Question about Nuova Simonelli Mac 2000 I Group Espresso & Coffee Maker
More info there is steam and water coming from the wand and the hot water dispenser. After pressing the shot button, the pump is running, but there may be 1 single, tiny, drip from the group and that is it. Nothing. If I push a pre- programmed button, it will run briefly and then the main cup fill button will flash and beep. the pressure gauge at this point is non existent. The machine did sit idle for 3 months, not plugged in. I think this is everything. thanks
    President:
  • 1,618 Answers
Sounds like either the gigleur on the top of the machine is blocked, or the blockage might be in the flowmeter gigleur.
Posted on May 08, 2014
EsWorld
  • 1618 Answers
SOURCE: Describe your Nuova Simonelli Mac 2000 I Group
Either the brew solenoid is bad or the shower screen is blocked or the metering jet on the top of the head is clogged.
Posted on Aug 28, 2009
EsWorld
  • 1618 Answers
SOURCE: My Nuova Simonelli Mac digit pushes steam out of the group
The metering jet on the top of the boiler is blocked.
Posted on Nov 26, 2009
  • 3 Answers
SOURCE: espresso machine loses steam than recovers in minutes
It sounds like a heating element issue. Those elements look like a single unit but are actually made up of 2 or 3 independent heating coils - one may not be working. So, you're only getting 1/2 to 2/3 heating capacity, which isn't noticeable until the machine is under heavy steam load.
Posted on Feb 20, 2010
EsWorld
  • 1618 Answers
SOURCE: milk frothing wand will not opporate
Check the end of the steam pipe, it might be blocked. If not then the machine is block where the pipe to the steam valve sits on the boiler.
Posted on Mar 02, 2010
EsWorld
  • 1618 Answers
SOURCE: recently bought a used premier maxi that was
Either your machine froze in transport, or the inlet solenoid is not working.
Posted on Oct 06, 2010
Help!! When I press the button to make coffee water only comes out the steaming wand. No water is directed through the ground coffee.
May be blocked or foulty selector or bad commands from cotroll PCB try running descaleing may be spouts are blocked
May 21, 2015 | DeLonghi Magnifica Coffee Makers &...
No water/steam coming out of wand
hi there,
do you hear the pump running when you ask for water or steam? You should hear the pump continuously when you ask for hot water, and intermittently when the steam is dispensed.
No hot water or no steam could come from many causes:
valve not working or not actuated (control board), and also the switch that closes when the water knob is turned may be defective.
Do you hear that switch clicking when you open the water knob?
Difficult to help further with so little behaviour information.
Good luck,
M.
Oct 28, 2017 | Saeco Vienna Plus Espresso Machine
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
Our machine will not make coffee or water will not come out of the hot water dispenser.
water and steam wand work
but i cannot get any response when i press the cup buttons
Feb 08, 2011 | Lavazza Espresso Point Capsule Machine
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium. Fault suggests ventilation required. Followed manual instructions, nothing happens. Tried rinsing, nothing happens. Tried hot water nothing happens? Have taken out and cleaned all pbvious...
Do you hear the pump working but no water flows?
You should select hot water (the third button from the right) and the display should say "hot water" at the same time it is saying VENTILATE --- open the steam valve all the way and the pump should start and you should see water from the steam wand.
If you don't hear the pump at all, then that is a different problem.
If you do hear the pump but still don't get any water with the steam valve open, then you need to prime the pump by using a turkey baster or the accordian pump that came with the Titanium to pump water into the valve where water from the tank goes. Remove the tank and use the turkey baster to pump water into that valve while the pump is running and the steam valve is open all the way with HOT WATER selected. the second water starts to come out the steam valve you want to stop the pump (turn the power off or turn the steam knob shut) and put the water tank back on and make sure there is plenty of water in the tank - then start the pump again by opening the steam valve all the way and let it pump water out the steam wand for a few minutes.
Oct 05, 2010 | Gaggia Titanium Espresso Machine
Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
Mar 05, 2009 | Saeco Classico Espresso Machine
Please help
The Magic Comfort Plus machine has a selection for the temp through the menu for the three sizes of coffees buttons. Using the menu button, scroll through until you come to temp section, then select the coffee size button and and change the temp, example-- Select maximum. Press the menu button to set it.
If that does not help, when a machine gets full of calcium (needs descaling) that also will lower the temp. You might have to descale it three-four times.
And remember, when you descale, run the solution through the steam/hot water wand and also the espresso/coffee dispensing nozzle. Only doing it through the steam wand (like the manual says) will only do 1/2 of the machines water sections!!! I usually run 1 cup of solution through the steam wand and 3-4 cups through the espresso dispenser.
Dec 23, 2008 | Saeco Magic Comfort Plus Espresso Machine
Francis!Francis!3X overheating
Your thermostat has failed. The middle button is the pump. The bottom button is for the steam mode. If you are getting steam instead of hot water when using the pump, then the boiler is way too hot. Either adjust the thermostat or try descaling the boiler.
Feb 13, 2008 | FrancisFrancis! X3 Espresso Machine
Ventilate
I fixed my ventilate problem! After 2 days of utter frustration and pushing many buttons, I read another guest comment about resetting to factory settings. Push the up button under the small coffee icon. It should say factory setting with the asterick next to it. Push OK. Then push "yes" for factory settings. Then my machine started working again! Hallelujah! It erased my personal coffee cup setting, but who cares.
Big thanks to the person who posted their solution on Dec. 2007.
Jun 11, 2007 | Gaggia Titanium Espresso Machine
Nuova Simonelli Mac 2000 I Group Espresso & Coffee Maker Logo
46 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
