Question about Invacare Invacre Battery Charger Bat-gc0811 Merits Pride Quickie Univ Xlr 8 Amps 24 Volts
I have model bat-gc0811 charger do it have a fuse
Won't charger
When i turn on my chair it reads controller and does nothing but flash controller
If this is when the charger is plugged into the chair, the chair goes into inhibited mode so you cant drive away towing the charger with you. A safety feature.
Jun 06, 2015 | Invacare Invacre Battery Charger...
How do i know if my battery is getting charged the lights on my invacare charger arent coming on
hi, if the lights aren't coming on, that's a no, check the the mains lead as these are standard to those used on computers and other items found in the home.
Regards
Robin.
Apr 06, 2013 | Invacare Invacre Battery Charger...
EB1214S battery won't charge
On your there are pins make sure they are making tight contact it could be that your charger is not charging the batteries to it's full extent
Nov 04, 2012 | Hitachi Gst Hitachi WH12DAF2 - 12V Impact...
Bat contact of charger
china phone C5 bat contact of charger?
Feb 16, 2012 | Cell Phones
My lighter won't work and this means my cell phone
If the lighter won't work, your cell phone charger might not either. It is possibly the fuse or it has burned or shorted out. The fuse panel is under the dash on either side of the car. Look at the diagram on the cover and replace the fuse with exact number.
Nov 18, 2011 | 1992 Jeep Wrangler
Batteries were dead. put 2 new 12 volt batteries and hooked them up the way the old ones come out + to+ and - to - I turn the switch on and have no lights, no horn , motor won't run. fuses are...
Bob make sure that the wiring is connected correctly to scooter controller in other words if the cables from the batteries have a connector that plug into the harness coming from the controller make sure that connectors (if color coded) match up and that they are seated correctly. Look on the underside of your rear shroud for a wiring diagram and make sure that the new batteries are wired in that way Hope this helps
Jun 21, 2011 | Health & Beauty
Phone doesnt charge....
Hello ! pls use the right charger for it using a different charger can damage the charging IC of the phone .
The charger for LG could look the same but designed different also the bat can be damaged thats means it won't charge
Get a new Bat then try what have told u
good day .
Aug 31, 2009 | LG Secret ? KF750 Cellular Phone
Laptop problems
Yes fuse/diod, but you'll have to take board out.
To take cd out you'll need to stick pin in the small hole on cd drive's bezel.
Mar 22, 2009 | Computers & Internet
Invacare Invacre Battery Charger Bat-gc0811 Merits Pride Quickie Univ Xlr 8 Amps 24 Volts Logo
57 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
