Question about Toshiba E-STUDIO 450 Copier
I have this problem, below tells me the problem but how do I fix it? copier is Toshiba E Studio 150 error L1 L1-00 indicates feeding is not completed within the specified time after starting feeding. (The scan head locking switch is locked) The white area and the black marking on the shading plate are used to obtain the difference in the CCD level values for judgment of lock. When the difference in the levels of which and black is small, it is judged that the black mark could not be scanned by lock and the trouble code ?L1? is displayed.
  • Cynthia Heimsoth
    Cynthia Heimsoth May 11, 2010
    The copier is basically telling you why it's figured out that the paper hasn't gone where it's supposed to go. One common issue with the tabletop Toshibas is that there is a scan lock button under the scan plate (above the area where the paper comes out). Take a small mirror (like a lady's compact) and put it on the place where the paper comes out, reflecting upward. You should see a slide switch that is marked either locked (closed padlock) or open (open padlock). You want it to be open. Did that clear the code?
  • 143 Answers
Make sure the scan glass is clean on the bottom, and the rail the scanner moves on is CLEAN and lubricated with 3N1 oil.
Posted on Jun 26, 2009
Error e030 copier toshiba 202L
E030 indicates Paper remaining inside the equipment at power-ON.
If no paper is found, probably the actuator/sensor is faulty. Kindly perform input test on following sensors:
Exit sensor 03-[FAX]ON/[2]/[B
Registration sensor 03-[FAX]ON/[2]/[A]
Upper drawer feed sensor 03-[FAX]OFF/[6]/[E]
Aug 28, 2012 | Toshiba e-Studio 202L Copier
I have problem with "L1" error on my toshiba e-studio 120....how to solve it?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The scanner does not complete feeding in the specified time
Jul 29, 2010 | Toshiba e-STUDIO 120 Laser Printer
I have a Toshiba e-studio 150 copier. L-1 error code flashing
hi there is problem L-1 means that u have problem CCD MCU Harness Disconnect
May 12, 2010 | Toshiba E-Studio 161 Copier
Sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
Jul 20, 2009 | Toshiba e-Studio163 Copier
Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
May 27, 2009 | Toshiba Office Equipment & Supplies
L1 subcode 00
The white area and the black marking on the shading plate are used to obtain the difference in the CCD level values for judgment of lock. When the difference in the levels of which and black is small, it is judged that the black mark could not be scanned by lock and the trouble code “L1” is displayed.
Apr 23, 2009 | Office Equipment & Supplies
Hi tohisba e studio 150
This is a fuser error.
First you must enter the simulation mode as follows:
press the keys clear, density select, clear, density select
then press the copy key
use the arrow up and down buttons to select the number 14 in the display
press the copy key
this should fix the problem
c
Aug 06, 2008 | Toshiba e-Studio150 Copier
F120 fault on Toshiba estudio 232
HOW TO RESET ERROR CODE F-120 IN TOSHIBA STUDIO 232
Jul 09, 2008 | Toshiba e-Studio 232 Black and White...
Error code L
L signal is scaner lock
please chack your copier left side copy board under lock unlock mark
Thanks
Tareq
Mar 05, 2008 | Toshiba e-STUDIO 150 All-In-One Laser...
319 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
