Question about Panasonic KX-T7420 Corded Phone
Voicemail stopped working
Voicemail button gives a busy signal
  • 6 Answers
SOURCE: Voicemail
This is for the 'After hours' message:
  • Pick up the handset and dial 199
  • When you start to hear the message you can then press #
  • Dial 101* to get to the admin section
  • Dial 3 then 1 then follow the prompts
To change you own voice mail message:
  • Enter your extension number (aka mail box number)
  • Dial 7
  • Dial 3... then follow the prompts
Posted on Feb 12, 2008
cnavarro
  • 2460 Answers
SOURCE: Forward to voicemail
It depends on what you mean by not set up. Voicemail has specific steps to make it work and it starts with admin access to both the voice mail and phone system. If it is already set up (ie you can call 165 or whatever the VM number is), then what greeting it plays will give you an idea if what needs to be done.
If it plays a general greeting like when you call in from outside, it may be that you just need to add the mailbox for your extension. If it doesn't answer at all, then it's probalby time to call an installer.
Carl
Posted on Aug 27, 2008
SOURCE: number of rings before going to voicemail on KX-T7630
Press the FWD/DND button, then scroll through the menu button until the screen shows "FWD No Answer time". Then use the number key pad to change from 000 seconds to 010 seconds (or longer if required). Then exit out of the menu.
Posted on Jan 22, 2009
cnavarro
  • 2460 Answers
SOURCE: Cannot retrieve voicemail
When you press the message button, look at the display. Is it really going to the VM extension or is it going to another phone? Othre people could have left you a message by calling you and pressing the MESSAGE buttone either on purpose, or by accident.
You can clear ALL message lights from your phone by dialing *700 plus your extension and #. Of course you can access VM by dialing the VM extension, usually 165 or 500 from the intercom.
Posted on Apr 06, 2010
cnavarro
  • 2460 Answers
SOURCE: how do I make calls go to voicemail both for N/A
If your voice mail extension is 500, then on the intercom dial *7105 500 #
Carl
Posted on Apr 22, 2010
Busy signal when calling voicemail
You need to contact service provide for better help
Dec 19, 2012 | ZTE Warp
Boost voicemail has busy signal
I trying to set voicemail up but keep getting a busy signal
Jan 07, 2012 | Samsung Galaxy Prevail
How do I forward my phone (DKT-2020-SD) to voicemail?
This does depend on which Toshiba phone system your phone is connected to
Here are a couple possible methods
Press button
Dial 601(all calls) or 602(busy) or 603(no answer) or 604(busy/noanswer)
Dial voicemail access code(extension number of voicemail)
Press button to end
Press button
Dial #601(all calls) or #602(busy) or #603(no answer) or #604(busy/noanswer)
Press button to end
Dec 08, 2010 | Toshiba DKT-2020-SD telephone
My voicemail keeps calling into my line every 20 minutes saying it has a message for me and to enter my personal ID number. I don't have a personal ID and if I push any buttons it either gives me a busy...
The PBX administrator has a setting marked in the voicemail properties under your extension number that needs to be changed. Try to dial 0000 next time it calls you.
Mar 25, 2010 | NEC Dterm DTP 16D-1 Corded Phone
Voicemail has busy signal.
Most cell phone carriers get directed to another number to access voicemail. I would recommend contacting your carrier, they may be having a problem and they are unaware of.
Sep 22, 2009 | Lands Phones
No issue, just a question. Looking at RCA 25425RE1 4 line business phone system. If all four lines are busy , will the caller of the 5th call get a busy signal or does the phone have "busy no answer...
ANY phone system will have this problem.
If 5 people call in, the first 4 will be answered, but the 5th will get busy, as there are no lines available into your phones voicemail system.
IF, you have voicemail through the phone company, you can get their voicemail feature for extra.
THEN, if 5 people call in, the first 4 go to the phones, and the fifth gets the voicemail greeting.
It would be dependant on the line provider how many calls their voicemail would handle at one time. SO if 500 people call in, 4 get through, and MAYBE 5 go to voicemail, the rest get busy.....
Jan 13, 2009 | Lands Phones
Electra elite IPK Problem
There are several things that could be causing this and it depends on how many conversations (ports) your voicemail can handle.
1. The voicemail ports could all be busy. Dial vociemail when you know nobody is using it. If you can get in then there is nothing wrong except that your voicemail system is busy and you may need more ports.
2. If you are pressing a button on your phone, then the button may be programmed incorrectly. Using the dial pad, manually dial the vociemail and see if you can get in.
3. As a last resort, you can turn the phone system off for 10 seconds and then turn it back on. Do this with caution however and make sure nobody is using the phones. You also run the risk of defaulting the programming on your phone system. If the voicemail ports have locked up, this will clear the locked ports. If this happens again (busy) hopefully it is under warranty as either the voicemail is going bad or is misprogrammed.
Dec 08, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Panasonic KX-T7420 Corded Phone Logo
35 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
