Question about Zoom Q2HD Handheld Portable Video Recorder
Www zoom co jp
JUST PURCHASED AND TRYING TO SET UP UNIT, I PUT IN SD CARD, BUT IT SAYS "NO SD CARD" WHEN I TRY TO USE IT WHAT'S UP WITH THAT ?
Www zoom co jp
did you format the card after putting it in the recorder?
press menu
use toggle switch (the scrolling wheel on the right side) to scroll till you find sd card on the menu
push in on toggle switch to select it when you have sd card on the screen
when you do that you'll see 2 choices remain or format
select format then press in on toggle switch
you will be asked if you're sure you want to format the sd card
select yes
the manual said it is important to format your card in the recorder
hope this helps
W
May 07, 2013 | Zoom H2n Digital Handy Recorder With...
My zoom stop recording after one hour with plenty of memery on my 16 gig sd card
Which firmware do you have? It should say on the screen when you turn it on. If it 1.10, or 1.0, you need to update the firmware by going to the Zoom support page:
http://www.zoom.co.jp/english/download/software/h4.php
Directions and firmware download is all there.
If you are already on 2.0 or 2.4, then try reformatting the card with the Zoom. This will delete anything on the card, so backup first!! Good luck.
Feb 17, 2010 | Zoom H4 Handy Recorder
Connect to PC does not work
You need to upgrade the H4  firmware from Zoom website
You will need an external SD card reader.
Good Luck
May 06, 2009 | Zoom H4 Handy Recorder
Zoom h4 not recognized by computer
Mac OS 10.4 and higher require the Zoom H4 to be upgraded.
Go to http://www.zoom.co.jp/english/download/software/h4.php#a and choose the download to version 2.20 that applies to you. The instructions are there, but it is a little tricky. You must download the upgrade to your computer and then transfer it to your Zoom SD card. To do that you need an SD card reader. I used my digital camera. I took the SD card out of the zoom and put it in the digital camera. I Plugged the camera into the computer and when the SD card icon appeared on the desktop I dragged the "System Bin" file from the download to the zoom folder. The rest of their instructions were pretty good. Good Luck.
Feb 03, 2009 | Zoom H4 Handy Recorder
My zoom will not be accepted by my mac
If you are using a Mac running Leopard (Sys 10.5), you need to upgrade the H4  firmware from Zoom website
Good Luck
Jan 09, 2009 | Zoom H4 Handy Recorder
Can't connect the h4 handy recorder to a mac
Good Luck
Nov 18, 2008 | Zoom H4 Handy Recorder
Cannot connect to PC
Do you have an SD slot in your mac? plug the sd card there and see if it works. Erase manually the files (leave the system files) and try again with the H4. Luck
Sep 12, 2008 | Zoom H4 Handy Recorder
Mac OS 10.4.11 does not recognize the Zoom H4 recorder
Connecting / Mac / Tiger / Midi
I have just downloaded and installed the version 2.20 of the software for the H4 from the Zoom site. It solved my problem and the H4-SD card now shows up in the Finder as expected.
Zoom site: http://www.zoom.co.jp/english/download/software/h4.php
Matthieu (MacOS 10.5.5 on a Mac Pro)
Note that I formatted a spare SD card to do this update in order not to lose any existing sound files.
Jun 10, 2008 | Zoom H4 Handy Recorder
Zoom Q2HD Handheld Portable Video Recorder Logo
51 people viewed this question
Top Zoom Audio Players & Recorders Experts
Jaysan Lunt
Level 1 Expert
Paul Bade
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
