Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Hp6500 won't print my invoices from Quickbooks, Help!
I can't print Invoices from Quickbooks to my new HP Officejet 6500 printer. It prints everything else fine, just not Quickbooks.
  • Anonymous May 11, 2010
    Was it working before from this program? Does the printer have to be set up / selected manually within that program (I'm not familiar with it's settings)?, and if so has it been?
    Guru:
  • 224 Answers
Quickbooks generally give problems with every darn printer on the planet.If you are not using the latest quickbook version then try this. save the document on your desktop and then close the original file.Then open the saved file and select the path to print and click on file point to set print area and then click on set to print area click on ok on the dialog box.Then try to print once again and see if it works.....it should if it doesn't call in to HP at 18004746836 and we will be happy to resolve your issue via a remote access session with your computer
Posted on Jun 16, 2009
To add to the 990c fix. You need to install this new printer as a new virtual printer. When you print to this virtual printer it will print to your HP 6500. Thanks for the great fix!
Posted on Dec 04, 2009
I just got off the phone with hp. Be sure to call them, they have a work around for this. In a nutshell, you are installing a new printer, the Deskjet 990c, and using that printer for use with QuickBooks, while Vista repairs the necessary drivers. Hope it helps!
Posted on Jul 31, 2009
My HP 6500 Printer jammed and now everything it prints has a line running down the side. Each segment is about 1/2 inch long and runs down the whole page.
This type of line is cause by a scratch or smudge on the toner cartridge's image drum. You will need to replace the toner cartridge.
Nov 01, 2017 | HP Officejet 6500 Wireless All-in-One...
We are a small company who just purchased QuickBooks Pro 2011. Have not entered the software as yet. Have a question regarding forms i.e. invoices, cheques,envelopes,etc. - Question: Does the software...
Hi ibeaton1484,
Invoices and other forms are built in the Quickbooks software and you can just simply print it on a plain sheet of paper. You can simply click on the print icon on top to print the invoice that you have created.
However, If you want pre-customized company sheets (invoice, envelopes) for your company you can order it directly from Intuit together with your checks.
Hope this answers your question.
Good Luck!
Mar 14, 2011 | Intuit QuickBooks Pro 2011 (License Only)
Hp officejet 6500 wireless printer won't print quickbooks checks
go to control panel, printers, right click on my printer icon (HP Officejet 6500 E709n), click properties, click advanced tab and check "print directly to printer"
Nov 26, 2010 | HP Officejet 6500 Wireless All-in-One...
Just install new HP Officejet Pro 8500 printer I cannot print invoices in my Quick Books Pro 2009 program. Will print Purchase orders but not invoices
contact the developer or programmer of invoicing system. i believed the problem is in hard code in which your newly installed HP printer not supported with the invoicing system application.
Mar 25, 2010 | Computers & Internet
Quickbooks forms will not print on newly installed HP 6500
I deleted the qbprint.qbp file and that fixed it for me. Aggravating regardless.
Feb 15, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Quickbooks Pro 2007 Printing Blank Invoices
Go 'Lists' and then open 'Templates', double click on the product invoice and make sure the invoice is 'Active'.
Qbooks saves printer settings for each feature, regardless of which is set as 'default' in Windows...be sure you have the correct printer selected.
If the above are set correctly, go to HP's website and download the latest driver for your printer.
Jul 13, 2009 | Intuit QuickBooks Pro 2007 Full Version...
HP6500 won't print Quickbooks
I had the same problem with this printer Office jet6500 Wireless. HP advised me to install a new print driver Deskjet990c and use it as default printer for Quickbooks. you need to ID the port of the HP6500 and use the same port for the 990c (nb i am using it with usb on my PC)
HP tech support emailed me step by tep instructions
Jul 01, 2009 | HP Officejet 6310 All-In-One InkJet...
Printing Quickbooks voucher checks with HP 6500 officejet printer
i have nearly the same problem and I'm going to continue to search and write 6500 voucher printing problem
May 18, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Printing landscape instead of portrait
this article may explain how to change it
http://hints.macworld.com/article.php?story=20070613051850612
Mar 05, 2017 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
2,002 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
