Question about Sharp AL-1642CS Copier
Sharp AL-1642CS making loud noise
Also copies blank pages
  • 29 Answers
SOURCE: My Sharp AL-1642CS is a
try to check the safety lock under the scanner unit.if the lock is in the lock position unlock it.
Posted on Mar 25, 2008
  • 29 Answers
SOURCE: AL-1642CS
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of the glass specialy the right side.ok
Posted on Apr 21, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Sharp AL-1642CS making blank copies
You have a door on the right side of the machine. in that door is a thin piece of wire mounted inside a bracket. The bracket is white and is at an angle in the door. Do you see that now?
Posted on Jul 18, 2008
checkitright
  • 1362 Answers
SOURCE: Sharp AL-1642CS Copier, the scanner is jammed
Not familiar with that model but what I would try is to turn off the copier remove the glass and try moving it by hand, then turn it on and see what happens it may have a bad motor
Posted on Oct 30, 2008
Sharp Tech
  • 63 Answers
SOURCE: drivers Sharp al 1642cs para vista 64bits
Ir a la ficha www.sharpusa.com de atención al cliente a continuación, descarga de productos. Categoría de producto elegir impresoras y multifuncionales. para el modelo seleccionado modelo no figuran a continuación, el tipo de modelo en AL1642CS. Para el tipo de descarga a continuación, elegir controlador presión de búsqueda en la parte inferior.
translated by goole
Posted on Oct 15, 2009
I have a sharp AL 1642cs and every time I make copies from the top of the printer my copy comes out with line/strips. What can I do not to get those lines anymore.
The machine that you have is digital the scanglass has somethind on it clean it with windex or alchohol that should take care of it
Jan 27, 2011 | Sharp AL-1642CS Copier
Pls my Machine Sharp AL-1642cs is showing code: H 4 pls i can't access it so help me out
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 20, 2010 | Sharp AL-1642CS Copier
Sharp AL-1642CS fuser problem
I have a lot of spare parts this machine.I live in Bangladesh.How can it possible to send you full fuser unite.if your necessary please send me details.your mailing address.I am expert this copier.it is problem heater gear.it replaceble.If I live in Your country it is no matter for me only 10 minutes.But I am bad luck I live in Bangladesh.It is so far.
Jan 31, 2010 | Sharp AL-1642CS Copier
I have a Sharp AL- 1642CS - broken transfer wire
so does that mean that you were getting blank copies and the transfer wire is broken?
Jun 25, 2009 | Sharp AL-1642CS Copier
Prints blank sheets of paper, code is L 1, can't find manuel
Blank pages means the Drum becomes bad, Change the Drum.
Jun 17, 2009 | Sharp AL-1642CS Copier
Sharp copier makes grinding noise
Contact your dealer for service. You may need to have mechanical parts replaced.
May 05, 2009 | Sharp AL-1642CS Copier
Oct 29, 2008 | Sharp AL-1642CS Copier
AL-1642CS
Apr 16, 2008 | Sharp AL-1642CS Copier
Grinding noise
my suggestion is replace the fusing gear and the rachet gear.
Mar 22, 2008 | Sharp AL-1642CS Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
