Question about Maytag MFX2570AEM French Door Refrigerator in Stainless Steel with
Water is always on the bottom of the freezer. It leaks out onto the floor or it freezes
Tired of pulling ice out off the bottom of freezer or cleaning water off the floor
  • 1462 Answers
SOURCE: Defrost Problem
there is a drain in the middle of the defrost water collector and it is probably blocked - usually with ice. dry ot the tray and put very hot water in to melt the ice. you may have to do several times. do this until water flows away freely
Posted on Jul 25, 2007
  • 72 Answers
SOURCE: leaking water onto floor at front of refridgerator
could be a leaky water valve
Posted on Jun 11, 2009
aasc
  • 1606 Answers
SOURCE: Freezer leaks water even after water supply turned off
Remove the food from the lower portion of the freezer and remove the 2 screws which hold the rear freezer panel on . Remove the panel and use a hair dryer to defrost the ice built up over the drain . Once you see the black drain hole , concentrate on defrosting the hole . Once defrosted , the ice water will drain into the hole . I would use a small hose inserted into the drain and blow thru , to remove any debris built up inside the drain . Reinstall the panel and food .
Posted on Aug 09, 2009
SOURCE: freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
kel1guy2002
  • 3740 Answers
SOURCE: maytag fridge water dripping from inside freezer side
This sounds like the evaporator drain may be clogged either in the freexer compartment or at the outlet to the drain pan under the unit. Every defrost cycle the defrost element makes water by melting the ice on the evaporator coils. If the drain is clogged there is no other place for the ice to go. Many times the drain may just have ice buildup in the evaporator drain funnel that can be corrected with a manual defrosting.
To do this manual defrosting all you do is first unplug the unit then remove everything from the freezer compartment. After that place a fan blowing into the freezer section for a little over 2 hours. Please NOTE this will make more of that pesky water mess so be ready to tend to the mess as it presents itself.
After the 2 hour fan session plug the unit back in and reload the freezer compartment with previous content. Monitor for the possibility of the water manifeting itself again.
In addidtion to the above there is a drain pan catch basin in the bottom of the unit near the compressor. They are usually white plastic on Maytag units and not to rugged. Make sure that the drain pan is not loaded with debris. There is about a 1/2 inch diameter opaque plastic line that drains into the catch basin. That is the Evaporator darin tube. Ensure the very end of the tube does not have caked up debris in the very end of the tube. Sometimes this tube cakes up and then the debris dries hard inside the tube near the end. Make sure the tube is free of foreign objects and clean.
After all of the above / cleaning and clearing / manual defrosting it is still making water then most likely the lower panel under the defrosting element / evaporator may have become disconnected allowing defrost cycle water from the melted ice into the freezer compartment vs exit via the drain. To fix the disconnected power metal panel problem the rear freezer panel would have to removed to re-attach / repair the metal panel that guides the water into the evaporator drain.
Thanks for using FixYa.
Kelly
Posted on Mar 27, 2010
Water leaks from freezer compartment onto the floor. Ice forms on bottom of freezer, then melts onto the floor.
In addition to the the other answers, also check to make sure your ice maker is not leaking around the the equipment box. Except for water on the floor, I had the same problem as you did, ice in the bottom of the freezer. It turned out to be the ice maker leaking, which is a common problem with that particular ice maker. I bought one on line and replaced it myself. If that is part of your problem, I can give you instructions on replacing it. It's not too hard.
I had the same problem. The ice maker started leaking water into the ice storage bin. I had to replace the ice maker. I did it myself and it’s easy. I ordered one over the internet. Here’s the link to the Sears parts: http://www.searspartsdirect.com/Kenmore-elite-Refrigerator-Parts/61005508/0046/464/Model-59676603600/0583/0161000.html
You’ll see three adjusting screws on the side of new ice. They preset at the factory so don’t touch them!
Ice maker replacement Instructions for bottom freezers: First, use your refrigerator to store the frozen food because it will only take you about 30 minutes to replace the ice maker. Unplug the power. Lift the ice maker wire switch to shut it off. One step no one tells you about but makes the job much easier is to remove the freezer sliding door. Remove the wire mesh storage tray in the freezer. Then with the drawer door pulled out, lift it up slightly with the handle, which releases it, and slide it out of the rails. Now you got it made! Carefully pull the front plastic cover off the ice maker. When you pull on it, you will see it separate from the rest of the machine. It simply snaps off and on the maker. You may need it for you new machine. Mine did not come with one. Unplug the wiring harness from the top back of the freezer. There are two hex head screws that hold the ice make to the side of the freezer. Unscrew them and the ice maker is free to remove. If your new maker did not come with the wire switch, simple pull the old one out of each side the switch mechnisiam and slide it into the new one. Now reverse the above steps to install your new maker. It may take an hour or so for it to start operating, just be patient. You may want to just sleep on it?
54caad00-6581-49f5-8bb8-acf097b357f4.jpeg25765545-mx1s20bq4dmbxnn5pkl1cloe-5-2.jpeg25765545-mx1s20bq4dmbxnn5pkl1cloe-5-3.jpeg
Jun 29, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool refrigerator--water freezing in floor of bottom freezer then leaking onto floor
whirlpool bottom freezers with ice forming on the freezer floor is nothing new. It is formed most likely by an ongoing issue with the design of the defrost drain becoming clogged and there is a revised kit for it part# W10619951.
Whirlpool has extended the warranty of this issue only to two years from the date of purchase and will usually give you the part but charge for install.
It can be put in in less then 10minutes using just a 1/4" hex bit and a small flat blade screwdriver to release the clip on the old "slide" style drain.
Once installed,it is best to defrost the fridge for at least 24 hours (doors open and unplugged) to make sure all ice is melted from inside the unit.
If your drawer was not closing,you would have frost.. If your defrost timer (which virtually no newer units have since digital controls are the norm with adaptive defrost) then you would have frost,not ice.
The fact that you have water is telling me it is defrosting and re freezing.
List a model# for further support if needed please
Feb 08, 2018 | Whirlpool Refrigerators
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Model52552100 side by side kenmore. What cause ice build up on bottom of freezer?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 10, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
My freezer has water that leaks into the bottom and freezes but water also leaks out onto the floor
Inside the freezer at the bottom in the back there's a drain hole that must be clogged and the water from every defrost cycle freezes up and make it worse , so first pour hot water into the drain to melt the ice and keep pouring until it goes through .Keep the drain clean doing this every 3 or 4 months.
Aug 10, 2009 | GE Refrigerators
Freezer malfunction
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Maytag MFX2570AEM French Door Refrigerator in Stainless Steel with Logo
23 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
