Question about Maxus Mxs11002 Portable Sandblaster 6za34
Changing nozzle
Maxus 125 lb. sandblaster gets clogged no matter what kind of material i use to blast and it makes no difference adjusting the valve
It's usually caused by moisture. It may help to dry your media in an oven, but the real culprit is probably moisture in your air. You need to add an air dryer to your line.
Jun 18, 2012 | Campbell Hausfeld Maxus 125 Lb Pressure...
Need to find manual for Dayton sandblaster model #6Z159 Nozzel #27-415 power-1000wt,vol.110-120,air volume 8-22 c.f.m,capacity 15-40lbs.
I have the manual you are requesting for the Dayton Portable Sandblaster Model 6Z159. Your info for the (Nozzel #27-415) is not listed. There are three choices for the (Nozzle..correct spelling) which are steel [pt# 497055]; ceramic [pt# 497020] and tungsten carbide [pt# 497010].
Sep 16, 2011 | Garden
How to start the cleaner solution to go through the hose???
You have to make sure that you are using the correct nozzle, see this attached link for the nozzle that you should use in order to get the machine to **** chemical or detergent.
Oct 12, 2010 | Honda Maxus Prosumer MX5223 Pressure...
My pressure washer inlet tube does not syphon chemicals. The hose is fine and the strainer is new. Do I have to do anything to the pump body to make it work? It is a 2750psi Honda
you have downstream injection and this means only with low pressure will **** chemical you need a soap nozzle or check your injector make sure is in the right direccion
Aug 24, 2010 | Honda Maxus Prosumer MX5223 Pressure...
No spray
I have a G 2600 VH psi which isn't listed here, I have need to order a part that isn't listed, this part goes into the detergent tank that monitors the difference between types of nozzle is attached to hose, what is it call?
Jul 06, 2010 | Honda Maxus Pressure Washer MX5222
Engine is on but when i press nozzle no water coming out
If you remove the tip, will it work? If so, unloader valve is sticking. Needs to be removed and lubed with lithium grease.
Jul 02, 2010 | Honda Maxus Pressure Washer MX5222
Pump does not seem to be working, motor runs good, no pressure
Typical causes: hose bib not fully on, kink in supply hose and, #1 - clogged nozzle, particularly after several months of not being used.
Apr 26, 2010 | Honda Maxus Prosumer MX5223 Pressure...
No Sand or Air is coming out when trigger is pulled
The sandblaster relies on a clear and unkinked line from the sand tank to '**** up' the sand and drive it out the nozzle with the air flow.
-Do you have air pressure at the nozzle? It may be obvious, but you need good air pressure. Pulling the trigger, you should get air out of the nozzle. If you don't, start with the air compressor.
-The sand needs to be dry and unclogged. Dump all the sand out of the container, and pour it back in through the filter screen.
Jul 29, 2009 | Campbell Hausfeld Maxus 45 Lb Pressure...
Pressure washer won't pull the from the soap dispenser
Nozzle dirty, clean out nozzle with small diameter wire. Soap dispensing only happen at nozzle low pressure setting
Jul 26, 2009 | Honda Maxus Pressure Washer MX5222
Maxus Mxs11002 Portable Sandblaster 6za34 Logo
61 people viewed this question
Top Maxus Tools & Hardware - Others Experts
john h
Are you a Maxus Tool and Hardware - Other Expert? Answer questions, earn points and help others
