Question about Samsung SMH9187ST Microwave Oven
Install template for samsung microwave mode SMH9187ST
Need the template for back venting the microwave where can I find it
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Samsung Over Counter Microwave Does not vent
You can download Samsung over the range microwave installation instructions here.
The installation instructions will tell you how to set it up.
Even if you're exact model is not listed, there should be one close enough to yours to work.
Once you look that over, if you still have trouble, please reply back.
Otherwise...
Posted on Dec 07, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Samsung Microwave for over the range vent issue
Most over the range models can be vented to the outside, or they can be set up (sometimes requiring a special adapter) to recirculate with a charcoal filter.
It depends on the model, and you would of course have to consult the installation instructions to be sure.
You can download many Samsung over the range microwave installation instructions here.
You may need the free DJVU viewer to view or print your manual.
You can order Samsung parts here.
Posted on Dec 06, 2009
SOURCE: I have a Samsung SMH9187ST microwave, it is about
If you can lift the plastic door latch catches with no resistance, it is most likely the spring/plastic connector. I removed the door by lifting up, pulling the bottom forward, and lowering. I removed the inside black plastic bevel with a jewelers flat screw driver, prying from the latch side's external edge. Once it was started, I could pull it of with a gentle lift. I took out the black plastic latch, drilled a hole near the broken piece and all was good. Samsung is not on my radar for any future purchases. This is the 3rd major purchase that barely made it past warranty or not even thru warranty.
Posted on Nov 27, 2011
My samsung microwave model SMH9187ST has an SE error code. What do I do?
Eric,
From what I have read, it does not sound real promising to get it repaired without going through a lot of hassle. I will include a link to a consumer website of the complaints about this problem. It sounds as though it is a sensor problem.
Samsung Microwave
May 20, 2015 | Samsung SMH9187ST Microwave Oven
Replacing keypad smh9187st
You can do this without removing unit from wall. First unplug unit. Next remove the two screws on the top of the unit closest to the front. These screws simply keep the up facing vent in place. Next slide the vent to the left (plastic latches on bottom hold in place) to allow vent to be removed. You should now see a single screw above the control panel. Remove it then open the microwave door. Gently slide the control panel up which will disengage the plastic latches on the panel sides. Suggest if you are going to remove the controller and replace take a picture before removing it so you know exactly how to reconnect all the wires.
Jan 06, 2013 | Samsung Microwave Ovens
How do you remove the door panels on a samsung SMH9187ST? I am replacing / repairing the door latch.
Hi Jerry, it sounds like I have the same problem as you. Have you been able to fix yours?
Sep 08, 2012 | Samsung SMH9187ST Microwave Oven
Door handle loose
The service manuals for Samsung model SMH9187ST are here and here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 05, 2012 | Samsung SMH9187ST Microwave Oven
My Samsung SMH8165ST Stainless Steel 1600 Watts Microwave Oven Problems
This indicates a system error, the keypad has a short in the membrane, the keypad control board will need to be replaced.
May 02, 2012 | Samsung SMH9187ST Microwave Oven
Need an installation manual for a Samsung SMH1816S Microwave .bough as a floor model...came with no paperwork
Gary Find a similiar model online and see if you can download a manual. I am installing the same microwave and lost my manual but remembered enough about it to install without a vent. I have have the templates which help but are not as critical as you might think - if you are not venting.
Nov 07, 2011 | Microwave Ovens
I need the installation manual for microwave SMH9187ST/ J4LV7MTS203118V
Sep 16, 2011 | Microwave Ovens
Where is the fuse located on the samsung smh9187 otr microwave
There are 2 screws on top that release the top vent. Under this is a single screw that releases the front control panel. Behind the control panel are 2 fuses. Mine are 20 amp. I'm heading to radioshack now to replace the one that is blown. Lowes has them but I have found Radioshack to be a little cheaper. Lowes use to, but they found they can charge 5 times what they are worth.
Jul 10, 2011 | Samsung SMH9187ST Microwave Oven
Peeping , screen says 5E
Hi, SE stands for "sensor error". It means that your humidity sensor has shorted and unfortunately needs to be replaced. You will need to uninstall the entire unit and remove the outer shell to access the sensor that needs to be replaced. It will be mounted somewhere around one of the vent on the cavity of the microwave.
It must be replaced, there is no way to clean it. The part itself is usually about $30 so depending on the cost of your microwave it may or may not be worth it.
Apr 02, 2011 | Samsung SMH9187ST Microwave Oven
Samsung SMH9187ST Microwave Oven Logo
95 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
