Question about Samsung E1080 Black OPTUS Cell Phone
Insert sim on e1080i
Tried sim cards in the phone keeps saying insert sim?!?! please help
jtdusmc
  • 16 Answers
SOURCE: sim card on Samsung sync
You have most likely already checked this, but just in case.....make sure the sim card is full inserted, and inserted in the correct position. (There should be a diagram showing which way to insert the card.
Hope this helps.
JD
Posted on Nov 01, 2008
gaggid
  • 80 Answers
SOURCE: Already have numbers saved to
How Do I Copy Contacts From My SGH-d807 Phone To The SIM Card?
To copy an address book contact to the SIM card follow the steps below:
While in standby mode, press the left soft key for Menu
Select Address Book (8)
Select Contact List (1)
Select the desired contact entry, stored in your phone's memory, using the navigation keys
Press the left soft key for Options
Select View (1)
Select one of the contact phone numbers, using the navigation keys
Select Copy (3)
Select SIM (2)
Press the left soft key to Save the single contact phone number to the SIM card
Note: Each phone number for a contact must be individually saved to the SIM card
PS-Not sure about updating/replacing entries though, which is what you may have been asking about
Posted on Dec 28, 2008
SOURCE: my samsung says insert sim card...
u should have to check your sim card nd insert a sim car in right way
Posted on Mar 03, 2009
  • 16 Answers
SOURCE: my phone says insert sim card
Remove the card, and dip a q-tip in some rubbing alchol, use the q-tip to clean the gold contacts on the back of the sim card and let dry for a minute. Reinsert the card and power up the phone.
Posted on Jul 31, 2009
jocoolguy
  • 1912 Answers
SOURCE: after inserting my sim it
You can get the Unlock code from service provider and Unlock it.....
Posted on Jan 26, 2011
My nokia phone keeps saying its off line
have you tried using different Sim cards? check if the network status is made offline,if yes change it.if you have a Sim card inserted and when you change the profile to general it shows that 'please insert a Sim card' ,think that your sim needs to be changed.try using another Sim card and post the result here.
Apr 03, 2012 | Nokia 5230 Cell Phone
Hello i live in Ghana and my mum sent my samsung gt-e1080i and it says networks lock when i insert sim card can you help me please unlock it. imei: 35683204243457/7
You can get the unlocking codes from the online unlocking sites. i will suggest the website OnlineGSMUnlock.com which is doing good service .....you can approach this website
Aug 02, 2011 | Cell Phones
Phone Keep saying " Sim
Hi! The phone might have been black listed (blocked) or you might not be inserting the sim card correctly.
To find out if your phone has been blacklisted then you could ring up your network provider and give them your phone serial number and they should be able to tell you straight away.
There could be a problem with the connection port of the sim card.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply
Mar 01, 2011 | Nokia E63 Cell Phone
Samsung Geino, my sim is inserted but my phones keeps saying insert sim i carnt phone anyone blah blah help
Hi,when a phone keeps saying insert Sim card, is either the Sim card has problem or the Sim tray of the phone is bad and will need tobe replaced.
To confirm, Take the Sim card and insert it into another phone, If it still says insert Sim, that means the Sim card is bad, But if the Sim card works with another phone, That means the Sim tray of the phone is damaged.
Sim tray is located on the phone where you insert your Sim card in on the phone to make sure the Sim works with the phone.
Have a nice day.
Sep 12, 2010 | Cell Phones
Keep saying insert SIM card
You are trying to use a SIM from another Network or Handset but your phone is LOCKED to your old network and/or to a specific SIM card and number: this is why it is asking you for the unlock code to remove the restriction. It you are no longer under contract or obligations (such as minimum total recharge amounts for apre-paid handsets), then you could try to request the unlock code from the original service provider of your handset.
As for asking to insert SIM card, make sure that the SIM is correctly and securely inserted in your handset SIM holder. Also check that the SIM is still functional by inserting it in another handset: SIM card can be permanently and physically disabled if you attempt to enter too many consecutive invalid codes (usually around 10).
Hope it helps and good luck!
Jan 25, 2010 | Nokia 7260 Cellular Phone
Cant use it
im not sure about this one as i would have to see the phone but i believe that one of the pin receptors to your sim card is damaged or the slot or latch you put your sim card in has come loose some if it is loose try some tape if not then take it to a cellular repair store and get an estimate on how much it will cost to fix it
Aug 19, 2009 | LG Vu CU920 Cellular Phone
I changed sim card, now they both display ''Insert SIM''
try taking out both cards and popping the battery on the phone.
Wait a few minutes and then turn the phone on with no card in it.
Turn it back off when it says no card found and insert the newer card and power it back up.
It seemed to keep a memory of the blank card.
Jul 23, 2009 | Samsung Cell Phones
Says insert smart chip
smart chip means the SIM card.
try cleaning the metallic part of the SIM card with a cloth and the metal connectors on the phone with cotton bud etc.
Put it back and try again.
If not working grab another SIM card (working - friend's etc) to test.
If still not working, send to service centre.
If working for other SIM card then replace your own SIM card.
May 29, 2009 | LG Vu CU920 Cellular Phone
Inactive sim
I know this is a silly question but are you putting the sim in correctly?
Dec 09, 2007 | Sony Ericsson W850i Cellular Phone
Samsung E1080 Black OPTUS Cell Phone Logo
26 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
