Question about HiTi P720L Photo Printer
0205 CINTA INCOMPATIBLE
ERROR DE CINTA
    New Friend:
  • 53 Answers
Pls Check the smart chip
Posted on Jun 24, 2016
Cual es la cinta de transferencia que tengo que quitar para limpiar los sensores de control de densidad de una bizhub 203
replace the black image unit and clean the transfer belt sensors located under the transfer belt
Nov 23, 2013 | Konica Minolta Bizhub c203 Copier
Tip
C?mo limpiar de forma segura a un Jefe de cintas de v?deo
<span><span><span>Si</span> <span>usted no est&aacute;</span> <span>recibiendo</span> <span>v&iacute;deo</span> <span>desde</span> <span>un VCR</span><span>,</span> <span>videoc&aacute;mara</span> <span>de 8 mm</span><span>,</span> <span>o</span> <span>c&aacute;mara de v&iacute;deo</span> <span>digital</span> <span>grabadora de v&iacute;deo</span><span>, pero</span> <span>de audio</span><span>obtener</span><span>, haga lo</span> <span>siguiente</span><span>:</span></span></span> <span><span><span><span>1</span><span>.</span> <span>Utilice</span> <span>una cinta grabada de</span> <span>nuevo</span> <span>-</span> <span>a</span> <span>la derecha</span> <span>del</span> <span>paquete</span> <span>e insertarla</span> <span>en</span> <span>la</span> <span>unidad.</span><br /><span>2</span><span>.</span> <span>Lleve a cabo</span> <span>un registro</span> <span>en la</span> <span>cinta</span> <span>-</span> <span>la puso</span> <span>a</span> <span>hacer</span> <span>un registro (</span><span>no</span> <span>la reproducci&oacute;n</span><span>)</span><span>.</span><br /><span>3</span><span>.</span> <span>Deje que se</span> <span>completa</span> <span>a trav&eacute;s de</span> <span>toda la cinta</span> <span>sin parar</span><span>.</span><br /><span>4</span><span>.</span> <span>Al</span> <span>terminar</span> <span>-</span> <span>le permiten</span> <span>rebobinar</span><span>.</span><br /><span>5</span><span>.</span> <span>Inserte</span> <span>una</span> <span>conocida</span> <span>cinta</span> <span>pregrabada</span> <span>buena</span> <span>y el juego</span> <span>-</span><span>observar</span> <span>la imagen</span><span>.</span> <span>Si es</span> <span>bueno</span><span>,</span> <span>entonces</span> <span>la</span> <span>cabeza</span> <span>estaba</span> <span>sucia</span><span>y</span> <span>est&aacute; limpio</span> <span>ahora</span><span>.</span><br /><span>Usted</span> <span>puede llevar a cabo</span> <span>lo anterior</span> <span>cuantas veces sea necesario</span><span>sin ning&uacute;n tipo de</span> <span>da&ntilde;os en el</span> <span>aparato</span><span>.</span></span></span></span>
on Dec 13, 2010 | Televison & Video
Que significa el codigo de error hd en el modelo wtw6600sw2
Todos los códigos de error que aparecen en una hoja de datos en la lavadora. Para acceder, levante el panel superior de la máquina y buscar entre la bañera y el panel frontal. El panel superior es levantado por la inserción de un cuchillo de la masilla a lo largo de la costura en la parte frontal superior se reúne la parte delantera de la máquina, cerca de dos pulgadas a cada lado. Empuje el cuchillo de la masilla en la costura para liberar los clips de sujeción y levante la parte superior.
NOTA: Asegúrese de que usted se aferra a la parte superior, por lo que no se abre y se rompa. Se recomienda que utilice un poco de cinta para mantener la tapa cerrada.
La hoja incluye todas las definiciones de los códigos de error, solución de problemas, diagramas de cableado y los procedimientos de diagnóstico.
Si usted todavía tiene preguntas, por favor, después de vuelta y me dejó saber. Espero que esto ayude.
May 19, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Al encender mi camara Nikon S80 me aparece que la tarjeta esta protegida para escritura como lo puedo quitar
¿Por qu? mi c?mara de decir "tarjeta bloqueada" o "protegido contra escritura"?
Los conceptos b?sicos. De la misma manera que las grabaciones en casetes de audio y cintas de VHS pueden ser protegidos por la ruptura de la ficha poco en la esquina posterior, el material en una tarjeta de memoria se pueden proteger contra la que se sobrescriban. En lugar de una ficha para romper, protecci?n de escritura se realiza mediante un control deslizante peque?a en el borde de la tarjeta (frente a la esquina cortada). Antes de que la c?mara tomar? im?genes, es necesario que este control en la tarjeta cuenta con un micro en la c?mara, que s?lo lo har? si no es en la posici?n de "bloqueo". El control deslizante en realidad no hace nada dentro de la tarjeta, por lo que yo no lo llamo un "interruptor" a pesar de que parece como tal. Su ?nico prop?sito es que sea detectado por el micro en la ranura de la c?mara, y es la c?mara que se encarga de la protecci?n de escritura, no la tarjeta.
Diagn?stico. Obviamente lo primero que debe hacer es comprobar que el regulador no est? en la posici?n de bloqueo. Si la c?mara te da este error en la posici?n de desbloqueo, esto significa que el regulador no ha podido hacer funcionar el micro, o que el propio micro est? defectuoso, o tal vez que hay alg?n error de sistema de archivos con la tarjeta. Para diganose el problema, ser?a muy ?til si se pudiera tratar de dos o m?s tarjetas de memoria diferente en la c?mara y ver si s?lo uno, o todos ellos presentan el problema.
Si s?lo uno presenta la tarjeta de memoria del problema: En este caso, es claramente algo que ver con la tarjeta de memoria. Es el regulador desgastados, doblados o que faltan? Una barra de desplazamiento que faltan de protecci?n contra escritura de la tarjeta de la misma manera que el deslizamiento a la posici?n de "bloqueo" se. Hay otra posibilidad. Recientemente he descubierto que algunas c?maras que utilizan tarjetas xD-Picture Card tambi?n dan este error a pesar de que esas cartas no tienen ni siquiera deslizadores de bloqueo! Adem?s, algunos usuarios han informado de la fijaci?n de este error a formatear la tarjeta. Por lo tanto, creo que tambi?n es posible que el error puede ser fijado por cambio de formato. Antes de hacerlo, aseg?rese de que usted ha copiado todo lo que quieras de la tarjeta y luego utilizar "formato" de la c?mara funci?n para formatear la tarjeta. Te aconsejo utilizar la c?mara durante la funci?n de formato porque as? se garantiza el sistema de archivos correcto. Si usted utiliza su computadora para dar formato, usted puede f?cilmente obtener el equivocado. Sin embargo, si es necesario hacerlo de esta manera, ver qu? sistema de archivos est? actualmente en uso en el disco antes de empezar. Vaya a "Mi PC" y haga clic derecho en la unidad que es la tarjeta de memoria, y seleccione "Propiedades". Ejemplos de sistemas de archivos son "FAT" (probablemente FAT16), "FAT32" y NTFS, para asegurarse de que su formato se realiza correctamente, asegurarse de que usa el sistema de archivos igual que antes.
Si alg?n trabajo tarjetas de memoria, y otros no, o las mismas cartas de trabajo, pero a veces s?lo a veces: El control deslizante es muy peque?o, as? que es posible que el n?mero de personas que informar de este error se debe a la falta de precisi?n en los tama?os de fabricaci?n. Debe ser dif?cil hacer un micro que puede sentir una cosa tan peque?a. ¿Tiene una mejor marca de trabajo de la tarjeta? ¿Puedes soportar quedarse simplemente las mejores marcas, o los que trabajan m?s fiable? Como remedio de ?ltima instancia, podr?a intentar envolver una peque?a tira de cinta adhesiva sobre el control deslizante para aumentar su espesor, pero creo que esta es una soluci?n de riesgo. Hay un riesgo de que la cinta saldr? en la ranura y causar a?n m?s problemas, o que la cinta ser? tan espesa que la tarjeta de atasco en la ranura y que tendr? problemas para sacarlo.
Si todas sus tarjetas de memoria se comportan de la misma manera: En este caso, es claramente algo que ver con la c?mara. Podr?a ser que el micro se rompe, o hay alg?n error de software. Aunque es menos probable, vamos a cubrir el error de software de primera; por favor, encontrar la funci?n del "restablecimiento del sistema 'en el men? de configuraci?n y uso para todo claro. ¿Es bueno? Si no, pruebe la soluci?n de cinta adhesiva en el ?ltimo p?rrafo en la esperanza de que se trata de un tama?o o el problema en forma con el funcionamiento de la micro, pero si eso no estamos fuera de las opciones en realidad, m?s all? de la reparaci?n de dicho micro.
Apr 22, 2011 | Nikon COOLPIX S8000 Digital Camera
Cyberamigos luego de 3 a 5 minutod de encender monitor aparecen rayas finas horizontales negras y a veces se quitan a veces no luego de mucho tiempo --gracias
Amigo tienes una pc de escritorio o una laptop.?
la falla es tipica de un problema en la tarjeta de video, creo que ya esta a punto de dañarse totalmente, te recomiendo compres una tarjeta de video nueva, En la laptop puede ser que se afloje la cinta que va al monitor. tendrias que abrir la laptop , limpiar los contactos y ajustar la cinta.
Mar 03, 2011 | Computers & Internet
Se desplaza la cinta de de tinta al imprimir
frubioa: En el soporte de la cinta hay dos peque?as laminitas que mantienen fija la cinta, si estan muy dobladas hacia adentro, no sujetaran el rollo de cinta. Puedes levantar esas laminitas para ajustar el rollo.
Roberto Martinez
padrino99@prodigy.net.mx
Jan 13, 2011 | Zebra Z4Mplus Label Printer
My DVM70 will not play back the tapes. I can record and the screen looks like it is recording just fine, everything looks normal. When I go to play the tapes back on the camcorder the lcd screen is blue...
ES MUY POSIBLE QUE EL CABEZA L DE VIDEO SE ENCUENTRE
SUCIO LO IDEAL ES USAR UNA CINTA LIMPIACABEZALES O USAR UN SPRAY DE LIMPIEZA DE USO ELECTRONICO (DE LOS QUE NO DEJAN RESIDUOS OLEOSOS) ,APLICANDO PEQUEñOS CHORROS SOBRE LAS GAPS DEL CABEZAL ROTATORIO , ESPERAR ALGUNOS MINUTOS Y CARGAR EN LO POSIBLE OTRA
CINTA EN PLAYBACK ,TAMBIEN SE PODRIAN LIMPIAR LOS CABEZALES AVANZANDO Y RETROCEDIENDO RAPIDO UNA CINTA
Oct 02, 2009 | JVC GR-DVM70 Mini DV Digital Camcorder
NO TENGO TINTA
COMO CAMBIAR LA CINTA (transcripcion del manual):
Nota: Apaguela.
1) Levante la pestaña del lado posterior de la tapa de la impresora y luego retire la tapa. (Figura 1)
2) Mientras sostiene el seguro de la cinta (A) en la dirección de las flechas, levante los carretes de cinta del eje. Deseche la cinta y carretes viejos. (Figura 2)
3) Separe los carretes de cinta nueva entre la cinta y la cabeza de la impresora.
Guíe la cinta alrededor de las cuatro guias de cinta (B) y coloque los carretes
encima de los ejes. (Figura 3)
4) Permita que los carretes se asienten y suelte los seguros de cinta. Si es
necesario, gire los carretes hasta que las clavijas en la base encajen en los
huecos del soporte de carrete. (Figura 4)
5) Gire cualquiera de los carretes para templar la cinta y asequrese que la cinta
pase por las cuatro guias de cinta. Coloque nuevamente la cubierta de la
impresora. (Figura 5)
NOTA IMPORTATE: Utilice unicamente el mismo tipo de carretes de cinta y
coloque la cinta de la manera indicada.
Puedes bajar el manual aquí (tambien en espanõl):
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=349&modelid=10226
Jul 14, 2009 | Canon MP-11DX Calculator
Zebra Stripes s400
el codigo de barras sale corrido de su posicion
Oct 29, 2008 | Zebra Stripe S400 Label Printer
HiTi P720L Photo Printer Logo
37 people viewed this question
Top HiTi Office Equipment & Supplies Experts
Emmanuel Sackitey
Chas Peters
Level 1 Expert
Are you a HiTi Office Equipment and Supply Expert? Answer questions, earn points and help others
