Question about Dell Computers & Internet
Only see one drive
Two drives in server
    Master:
  • 785 Answers
Not configured or bad
Posted on Aug 18, 2014
I have a server running sql application. I need to create a backup system that replicates the current server to another server so that if my current server crashes; I can start the other one to provide...
This is a complex and diverse question due to the numerous scenarios.
A common setup: Dual servers setup on a fail over cluster. You basically make two servers seem as one with a virtual IP and name. Hardware breakdown is 2 servers with 5 drives each minimum. The first 2 drives the OS at RAID 1 (mirrored). The other 3 drives are the database at RAID 5 (striped). You now have hardware redundancy all the way around. When 1 drives fails, you simply replace the drive. The database is replicated and is fail safe. When a complete server fails or needs maintenance you just roll over the server / database to the other node via cluster administration.
This is just an example, but a very common SQL server setup in busisness enterprise environment.
Feb 05, 2013 | Computers & Internet
Hp smart array 641 not recognizing 146.8 gig drives
update with latest firmware for server & controller card
Sep 15, 2012 | HP Computers & Internet
External wd hdd driver letter not seen in IBM x3200 server, but listing in drives to be removed
go to control panel -- administraive tools -- computer management -- disk management
Find the drive and right click on it. select to change the drive letter
Apr 13, 2012 | IBM System x3200 M2 Server
ASUS RS120-E4/PA2 SATA harddisk drive
IT is Mandatory that ALL The HARD DRIVES Should Match the Specifications Provided according to Server Specs.
Mar 02, 2012 | ASUS RS120-E4/PA2 Server
I have a Gateway Server model 9210 Raid 5 (3 drives) Small Bus. Server 2003 and one drive failed. I purchased the same dive. Do i just shut down the server and replace the bad drive or do i hv to go into...
With a RAID 5 setup, if you replace the drive with the exact model, you only need to shut down the server, replace the drive, power on, and the RAID will remount the new drive to the needed confiuration.
Good Luck.
C2Solutions
Jul 11, 2011 | Gateway Computers & Internet
Problem with the Dell PowerEdge 2650 Server Can't detect Hard drive
First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. The hard drive needs to bereplaces in the laptop and Windows installed and the laptop's device driversand your programs etc to get a functioning laptop again.
Mar 23, 2011 | Dell PowerEdge 2650 Server
Micron Netframe 3620 server running server 2003 with raid drive has steady beeps at start up that never stops and says it can not find drive. Where do I start looking for problem?
on the hard drive carriers themselves there are LEDs that will be amber in color to indicate which drive has an issue. You can also install MegaRAID Storage Manager in Windows to view the status of the drives
Feb 09, 2011 | MPC Computers Netframe 3620 Server
Server XSeries 220
Yes, that is the total amount of hard drive space.
This server was built for speed not for storage.
The xSeries 220 server supports four SCSI hard disk drives. The server does not support IDE hard disk drives. Some models support hot-swap hard disk drives and other models support only non-hot-swap hard disk
drives.
Your server supports four 1-inch (26 mm) slim, 3.5-inch SCSI hard disk drives in the hard disk drive bays. You can install four non-hot-swap hard
disk drives in the models that have the standard non-hot-swap drive cage. You can install three hot-swap hard disk drives and one on-hot-swap hard disk drive in the models that come with the hot-swap drive cage. Both the non-hot-swap and hot-swap drive cages hold a maximum of three hard disk drives.
The calculation at that time was 4 drives with 36.7GB storage.
Even if you find the drives somewhere, they will be very pricy.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 28, 2009 | IBM xSeries 220 (86451SF) Server
Dell poweredge 1800 scsi drive not found
check if the drive is showing in the bios of the server,
shut down the server, take out the power cable, press and hold the power button so as to realease flea power, open the server, and reseat the data cable at both ends and if there is another power cable available in the server swap it with the existing cable plugged into the scsi drive.
and now try to start your server.
Further Queries are welcome
Feb 26, 2009 | Dell PowerEdge 1800 Server
Computers & Internet Logo
35 people viewed this question
Alun Cox
