Question about Lexmark X950de Multifunction Laser Printer, Copy/Fax/Print/Scan
Need to change default on Lexmark x950de in the "copy to" field from 9 1/2 X 11 to 8 1/2 x 11
X950de, Lexmark, copy to
My lexmark x5650 will only copy half of what i need. I adjusted the alignment and it still the same.
It could be the Copy setting on your printer. Try to reset the printer to its default settings. From the printer operator panel, press Setup > Defaults > Set Defaults > Use Factory > press OK. Your printer will then ask you to re-enter some printer settings (language, datel, time, etc.). After entering the required info, try to make a copy a again to verify that the problem is fixed.
I hope this helps.
Nov 02, 2011 | Lexmark X5650 All-in-One InkJet Printer
I have a lexmark x5630 printer. Since last week whenever i try to photocopy a document, it only copies 1/4 page, not the full page.I have tried to change the "Resize" or "Size" but...
If you're using the Lexmark X3650 printer, try to reset the printer to its Default Factory Settings. Please follow the steps below:
  1. On the printer operator panel, press Setup button.
  2. Select Defaults.
  3. Select Set Defaults.
  4. Select Use Factory.
Then try to make a copy again to verify that the problem is fixed.
Aug 22, 2011 | Lexmark X3650 Printer
My lexmark 3650 will only copy part of the document. I had a problem with scanning and a new driver was installed to eliminate the problem. I was changing from XP to Windows 7 and that problem is now...
Try to reset the printer to its Factory Default settings. Press Setup menu > Defaults > Set Defaults > Use Factory. Try to make a copy again.
May 25, 2011 | Lexmark X3650 Printer
Belkin N+ wireless router giong out periodically. Could 2.4 ghtz phone be the problem?
There might be a possibility have you tried manually changing the wireless channelto 9,11,or 1. by default cordless phone has channel 6. It might help if you put the base of the router or the phone away from each other.
Sep 04, 2009 | Computers & Internet
Can the copy setting be defaulted to black and white document?
You can set it to B+W but it will revert to its default setting the next time you print.
Jun 30, 2009 | Lexmark X1150 All-In-One InkJet Printer
Default printer factory settings Lexmark X8350
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Apr 27, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Change default ptr setting for lexmark x8350
4. Press "Select."
7. Press "Select."
Administrator Password Reset to factory default
Hey
have you tried to reset the whole printer to factory defaults
**411 -> 4 -> 1 then the green go button
Regards
Daniel Knudsen
Jan 12, 2008 | Lexmark X4500 MFP Flatbed Scanner
Lexmark X950de Multifunction Laser Printer, Copy/Fax/Print/Scan Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
