Question about Akai Televison & Video
No disc even though one is in the player
Keeps saying no disc with one in it
  • 3 Answers
SOURCE: TROUBLE WITH KLH DVD-8350 PLAYER
I took the cover off. Moved the lense to the outer edge with my finger. Then rubbed the lense with a q-tip soaked in eye drop fluid (rubbing alcohol would work better). Then wiped it with the dry end. Works greats now!
Posted on Jan 04, 2009
  • 55 Answers
SOURCE: "no disc" error message
Did this problem just start? It may be due to the lens no longer reading the disc. Try a lens cleaner. If your lens went south, it usually is paired with a clicking noise or/and the combination of a no disc/disc error message. I would also recommend staying away from Polaroid dvd players and tv's in the future. They have a habit of not making parts available, especially after the warranty.
Posted on May 09, 2009
  • 814 Answers
SOURCE: RCA DRC 8052NB will not read discs
This sound like a problem with the laser read circuits and it may be solved with a simple cleaning and using compressed air to clear the unit of debris .To do this you must take off the top cover of your unit by taking out the screws and lifting the top off. To clean the laser head you should use cotton swabs and isopropyl alcohol. put a small amount on the cotton swab and rub the swab gently back and forth over the head, until it seems bright and shiny.Check the transport carriage for dust and debris and also the gears. all these must be clean for proper operation. You may want to put a little lithium grease on the gears and guide rails for smooth operation. All this should be done in minute amounts so you do not over do it and cause more problems. If all this fails to allow you to use you disc player, Then you probably have a worn out laser sensor and will have to have it replaced. If under warranty send it in and if not try to find the part number and order it and either take in to a service center for repairs or do it yourself. Hope this helps you with your problem.
Posted on May 15, 2009
  • 51 Answers
SOURCE: my disc keeps saying it's dirty on xbox 360 even
Your DVD drive's laser is malfunctioning.
You have a few options:
1) Decrease the resistance on the laser to increase power, and it may be able to read the discs again. A guide for that can be found here.
2) If that doesn't work, or you do not wish to do that, you can replace the laser head all together. Replacements can be found on eBay. You can follow this guide to replace the laser head.
3) You can replace the DVD drive completely, but it will require taking the original drive's firmware and putting it on the replacement one. The guide for that can be found here.
Posted on Dec 14, 2009
  • 3 Answers
SOURCE: Have Toshiba SD-P91S dvd player.
EXACT same problem here. All discs invalid. 1 second of disc motion and then nothing. Have barely used the device.
Posted on May 08, 2010
Disc won't load
Try a different disc, one that worked before if problem still persists try and buy a lens cleaning disc that should solve your problem. If not, your optical laser head needs replacing.
Sep 25, 2012 | Coby Televison & Video
Why does my player display
Sorry, the player is dieing. i had this player with the same problem.
Jul 05, 2010 | Cyberhome CH-DVD 300 DVD Player
Cello tv/dvd model dcs1420 cannot tune it in
please change your optical lens this a most common problem of all dvd player. bad optical lens always no disc on screen when loading disc, even cd's are new.
Aug 20, 2009 | Emerson EWF2004 20" TV
Dvd player
Go Video 2150 sayss Bad Disc. Then movie started and stopped.
Mona
Dec 17, 2007 | GoVideo Televison & Video
Sharp mini disc md-mt16
Is the Disc inserted UPSIDE DOWN? Turn it over. Are the Lens Dirty? Clean them. Are Your DISC's Dirty Or Damaged? Get one that is Clean And NOT Damaged.
May 21, 2007 | Sharp MD-R3 Mini Disc Player
Cd ejects
New CDs may have some rough spots around the inner and outer edges. If such a CD is used, this unit may reject the CD. To remove these rough spots, rub the edges with a pencil or ball-point pen, etc.
Nov 21, 2005 | JVC Arsenal KD-S6250 CD Player
Televison & Video Logo
26 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
