check this by disconnecting the ribbon that comes off the touch pad and plugs into the board,unplug the fridge then you can unplug the ribbon,when you plug the fridge back in if the water stops coming out you know the touch pad is bad,if the water still comes out then the board that the touch pad plugs into is bad.you can call your parts store and see if the touch pad comes with the board,i've found this problem on other machines and they sold everything together,but if the parts are sepatate do what i said,unplug the ribbon if the water stops the touch pad is bad,if it doesn't then it's the board that's bad.you can shut off the water at the valve that connects to the fridge if you haven't done that already and then do the tests .good luck.
Apr 25, 2011 | Refrigerators
Not cooling fridge or freezer.
need cooling at the back, unplug for about 15 mins, move it for about 1 foot from the wall then plug back.
Sep 15, 2009 | Refrigerators
Fridge lights are buzzing and flickering
You need to replace the electrical control board. It's an easy fix. About $75 for the part. No electrical work necessary. Just unclipping and re-clipping wires into their ports. You do not need a repairman to do this! (I'm a 33 yr. old female, so please forgive my lack of technical terms in the post) I ordered one from AppliancePartsPros.com. It came in two days.
1. Pull out and UNPLUG the fridge.
2. Take out the screws that hold the bottom back panel on
(The electrical contol panel is located inside a white box attached to the lower left corner. )
3. Remove the screws that hold the box in place
5. Remove the bunch of wires out of the clip on the side of the box and pull the box out. Open it by releasing the clips on either side.
6. Disconnect the three sections of wires that plug into the board
7. Remove old board out of the housing
8. Insert new board,
9. Reverse above steps to complete installation.
Note: What triggers the buzzing sound is the door being opened. If you want to stop the sound and prevent the electrical current from going to the fried board until your new one comes, put a piece of tape tightly over the switch that pops out when the door is opened (located inside the unit near the door hinge).
Apr 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge has problems
sounds like the defrost clock may be going bad and or a door switch. Look for a hole that has whatr looks like a big screw that you can turn.
Oct 21, 2008 | Frigidaire FRS26R4A Side by Side...
Tv screen goes off until you unplug and replug in
That's a video card error. Pulling the plug resets the card, but a firmware or chip problem is reoccurring. It needs a professional service call.
Sep 04, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
