Question about Vizio VA26L 26 in. LCD HDTV
VERTICAL LINES When it first comes on, there are colored lines over the screen. leave it on and it will come on to the picture and work fine if you don't shut it off.
freetek
  • 5568 Answers
SOURCE: left half of screen is filled with vertical
If I am right, this is an expensive problem.
The minute pixels that make up the display are turned off and on by circuits arranged in an X-Y matrix. To avoid using one circuit to control each pixel, the circuits are rapidly scanned at a rate higher than the eye can detect.
One or more of the circuits that do the scanning have failed on your set and the ugly part is, the display panels often have these mounted on the display itself forming a 'package' that speeds assembly and are made only by a few companies. If yours is one of these, the entire panel would have to be replaced since the integrated circuits used are very small and have pin spacings that pretty much preclude replacement by hand since they were originally placed by robots.
I hope for your sake the display panel and its control circuits are separate and the panel is still fine since the cost of an integrated replacement may prove to be about 1/2 to 3/4 of the cost of a new set.
Posted on Dec 12, 2009
moorah1
  • 181 Answers
SOURCE: Two vertical red lines.
need to replace main board. it can't be repaired. check vizio parts web site for availability
Usually, they good with parts supply
Take care,
Alex's TV Service,
Philadelphia,PA.
215-806-5980..
Posted on Jan 22, 2010
brownline45
  • 310 Answers
SOURCE: screen turned black except vertical color lines in the center
good day your vertical ic is defective needs to replace look for qualified technician to fix your tv
Posted on Jun 20, 2010
  • 26 Answers
SOURCE: Vertical Gray lines and bars mixed with other
This is the pass thru option on your box. Go into the settings and look for pass through. It will take htose away/
Posted on Nov 20, 2010
  • 142 Answers
SOURCE: i have color vertical lines instead of a picture
color vertical lines means the lcd PANEL is gone bad. it is a costly part which can cost more then 70% of the total cost. you need to replace it.
Posted on Sep 26, 2011
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Vertical colored lines on top and bottom of screen
Definately a video processing problem and it may need a logic board it is called. Does the set work fine if you feed component into set to bypass all that? Let me know. GURU JAY
Sep 11, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Vizio VA26L 26 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
