Question about Canon PC-735 Copier
Where do you put spring back on when it comes off
Say there is paper jam lever sping off
3 Suggested Answers
  • 199 Answers
SOURCE: problem during printing back to back
check the bypass if bypass not working (not pass paper) that means there are (inside) a sensor spring are loosed
Posted on May 13, 2009
pineworks
  • 4041 Answers
SOURCE: hOW DO i FIND THE PAPER THICKNESS LEVER SO CANON S330 WILL NOT JAM?
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 26, 2010
My samsung printer scx4521f show message: paper jam
Dear
you hav not mentioned paper jam(0,1,2 )
JAM 0 sensor at bottom of the HVPS a lever attached to this may not work properly. foun at the base.
JAM 1 sensor at the bottom of the SMPS a lever attached to it may not work properly check it.
JAM 2 sensor at top of the HVPS the lever is attached to fusser assy may not work check
check all springs attached to the levers are working properly.
thanks.
Jul 07, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Duplex paper jam . i thought i took out the paper that was jammed and i am still getting that message, PLUS now I cannot the top tray back.
The duplexer, which flips the paper to automatically print on the back side, slides into the back of your printer. Unplug the printer and slide the duplexer out to check it for jammed sheets. You might have pulled out a sheet or two in the main printer section and left one in the duplexer.
As for the top tray, the paper feed wheels ride on the end of a long lever that drops down to rest on the paper. It should be held up out of the way by a spring until the drawer is inserted, but sometimes the plastic nub that the spring pulls on breaks off. Lexmark sells a little kit of the spring and "bellcrank" to fix it. If your paper tray holds 500 sheets - a whole **** - you need part no. 56P1331 "Parts packet, bellcrank and spring, 500 sheet." For 250-sheet trays the part number is 56P1337. A web search for either part number will find you a seller.
Sep 20, 2010 | Lexmark T632 Laser Printer
Paper jam lights despite no evidence of a jam.
prior to the issue ,basically is your paper path sensor .1)firstly try to check all the sensor lever ,it must be at home position .i guess one of the paper path sensor lever activated paper present.this usually happen when removing jam paper incorrectly causes the lever sensor spring came off .2)it can also be the clutch and solonoid rotation timing issue.good luck ,pls rate me if u satisfy wih my clarification.!!!!!!!
Sep 08, 2009 | Canon PC-735 Copier
Paper jam and 2 found springs
Those 2 springs should be re-installed, they should be put back in place in the paper guide assembly in the back they should be there to apply pressure to the feed rollers so the paper will feed.
Aug 20, 2009 | Brother MFC-7220 All-In-One Laser Printer
Paper jam at transfer roller with no paper jammed. Have cleaned rollers with 409
Had the same problem after cleaning the rollers also. Technical help was rubish. In the end I found some clues n fixed it. There is a flag between the rollers n if it gets stuck and or in my case the spring behind it came off, then the sensor thinks there is a constant paper jam. Undo one screw and get inside n check the spring n flag. I done this. placed sping etc back in place, put it all back together n bingo. Be carefull not to drop the screw inside and make sure the cog is properly engaged or you will get a funny noise. I can provide pics etc if needed.
Jul 17, 2009 | Konica Minolta magicolor 2400 Laser...
The "Paper Jam" light on my Sharp AL-1631 copier stays on
The paper detector on the fixing units have a history of going bad. The fixing unit is the hot roller above the drum inside the right door on the top. As the copy comes thru the rollers the paper hits a plastic lever that is spring loaded and located in the middle of the fixing unit. The sensor is all the way to the right side of the fixing assembly. If you move the lever in the middle you'll see a piece of plastic moving on the right, that piece comes out of the sensor and if can't reset the jam, that piece may not be resetting itself back inside the sensor. This is difficult to try to explain.
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
Canon Imageclass MF4370dn constant paper jam errors
Dear
Inside the back panel there are paper sensors attached to lever, a small spring connected to lever to keep its home position, the spring may dislocated from its position or the lever sticked to the base. some times a small piece of paper sticked at this may cause the problem.
Thanks.
Apr 20, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Paper jam
I too have this infuriating problem and the reason has already been pinpointed very well it is indeed the front rubber pinch cam not grabbing the paper well. I have approached this problem from another angle... under the front sprung loaded flap on the paper tray
there are two compression springsapprx 1/2" in dia. Gently prise apart the 2 flap pivot (on the extended arms) to gain access to the springs ,pull out the springs and either replace them with slightly stronger ones or pull the existing springs apart to retension them and pop them back (long-nosed pliers or tweezers) this will restore the spring tension lost during use with the rubber pinch cam.
Jabba0737
Mar 10, 2008 | Samsung CLP 300 Laser Printer
Samsung SCX-4521 "Paper Jam 2" won't clear
I had this problem too. For me the answer turned out to be the paper sensor in the back part of the machine, behind the little back door just under the top part of the machine. This sensor hangs down from a thin rod that runs across the width of the machine, and is held in place by a small spring that encircles the same rod that supports the finger. The finger had apparently gotten moved so the spring was dislodged from its proper place. I was able to rotate it around the rod with my finger & get the spring moved back to where it should be. This seems to have cleared the problem--I'm keeping my fingers crossed.
Jan 22, 2008 | Samsung SCX 4521F All-In-One Laser Printer
HP 1020 Issue
Maybe if you hold down the cycle button and let it run through a "test cycle" to receive a printer data sheet it might clear the internal buffer or whatever you call that short term memory these printers have. Let us know. JP
Oct 17, 2007 | HP LaserJet 1020 Printer
Canon PC-735 Copier Logo
48 people viewed this question
old marine
old marine
