Question about McCulloch 13HP 338 Cc Portable Generator # FG6000MK
No electrical out put
No electoral out put from generator
I have a 2005 Scion can The car won't start Put in a new starter and an ignition switch There is electoral current but does not catch when I turn on key What do I check now?
There's an electoral current ... as in the electoral college that put President Trump in office?
In other news, have you checked the battery connections? Are the headlights bright? What about the neutral safety switch? Does it work? You could have a defective starter solenoid, if it's not jammed!
Apr 29, 2017 | Scion Cars & Trucks
What is electoral college
The Electoral College is a process, not a place. The founding fathers established it in the Constitution as a compromise between election of the President by a vote in Congress and election of the President by a popular vote of qualified citizens. ... TheElectoral College consists of 538 electors.
U. S. Electoral College, Official - What is the Electoral College?
https://www.archives.gov/federal-register/electoral-college/about.html What is electoral college Google Search
Dec 21, 2016 | Cars & Trucks
A twist in the Electoral College December 19 Clinton could over take Trump?
If enough electors choose to abandon Trump in favor of Clinton, yes. Electors are not legally bound.
Nov 11, 2016 | Cars & Trucks
What is the name of Ajay Chandrakar's village?
Ajay Chandrakar is a Minister of BJP (Bhartiya Janta Party). He is serving as the Panchayat and Rural Development, Culture, Tourism and Parliamentary Affairs Minister of Chhattisgarh State. Kurud is a town and a nagar panchayat in Dhamtari District in Chhattisgarh. Mr. Ajay Chandrakar`s commitment to the Kurud body electorate have been gigantic, with enormous interest in the improvement of provincial foundation as far as the fundamental civilities and usage of novel innovation in the remotest of his body electorate.
Nov 11, 2016 | Computers & Internet
4 wheel drive electoral module
If you have power to the actuator and it does not operate it is probably bad.
Jan 10, 2015 | Cars & Trucks
Generator will not produce electricity, why
Why wont my husky generator put out electricity
Jun 05, 2014 | Husky Portable generator
DBSI325 will not put out voltage
Most of the problems like this are due to a failure of retention of the magnetic field to allow it to build up. Search Google for methods to "flash" the field. If you have had an accident of shorting or putting excessive load on the unit, rotating diodes of a brushless generator can be blown. Of the methods of flashing fields of the generators, I have had the most success with the method using TWO light bulbs in series between the utility mains and the generator. PLEASE be careful when doing this or handling electrical equipment where high voltage is present.
May 13, 2012 | Porter Cable PorterCable DBSI325 3250 Watt...
The generator kicked the breaker of and was smoking and smelled like electrical
What type of load (electrical) was hooked up to this generation?? If the surge voltage and current was exceeded above the generator maximum for any length of time. There problems, it could be the regulator, insulation burnt off the windings.
I am taking a guess here. Now, 7100 Watts is it typical surge wattage. This mean that the generator will deliver 7100 Watt (voltage times current) this is know as the power factor. The actual operating load would be 6800 Watts and I would even operator the generator at its peak wattage. Something in the neighborhood of 10--15% less the peak wattage. Therefore a good positive theatrical Wattage would be 5800 to 6350 operating wattage. Then this generator would run all day.
Just remember Ohm's Law. Current plays a big factor in loading of a generator while the operation voltage is at 120 AC Volts. Example: electric motor; Now electric motor when starting will pull three time its operation current. Operating current for a 1/2 HP AC motor is 6 amperes but start this electric motor will require 18 amperes. This is one reason why they starting capacitors on smaller electric motors. Larger three phase electric motor can literal stop a generator cold...in its tracks. It put such a large demand on the generator it stops the engine powering the generator. I have seen crankshaft break because the generator could handle the heavy current load.
Remember, any time you are running a small gas powered generator. All ways figure what the load and surge current load will be before hooking up any generator. Normally this is figured in VA (volt/amps). Wish you lock. GB...stewbison
Sep 05, 2011 | Robin Subaru RGX7100 7100 Watt Gas...
McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
29 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
