Question about Honda Garden
Won't cut off
Engine stays running when handle released
    Master:
  • 969 Answers
Oil all connections.lean replace grounding wire connection.
Posted on Jul 04, 2015
Car won't stay running
If the problem only happens when the engine is cold, a bad electric sensor is likely to blame. If the car stalls even when the engine is warm, the cause is likely a faulty electric fuel pump.
Why is it that my car starts but won't stay running? ' Reference.com
https://www.reference.com/vehicles/car-starts-won-t-stay-running-6449388a9326285d Car won stay running Google Search
Dec 15, 2016 | Cars & Trucks
When I turn the engine off the engine cooling fan stays on and does not shut off
depending on the engine temperature the fan is supposed to remain on after you turn the engine off, until the engine reaches a preset cooler temperature. when it reaches cooler temperature usually within 5 minutes or so it should cut off... if you cut it off and it is running 30 minutes later.. then there is a problem with the fan relay or temperature sending unit.
Sep 28, 2015 | 2009 Dodge Grand Caravan
Engine won't get gas
check the fuel cut off switch in the trunk its on the l/s .look for yellow label
Jan 15, 2013 | 1998 Ford Contour
Hatchback won't lock on saab 9-3
I had the very same problem with my 2002 Saab 9-3 after I manually moved the trunk latch to the locked position "out of curiosity..." Then I noticed there is a handle you can pull to release latch opening it up! Very simple remedy... It is a glow in the dark green plastic handle hanging down when the trunk/hatch is open dead center, just in slightly behind latch... Gently pull handle until you hear and see the latch click into the open position...Let me know how You make out. BTW: Toyota Camry has the same set up,same color as well...lol Good Luck!
Oct 16, 2012 | 2002 Saab 9-3 SE
My chain won't run on my 240 eseries when I try to release it ti cut
The hand guard on the machine should control the chain brake, you should be able to firmly pull the guard fully back to the top hadle to load the brake, if the saw has been run for any time with the brake on there may well now be some melting of the plastic cover, this will mean a new brake complete required, you will have to lever the brake off the saw as best you can, it will be tight because the band will be clamped around the drum, this should only be done as a last resort if pulling the hand guard back does not work
Oct 03, 2012 | Garden
Polan 14.5 rifding mower won't stay running when clutch released
Either a problem with the seat switch, or just make sure the block connecter that gose to the switch is fully pushed into the switch if its even slightly off it will stop the engine.
Jun 17, 2012 | Poulan Garden
Clutch won't release
Start with inspecting the clutch handle for any obstructions or rust.
Lubricate the clutch cable at the handle.
Follow the cable down and look for and pinching or damage.If you can follow the end of the cable to the actuall clutch mecaniism, inspect the area for clearance.
If you can disconnect the cable from the clutch mecanisim and test the clutch handle to see if the cable moves freely.
Manually try to engange an clucth with the engine off.
If it won't move, time to diassemble the clutch.
Apr 07, 2012 | 1996 Suzuki VS 1400 Intruder
24 hp LA165 mower. While mowing the mower stopped moving. Engine runs, blades turning but won't move forward or backward (the side lock has been released and the pin at the back is pushed in) 11...
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Jul 17, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
Hard to start and won't stay running
Put fuel in it,then check the fuel pressure with a gauge. The tank unit maybe giving a false reading.
Apr 18, 2009 | 1993 Buick Riviera
Switch Problem
It sound like the switch is loose if you are able take the handle apart and plug the leads back into the switch. be sure to unplugit ffirst
Jan 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Garden Logo
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
