Question about Bose (321GS) System
I bought a BOSE system in chicago. now in India not working
I plugged the system in India making sure i connected it with a spike protector. The system did not respond. I thought i heard a burp kinda sound...did the system die? Is it expensive to get it fixed?
  • Naveen k Dec 21, 2011
    Hi Naren,
    Were you able to solve your problem? I am in the exactly same situation. Please help.
    Thanks
  • 74 Answers
Electricity in India is 240 Volts, alternating at 50 cycles per second. You will require a voltage converter if you are carrying a device that does not accept 240 Volts at 50 Hertz. Check the voltage selector atthe back and set it to teh correct voltage - if not present buy an adaptor. Your component will have to be examined by an expert. Click here for repair locations in India.
Posted on Jul 08, 2009
Hi, I am working in US and planning to buy Bose V25 and take it to India. Please help me with following clarifications I have. Is Bose V25 system region free?. Is it going to work with both PAL and...
Hi,Did you get solution to your problem?If so let me know..Even we bought Bose V25 and planning to move it to India..did you face any problems else evrything worked out good for you?your answer regarding my problem is very precious..please reply me..
Jun 12, 2011 | Bose Lifestyle V25 Theater System
I have bose gs 3-2-1 Series iii home theater system. I bought it from us and now I am in India. I want it region free. can any one please provide me the information or the link to respective thread....
The only thing I that may not match is the power supply which I guess is 220VAC in India. Other than that I don't see any problem that arise from using it in your country.
Jul 03, 2010 | Bose (321GS) System
Wrong voltage applied
Whoops! Being a Bose, you should be lucky but the sounds you describe are not good. Take it to a competent engineer and get an honest opinion.
May 24, 2017 | Bose Companion III Computer Speakers
I bought a Bose sounddock from the usa and Adaptor has a two pin plug but the plug is interchangeable. - so... My question is I need to change the 2 pin part of the plug with a 3 pin uk part - where can i...
You can get a 3 pin plug from many shops, but make sure the voltage rating on the back says it will work on 240V if using in britain as America use 115v electriccal system.
May 20, 2010 | Bose SoundDock Digital Music System for...
Hello, I connected my Bose Companion 3 system that I bought in the US, to 230V when I brought it back to India. There was a hum in the acoustimass unit as soon as i turned it ON and then it simply died!...
It is 94/100 % sure it is smoked. You can look inside for a fuse, but based upon your description, there proabbly is not one.
Im sorry your smoked your new system.
Thanks for your question here at FixYa.com
Jan 09, 2010 | Bose Companion 3 Computer Speakers
32 '' CRT won't turn on afer power surge
Follow these steps to troubleshoot the television not turning on:
Make sure the AC power cord is connected securely to a working wall outlet.
NOTE: If the television is plugged into a power strip or surge protector, unplug it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Press the POWER button on the television.
Press the POWER button on the remote control that was supplied with the television.
NOTE: If the television turns on and off using the POWER button on the television but does not respond to the POWER button on the remote control, troubleshoot the remote control.
Unplug the television power cord from the electrical outlet for 30 seconds.
Plug the power cord back into a known working electrical outlet.
Attempt to turn on the television.
IMPORTANT for the following models only:
KDF-E42A10
KDF-E50A10
KDL-V26XBR1
KDL-V32XBR1
KDL-V40XBR1
Unplugging the above television models from the electrical outlet may only be a temporary fix. The problem may reoccur after several months of use. To completely resolve the issue, a software update is available.
For all other models, service will be required if the troubleshooting steps do not resolve the issue.
Aug 01, 2009 | Televison & Video
Bose cinemate will not power on. light stays red?
Make sure your system is not plugged into a surge protector. Sometimes a surge protector will foul the system up, don't know why. lol. I fought with my system for 3 hours trying to get it to work, then moved it from my surge protector to the wall and it came on. If that doesn't work, try disconnecting the receiver module itself, wait 60 sec, then plug it back in. If that still does not solve the problem, I would suggest calling Bose Customer Service..
Jan 25, 2009 | Bose Cinemate Digital Home Theater System...
Cant get all componenets to work together
Okay so you need to run a fiber optic cable to back of bose system for sound on the cablebox if it's a hd cablebox. If you don't have a fiberoptic connection on cable box then you can use a digital coax audio cable and plug it from cablebox if it has it to back of bose system where the plugs are colored all black under the red and white connections. This cable is basically a yellow video rca type cable. That cable doubles as a video cable and a digital audio cable. But anyways once you plug your cablebox up digitally you need to make sure under the settings or setup menu of cablebox that you go under audio and make sure your cablebox is set to dolby digital instead of hdmi. Especially if it's a scientific atlanta time warner cable box. The bose remote should operate eveything still unless I read your question wrong and your saying it doesn't.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 09, 2008 | Bose 3 2 1 GSX System
Help me i have bought bose 321 gs from newyork
Take the time to post some details in your question if you want anybody to take it a little more seriously
Aug 07, 2008 | Bose (321GS) System
Bose (321GS) System Logo
302 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
