Question about Cricut Expression Cutting Machine
Wifi How do I use the circuit expressions without wifi? It is picking up my wifi and I don't have the adapter
I have a g5690 shuttle and would like to install a wireless card to connect to our home wireless network. What shoeld I buy?
My suggestion would be a mini-pcie laptop card, N300 or higher (you can buy them on Amazon and Ebay for around 25 dollars, Azureware or Intel are usually good) and a low-profile mini-pcie to pcie adapter which comes with antenna. Azurewave AW CE123H 802 11ac nbg WiFi BT PCI Express Module Broadcom... Mini PCI to PCI Wireless Adapter 3 Antenna WiFi
Dec 26, 2014 | Shuttle Computers & Internet
Windows 8 keeps losing WiFi config
You can test it with an external wifi adapter. I use Edimax nano USB WiFi adapter (it cost around $15) and it has its own drivers and applications. Please don't forget to disable your internal wifi adapter after installing the external wifi adapter.
Feb 27, 2014 | Microsoft Computers & Internet
Cant pick up wifi on desk to
go to internet connections and try again
Feb 27, 2014 | Gateway Computers & Internet
I only get a wifi connection when I am next to the wifi hub. I lose the signal when I move 4 meters from the hub. Other laptops pick up the wifi without problem. I have tried using the zenbook on main
It's may be the laptops Antenna? Wire broken, pinched, damage, connection loose. The Antenna is usually behind the monitor, wires run from the wireless adapter through the hinges and attach to the antenna, Maybe a loose connection on the Wireless adapter itself? Sometimes you can access through a bay door on the bottom of the laptop, sometimes you have to disassemble the laptop/keyboard, depends on the Asus Model. Have you connected a Ethernet cable?
Jan 08, 2013 | ASUS Computers & Internet
Can the console recieve live signal without added components
If you don't have an Ethernet cable connected from your XBOX to your router, or an XBOX 360 wireless adapter (purchased seperately) connected by WiFi to your wireless router, then no.
Sep 01, 2011 | Microsoft Xbox 360 4GB Console with Kinect...
Can i use my netgear adapter to pick up xbox live on a new xbox 360 from stealing my neighbors wifi signal
not really, as it can't share that signal with your xbox. It can only join their network. If you had a router, and you set it up to "extend" their network, then you could have your xbox connect to the router which would be on their network.
Of course this is illegal and I advise you don't do it.
Apr 22, 2011 | NetGear USB 2.0-Stick WiFi 108 Mb WG111T...
I have a usb wireless adaptor why cannot connect to the internet
look its an ADAPTER an adapter ADAPTS to the internet BUT for the internet you neeed WIFI.. BY a ROUTER Or by your DSL set up the wifi and your ADAPTER WILL pick up your WIFI once they ADAPT you can connect to the internet.. RATTTE
Jul 22, 2010 | Nintendo Wii Console
Wifi wont pick up internet netgear adapter does
there is a kind of conflict that has to do with the driver. If it worked when you just got your system, them a system restore would get it working.
Apr 07, 2009 | Computers & Internet
Cricut Expression Cutting Machine Logo
Top Cricut Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Cricut Craft and Hobby Expert? Answer questions, earn points and help others
