The keyboard must be lifted to gain access to the top of the PC board. How to lift the keyboard?
SOURCE: how remove the panels to replace the rear hatch lifts 1995 camaro
You don't have to remove the panels, the lifts are held on with U clips at each end of the gas cylinder
SOURCE: I need to replace the CMOS battery in a Presario 906US Laptop
Here is service manual for Compaq Presario 900 (download parts one by one, then extract):
Part 1
Part 2
Part 3
Part 4
SOURCE: The On/off button is loose - I need to lift the keyboard
It depends what type of system you have...It it not very difficult. Some laptops like Dell xps, are so simple that you just need to lift a small face plate right below the screen and under it, it has 3 screws and keyboard pops right off...others you have to remove some screws from under the computer itself. Every laptop computer is slightly different. If you have the owner's manual, it walks you step by stem where to find the screws. If you don't have one, you can download it from the manufacturer's website ..it is a very smaill pdf file.
Good luck
SOURCE: unable to remove keyboard
you need carefull when you disassemble the KB, following give you a sense:
1) take out the long panel stick first it has the cable connect to motherboard, which should be disconnect.
2) then take out the KB part with the cable:
hope help you fix it, please take a rating let me know how much helped you thanks!
SOURCE: replace amilo Li1718 laptop cmos battery howto
the battery will see on the back or side of your laptop, press the two together and lock up slowly, ,,,,good luck
