Question about Roshco 5-qt. Pressure Cooker
The pressure button does not move from high to low.
After securing the lid in place the pressure setting button cannot be moved from low to high.
How do I increase the pressure on my Flotec FP711OT-08. It is low 40s psi, can I move it up to 50 psi or high 50 psi? Water pressure throughout the house is low.
There may be a pressure setting on your outfit but My feeling is -- your problem will be low pressure on your water line. Most pressure settings is to keep from having too much pressure on what your running. For instance our city water pressure is 70 lbs but in order to keep my furnace boiler system at 16 lbs I have to install a pressure reducer.
Nov 23, 2014 | Pentair Flotec Fp7110t-08 Water Tank...
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    I want to remove content control
    REMOVAL
    A/C Compressor Mounting
    1. Discharge the refrigerant. Refer to MTC-111, "HFC-134a (R-134a) Service Procedure" .
    2. Remove the front right wheel and tire assembly. Refer to WT-6, "
    Rotation" .
    3. Remove the engine under cover and the splash shield using power tool.
    4. Remove the engine air cleaner and air ducts. Refer to EM-14, "
    Removal and Installation" .
    5. Remove the drive belt. Refer to EM-12, "
    6. Disconnect the compressor electrical connector.
    7. Disconnect the high-pressure flexible hose and low-pressure flexible hose from the compressor.
    Jun 13, 2014 | Computers & Internet
    I have a Singer Stylist 533 and the feed dog isn't working properly. It is not jammed because if I turn the handle to use the machine manually I can see it moving below the presser foot. However, once I...
    This could be a couple things. First it could be your presser foot pressure is not high enough or the presser bar is sticking and not pushing on the fabric properly. Second it could be broken feed gears. To check this remove the needle and foot and place a finger on the feed dogs. Then turn the hand wheel and feel if the feed dogs are still moving with the pressure of you holding them down. If the stop moving the you most likely have a broken gear or two. The first problem could be resolved by adjusting the setting of the needle bar pressure or oiling the bar if sticking. The second one needs a sewing machine repair person,
    Sep 13, 2013 | Sewing Machines
    Baby lock serger will not feed, fabric want come out from under presser foot.
    what is the stitch length set to? should be 2.5 or thereabouts for normal serging.
    Is the pressure foot pressure turned up too high perhaps?
    The reasons I could think of for it not feeding through would be:
    - the feed dogs under the pressure foot are out of position/not moving
    - that the differential feed is turned up so its pushing the fabric back to the front of the machine
    - stitch length is set very low so hardly moving the fabric at all
    - or youv'e got a thread tangle happening around the foot/blade area.
    Jun 14, 2012 | Sewing Machines
    I have a cuff like this and get an error saying EE
    According to the Owners Manual, the EE Message shown on the display or the blood pressure value is displayed when an excessively low (or high) reading is detected OR as a result of one of the following:
    1. Cuff has been placed incorrectly. Solution: Wrap cuff properly so that it's positioned correct.
    2. Did you talk or move during measurement? Solution: Measure again. Keep wrist steady at heart level during measurement.
    3. Shaking or moving of the wrist with the cuff on. Solution: Same as # 2.
    NOTE: Be sure the cuff is placed exactly as pictured on the face of the box, 1/2" above the heel of the hand.
    Jan 27, 2011 | Walgreens By HoMedics Automatic Wrist...
    The cursor jumps from line or field on its own...I could typing away and before I know it, the cursor has moved to another field or to the middle of another word! real pain in the ****
    You will probably want to adjust the pressure sensitivity on your laptop's touch pad to alleviate this problem. If you have Windows, enter the control panel from the start menu.
    1. START > Control Panel
    2. Find Mouse or Pointing Devices.
    3. Enter the Pointing Devices Control Panel.
    Things can vary a bit in this section. So you should look for anything that deals with Pressure settings or Pointing Settings. One setting should be labeled "Touch Sensitivity." This setting controls how much pressure is required on the touch pad.
    -If you move the setting lower (or move the slider to the left) this decreases the sensitivity. It is harder to accidently move the cursor if you brush the touchpad while typing.
    -If you move the setting higher (or move the slider to the right) this increases the sensitivity. It is easier to accidently move the cursor if you brush the touchpad while typing.
    (Note that in some configurations, these are opposite - left to increase senstivity and right to decrease sensitivity).
    Depending on your laptop there may also be a setting labeled Touchpad Pressure. It's a setting that resgisters if you are accidently leaning on the touch pad. It's designed to reduce the chance of accidental clicks or motions. This setting is generally controlled the same way the Touchpad Sensitivity setting is controlled, through left-right sliders. I've found that keeping the touchpad sensitivity low makes it easier to avoid accidental cursor motions. I also keep the Pressure setting relatively high as well. One thing you'll note that if you adjust these settings to far into one extreme or the other, you will have difficulty using your touchpad. Fine tune these two setting until you achieve the results you want.
    Dec 05, 2010 | Computers & Internet
    Why is my hot water so low on pressure with a single handle faucet. Parts have been replaced yet pressure reduces to less than half when trying to get enough hot water to shower and rinse. Could this be...
    Remove handle and adjust the rotational limit stop. As you move the rotational limit stop counter clockwise it will increase more hot water in the mix.
    Remember where it is before starting and pull in back onto shaft out of place so you can move it a little and put back into place. It should have marks to line up to get you different setting's. Just put handle on and turn on and check for desired hot setting.
    The only way to adjust this is to pull it out of place due to it fitting in place like a gear and reinsert and check water.
    Jun 19, 2010 | Delta & Single Handle Shower Faucet
    How do I get both 8 hours time and high setting on this crockpot?
    I got it on high for 1 hour and then reset it to low for 7 more hours and everything appears to be fine. I suspect that this crock pot runs at a little higher temperature. The *low* setting seems as hot as my older crockpot on high...... With this crock pot - set the hours while turned off with the right button and then turn it on. You may have to play with it several times to get the proper heat setting. As I said, I could only keep on it *high* for 1 hour.
    Nov 22, 2008 | CorningWare SC60 Slow Cooker
    Roshco 5-qt. Pressure Cooker Logo
    Top Roshco Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Irene Tulloch
    Are you a Roshco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
