Question about New Home Sewing Machines
The wheel.of machine hangs up can i oil it
Yhr wheel of my machine hangs up and is hard to turn. Can I oil it
I have a 952 necchi supernova I beliv but I can't get ghee needs to go up a Anne down
1. If you turn the hand wheel with your hand and the needle doesn't rise or fall you will need to tighten the hand wheel.
2. If it is really hard to turn you may need to take the top, bottom and front covers off. Clean everything with rags and qtips. Some places may need carburetor cleaner.
3. Grease all gears.
4. Oil all moving metal against metal parts.
Once it is going make sure again that you have oiled everything.
5. The bobbin case and other parts need to be removed and carefully cleaned. The race (part the hook rides on) needs only one drop of sewing machine oil. Don't oil the other parts.
NOTE: It is an old machine and has probably set in a garage so there may be a build up of rust. To get the machine going you may have to overdose it with wd40. Force the machine loose if necessary. Afterwards the wd40 has to be removed. Oil the sewing machine with sewing machine oil.
Jul 24, 2015 | Necchi Sewing Machines
Brother sewing machine cs6000 hand wheel hard to turn by hand
before you race the machine into a service centre, most hard to turn problems are from thread and fluff wound around the bobbin shaft in the base of the machine. Use a pin/ needle to remove the thread /fluff then oil the machine using light machine oil. If it is still stiff , take it to a service centre.
Jan 31, 2015 | Brother Sewing Machines
Why wont the needle go up and down?
what model machine? First check that the bobbin winder is not engaged or the wheel on the inside of the handwheel is tightened, by turning towards the back of the machine. Often times on older Berninas the basting mechanism gets gummed up and has to be completely disassembled and polished/oiled as the replacement part is not available.
May 01, 2014 | Bernina Sewing Machines
My wheel will nor turn and my machine will not sew on my 930
sounds like it's time to have the sewing machine serviced.
Feb 07, 2013 | Bernina Sewing Machines
HAND WHEEL ON JANOME 350E HARD TO TURN AND MAKE SQUEAKING NOISE THEN JAMS.
Have you oiled it lately? under the bobbin there is a white colored "wick" one drop of oil (maybe 2 now).
It also might be time for a professional service.
Sep 14, 2012 | Sewing Machines
Machine wheel is very tight and hard to turn
not knowing your machine make or model, I can only suggest that you are having "tension" issues. Most machines have tension control located around the wheel, sort of like a second very thin wheel. This type usually requires that you would hold the wheel in place while moving the 2nd wheel to make the adjustment.
Other machines have the tension control looking like a push button. Maybe in the middle of one of the other tenstion wheels. pushing that button in while turning that and/or other control wheels would help that.
I may also be that your machine just needs to be oiled. Fabric stores will have this oil and it is specially formulated for sewing machine parts. More is less w this type of oil.
T ake a look all around and even under the machine, hopefully you will find a number for tech support for your machine.
Good Luck and Happy Sewing!
Jun 05, 2012 | Sewing Machines
Bernina 707 wheel is hard to turn
If the handwheel on your Bernina 707 is hard to turn, it most likely needs a good cleaning and oiling. Old oil dries and tends to get gummy, causing the moving parts to be stiff.
Oct 01, 2010 | Bernina Artista 180
Oiling the Brother LS1217
oil all moving parts and try turning handwheel by hand to work oil in. it really needs a service by a technician
scott
Jul 26, 2009 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
12 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
navapistol
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
