Question about Jeep 10 x 20
97 jeep wrangler overheated due to bad water pump. After replacing, it runs rough. It ran great before the problem now barely runs at all. Please help.
When you got it hot you probly blew a head gasket or worse worped/cracked the head. on mt caamaro i got wateer on the coil packs when changed water pump and they went out
Posted on Dec 26, 2009
Overheated. Why won't it start?
I'm not really familiar with JEEP mechanics but if you've replaced your water pump and it's still overheating with full water/coolant level, you should check the thermostat; when it fails, it's a common cause or overheating in all kind of cars
I'm attaching some links to Youtube tutorial about replacing thermostat in a Jeep but you can expand your Google search using terms
Youtube replace thermostat JEEP Liverty
https://www.youtube.com/watch?v=Y3NpLdG993U
Jeep 4 0L straight six thermostat replacement
Thermostat Replacement Overheating fix Part 1 Jeep
How To Change the Thermostat in Jeep Wrangler
2002 Jeep Grand Cherokee Thermostat Replacement
Replacing the radiator thermostat in any Jeep Cherokee Jeep liberty Jeep...
Sep 10, 2015 | Jeep Liberty Cars & Trucks
Car started knocking really bad got a cylinder 2 misfire code after opening coolant bleed valve with enging hot
Okay, it may be due to overheating, that may be the noise you heard, lets hope. first allow engine to cool, open radiator cap or the resivoir cap, which ever is the fill, remove the bleeder at top hose and fill radiator slowly until coolant comes out bleeder.
note if water pump was replaced due to leaking and engine was overheated at that time then it may be a good idea to replace the thermostat .
after filling is done start engine and allow it to run. watch temperature if temp start to climb past half way shut engine down and let sit for 5min. then restart and check level, in res do not open cap . feel air from fan and see if it is getting hot, this may take up to a half hour but do not drive,
A few questions, does this jeep have an electric fan?
when you heard the knocking was engine temp hot?
If you start jeep cold does engine knock?
Did this jeep get a new thermostat with waterpump job?
did it overheat when pump went bad and why did water pump get replaced?
sorry for all the questions ,just trying to get all the info to help you .
Dec 25, 2012 | 2004 Jeep Grand Cherokee
Just replaced the radiator and the jeep overheated after 1 month
It could be a bad thermostat or a water pump that is not pumping coolant. Even a miss routed serpentine belt causing the etc
PSA BSI tool for Peugeot and Citroen Odometer v1.2
Dec 13, 2012 | 1999 Jeep Wrangler
Have a 2.5 liter and number 2 cylinder exploded. I replaced the entire engine including head, valves, spark plugs and wires. new engine ran a little rough and had a check engine light for a o2 sensor....
check the spark plug wires. go somewhere dark, get a spray bottle with some water in it, then mist the spark plug wire and look for a spark to jump
Sep 06, 2011 | 2000 Jeep Wrangler
97 Jeep Wrangler sport- Cranks, will not
Fuel flow. Either simply, a blocked fuel line (debris / filter / fouled gas) or an electronic issue. Ever let this Jeep run bone dry on gas? Hopefully not, as doing so can draw a lot of crud into your fuel lines from the bottom of the tank. Electronically, if part of the Jeep "brain" has gone bad, there may not be any fuel being routed to the engine. This most likely needs a Jeep mechanic to repair.
May 15, 2010 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Rough running
Computers aren't ALWAYS correct. If a code wasn't cleared after the original problem, it will read the same codes off to the diagnostic. I would remove the wire connector to each injector while it's running. If one of them makes no difference THAT is your culprit. Let me know please!
Jun 27, 2009 | 1999 Jeep Wrangler
95 jeep wrangler overheating and hissing sound
Had the same problem on my 95 Wrangler within the last month. I was told that the radiators on Wranglers tend to wear out, and don't push fluid through after 10 years or so. I decided to 'fix' everything at the same time. I replaced the radiator, the radiator hoses, and the water pump. That stopped the leaking, and fixed the problem. Water pumps run less than $50, and is actually something you can do yourself. I'm not mechanically inclined, but I needed to save the labor charges from the mechanic, so I took at shot. I had no problems. It does help to have an extra pair of hands to replace the serpentine belt.
Jul 25, 2008 | 1995 Jeep Wrangler
Jeep 10 x 20 Logo
340 people viewed this question
Top Jeep Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
Are you a Jeep Optic Expert? Answer questions, earn points and help others
