Question about Midwest Air Technologies Air Tools & Compressors
I have a air tech 135psi 3hp 3gal oil lubricate electric air compressor i need a repair manual for it
The lable states to fill the oil full at each use once started the oil runs out thru the oil cap and looks like suds and yellow in color
hdpanama
  • 65 Answers
SOURCE: owners manual ruined. what type of oil do i fill w before use
you should be able to find the manual online if it's available if not Sears would I'm sure be able to tell you.
Posted on Dec 20, 2008
  • 1383 Answers
SOURCE: AIR LEAK ON CRAFTSMAN AIR COMPRESSOR, 3HP,25 GAL, HORIZ TANK
The needle valve that you see is the unloader which releases air pressure from the discharge line after set pressure is obtained. If air continues to leak after the compressor shuts off, the check valve installed in the tank is leaking air out of the tank. Follow the air discharge line from the compressor to the tank. There you will find a brass valve which is the check valve. Simple test is to remove the smaller airline (1/4") from the brass valve and check for air leaking. If leaking remove brass valve and check for debris under the white seat. If you cannot clean the valve, replace with generic check valve from www.grainger.com. It will cost less than factory part. Just order the valve considering the fitting sizes that you need. For exact replacement,( www.sears.com parts). If you sears model # begins with WL then your compressor is made by campbell hausfeld and parts may be ordered from www.chpower.com. Good Luck with you repair and email if you have more questions.
Posted on Mar 21, 2009
mrhappyface
  • 205 Answers
SOURCE: air compressor fills, but slows down as the pressure builds
sounds like you need a new check valve which should be somewhere between the compressor outlet piping,tubing,etc and the tank which prevents the air in tank to back feed to the compressor which would cause hard starting and could damage the motor easy way to check is when you shut off the compressor with some air in the tank if the check valve is bad it would continue to bleed air out out the unloader valve .the unloader valve on your unit is most likely part of the pressure switch when the unit shuts of it should only bleed down the pressure in the pump so it would make it easy to start when needed hope i didn't confuse you
Posted on Mar 23, 2009
SOURCE: Craftman 3gal/1hp air compressor runs normal, but
Chek for pressure BEFORE REGULATOR,if the problem remains worn rings or valve seats most likely source of trouble.
Posted on Aug 09, 2009
erpaalai
  • 999 Answers
SOURCE: Oil type & owners manual
here is the oil you need. Manual is NLA. Eric http://www.kmart.com/shc/s/ProductDisplay?sid=KAx20061023x272xTier3&aff=Y&vName=Tools&CustomerMemberID=tfc_-_9_1_090811_cbdc17f8236de8319108ad3e858ffcf6&catalogId=10104&sName=Air%20Compressor%20Accessories&AirTools=&cName=AirCompressors&partNumber=9990000031945111P&storeId=10151
Posted on Aug 11, 2009
How much oil in an ec12 hitachi air compressor..... brand new. no oil. no manual.....
DO NOT FILL to the plug threads on this compressor!!! The dipstick has a mark and it is very near the end of the stick. Any more questions please email or repost.
Tim
Sep 22, 2011 | Hitachi EC12 Portable Electric 2hp Air...
I have an Hitachi EC-12 compressor and I need to know how to verify that the oil level is correct. There is a green plastic dip stick but there are no markings on it that I can see indicating where...
Pull the dipstick and notice the notch cut into both sides at bottom (push dipstick all the way in to check oil level). Fill to top of notch. Lowest safe oil level is bottom of notch. This unit does not hold much oil. Always use the compressor on level ground (tilted compressor could cause a lack of lubrication). Good luck
Jan 26, 2011 | Hitachi EC12 Portable Electric 2hp Air...
What type oil does the Hitachi EC 12 use? Ray
SAE 5W50 and if available use full synthetic.
This link will take you to the EC12 owners manual if you would like.
http://www.hitachipowertools.com/product/files/pneumatics/compressors/EC12__OM.pdf
Oct 28, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Compressor fills,drains off a little but won't
sounds like the pressure switch is fused shut, more than likely it needs to be replaced, most single stage pumps should shut off at 125 psi max.
Jan 21, 2010 | Hitachi EC12 Portable Electric 2hp Air...
I have 2hp 25 litre marksman electric compressor how much oil should be in it and how do you know when it is at the right level
either by the sight glass half full or by the dipstick touching the line on the dipstick (fillerplug) get back to me if need more info
Sep 30, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Aug 09, 2009 | Air Tools & Compressors
Aug 02, 2009 | Craftsman Air Tools & Compressors
Air tank leaks along the weld
NO,NOT FOR MINE,REMOVE TANK FILL WITH WATER AND TAKE TO A WELDING SHOP.THATIS THE BEST AND SAFEST WAY
Jul 27, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Need manual for a Kawasaki model 840703 5gal 3hp
I called 1 800 590-3723 and they are e-mailing a manual to me. For my model (3HP twin tank) they said 10W30 or 5W30.
Jun 19, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
27 people viewed this question
Top Midwest Air Technologies Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Midwest Air Technologies Air Tool and Compressor Expert? Answer questions, earn points and help others
