Question about Garden
Hayter ranger 53
Replace belt
Hayter 56 pro lawn mower will not drive with weight on roller I have replaced belt
Sounds like the belt is slipping
Is your new belt the right one or is it the same length as the old worn one.
You might try spraying the belt with a belt dressing and that may work if its the belt slipping.
Another thought is your belt tightener working properly.
Just throwing out ideas to check.
Nov 12, 2014 | Garden
2003 ford ranger need timingmarks my beltbroke
I've never done one on a Ranger, but most timing gears have alignment marks that you line up before you install the belt. Don't forget to replace the belt tensioner while you're at it.
Jul 06, 2014 | 1993 Ford Ranger SuperCab
How do you replace a broken cord in a hayter lawn mower
hi there i got a hayter lawnmower i want to know how to change a self propelled cable
Apr 06, 2012 | Garden
I have a hayter 13/40 type 144s ride on lawnmower and i am looking for a diagram to repace the blade belts
http://www.hayter-lawnmower.com/products/homeowner/handbooks/download.html?file=%2Fdata%2Fmedia%2F625%2F111-1012%20(Rev%20A).pdf&name=13%2F30%20Heritage%20Ride-On%20-%206%20Speed%20-%20131E%20(1).pdf
Apr 23, 2011 | Garden
How to replace a/c belt on 88' Ranger XLT Which
try loosing the alternator bolts then move it might loosen it up. hope it works
Nov 28, 2010 | 1988 Ford Ranger
Hi i have a hayter heretige 19/40 ride on mower it has lost all drive the belt is fine but it just wont move can you help ?
I have a Hayter 19/40 ride on mower it starts and run fine but when I take my foot off the brack it cuts out can you help.
Aug 31, 2010 | Garden
Lossen the fan belt on 2002 ford ranger. 3.0 liter
This is a difficult problem for an English-speaking person (me) - but I will guess at what you are saying is wrong with your Ranger......
You have a loose fan belt.
I believe that the belt is Surpentine - and, therefor has a belt tensioner. A loose belt normally exists if the tensioner spring is weak. Other possibility is that the belt has stretched beyond the ability of the tensioner to keep it tight.
Either replace the belt (about 30 dollars, US) or replace the tensioner. (Your 2002 probably has enough miles on it to justify replacing the belt anyway!!)
Oct 10, 2009 | 2002 Ford Ranger Regular Cab
THE STARTER CABLE ON MY HAYTER 41 PETROL LAWNMOWER HAS JUST BROKEN. HOW DO I PLEASE REPLACE IT, OR DO I NEED TO TAKE TO A HAYTER SERVICE ENGINEER? BRIAN TAYLOR
hi,if you can remove starter housing and think you are up to replaceing cord then you can get replacement cord from any repair centre but may be as well to take starter along and they should do it for a nominal fee ,which is cheaper than if you damage it doing it yourself,it doesnt have to be a hayter dealer since the engine is a briggs and stratton ,hope this helps
Apr 07, 2009 | Garden
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
