Question about Xerox Phaser 6360 Laser Printer
Xerox 6360 My Xerox 6360 is making an occasional loud clicking or clacking sound on the right side of the machine. The manual feed does not make the sound. Is there a simple fix for this problem? Thanks!
johnychel
  • 796 Answers
SOURCE: xerox grinding noise
the bearing on the motor or the rotating path must have damaged..
replace them
Posted on Jun 02, 2008
  • 2072 Answers
SOURCE: Xerox 6360 will not recognize replacement toner
Only two things I can think of.
1 Be sure you have removed all the seals that are on a new cartridge. The tape etc. Sometimes a piece of one of them rips off.
If you have all the packaging seals removed then return the cartridge because its defective.
That machine can take up to 3 minutes to recognise a new cartridge. So if your turning it on and off quickly, let it set up for a few minutes.
Posted on Dec 31, 2009
Testimonial: "This should help"
StevenC82
  • 160 Answers
SOURCE: Xerox 6360 control panel blank
If your Xerox Phaser 6360 has either garbled characters, inverted or upside down display, or no display, the control panel is most likely bad and must be replaced. Here's a video on how to do it and where to get it. Hope it helps!
Posted on Feb 03, 2011
lawdog81
SOURCE: xerox phaser 6360 is ghosting.
Most common cause of this is the use of 3rd party toner. This isnt true for all printers but some of the newer Xerox are notorious for it as the 3rd party toners are not produced to the exact specs as xerox. If your not using genuin Xerox toner you have your cause.
If your mechanicaly savy you can completely dissasemble most of the printer in order to clean out the toner. Then start over with new Xerox toner cartridges. I have had to service 2 of these printers in this way, and both were like new when done.
Posted on Feb 11, 2011
StevenC82
  • 160 Answers
SOURCE: Xerox phaser 6360 laser failure
The most likely cause here is the laser unit, check all connections to the laser unit and cycle the power (turn the machine off and on) if error continues replace the laser unit. You can buy a replacement for $350 new or $225 refurb. Part# 062K17233. Installation isn't very simple, so if you aren't a technician you may want to bring it to one. Good luck
Posted on May 03, 2011
Xerox phaser 6360 smearing magenta toner only
that's the developer assembly that has gone bad. If you're using 3rd party toner it wears down a lot quicker. You'll need to replace the magenta developer unit, part number is 848K03850.
http://www.iteminconline.com/848k03850_848k03850-xerox-6360-developer-assembly-magenta-oem-new-genuine.htm
Feb 09, 2016 | Xerox Office Equipment & Supplies
How to replace the main drive assemble gear on a xerox 6360
Remove the top cover, remove the right cover, disconnect the cable, remove the 4 screws that hold the main drive in place and remove.
Aug 15, 2014 | Xerox Phaser 6360 Laser Printer
Xerox 6330 loud clicking sound
Check the rails the paper tray sits upon. see if the one on the right side is damaged or dislodged. You didn't say if the noise happened when you printed from the 2nd paper tray.
Apr 01, 2014 | Xerox Phaser 6360 Laser Printer
I have a Xerox Phaser 6360 that one day just stopped printing yellow, despite having plenty of ink. Xerox told me I needed a new imaging unit, so I replaced it, but it didn't help. I put the old one back...
Your machine uses solid ink wax blocks. So no calibration is necessary. Does the self test print look good. I suspected not.
Check out the Xerox.com website. It could be a problem as you machine is no longer sold.
Sorry.
Oct 16, 2013 | Xerox Phaser 6360 Laser Printer
Xerox phaser 6360 imaging unit stuck
The lid lifts a lever on the right side of the printer that moves a set of gears that releases the imaging unit. If the lever is broken or disconnected, it will not release. You may have to remove the right side panel to resolve it. You have to release the top, by removing 4 screws, and then the panel will release.
May 18, 2012 | Xerox Phaser 6360 Laser Printer
Xerox 6360dn, Tray 2 makes loud grinding noise when printing. Tray 1 is as quiet as a mouse. Replaced tray 2 with a known good tray and it still makes grinding noise.
In my experience, it was the registration roller causing the grinding noise. See http://my.brainshark.com/Phaser-6300-6350-6360-Grinding-Noise-795590408 for troubleshooting video.
Oct 18, 2010 | Xerox Phaser 6360DN Printer
Loud clicking from the manual paper feed? very loud..? xerox workcentere pro 16fx
When printing from the computer, Clicking starts from the printer before printing starts.
Aug 11, 2010 | Xerox WorkCentre XD120F Laser Printer
Xerox Phaser 6360 Black Toner prints Light Grey
I have had to repair a few of these. Take off the sides and back of the 6360. You'll see the hoses that feed into the laser. The black one becomes unplugged from the laser. All you have to do is plug it back in. The next step can be kinda messy. Take out the black toner cartridge, and spin the motor backwards. You'll know you're going the right way because it won't turn the other way. Cycle the gear where the toner sits for about 2 revolutions. Reassemble and you should be good to go!
This thing took me 6 days to figure out the first time. Haha!
Please vote on my solution! Thanks!
Sep 12, 2009 | Xerox Phaser 6360 Laser Printer
Mar 30, 2009 | Xerox Phaser 6360 Laser Printer
Xerox Phaser  6360 Laser Printer Logo
14 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
