Question about Steamist SM-46 4600
Unit does not shut off
Comes on when plugged in
My unit shuts off whenever it wants even with the charger plugged in. When I try to turn it on it comes on for a few seconds and shuts off again.
Is the Unit being fully charged before using it. Your Unit should have a Reset on the bottom of the GPS. Use a paper clip and press into rest hole with the Unit turned on. It will now shut off, restart the Unit. Usually this will helps with a lot of the problems. Good Luck!!
Jun 25, 2011 | Tomtom GPS
The air conditioner cools the room but it shuts of. The power light doesn't come on while unit is on. Can I replace the plug?
"The air conditioner cools the room but it shuts of." -- Temperature reached, but does not turn back on automatically? Stops short of reaching temperature? Shuts off for a period, but will come back on only to shut off again later?
Most importantly, how do you get it to turn on again?
"The power light doesn't come on while unit is on." -- If the unit is on and the power light is not, then the power light must not be operating (is burnt out).
Actual answer: "Can I replace the plug?" -- Of course you can.
What is causing you to feel that the plug needs replaced?
:o).
Jun 04, 2011 | Daewoo DWC-056CL Air Conditioner
Unit shuts off as soon as it is plugged in
Hard start Kits are attached to a compressor wiring to give an extra amount of electric current to the compressor motor. You will need someone more familiar with refrigerator wiring to do this. Hard Start Kits are available at refrigeration parts houses.
Aug 24, 2009 | Refrigerators
My LG window ac continues to shut down after 20 or 25 minutes
The button on the plug is a GFI. Ground fault interuppter. Like on your hair dryer. When the unit is running, or has just tripped out, feel the plug and the well receptical. If either feel warm or hot, do not continue to run the A/c unit. Get an electrician to check for a faulty/ worn/improperly wired outlet. The units tripping out for a reason.
Aug 01, 2009 | Samsung AW0603B Air Conditioner
Unit (tom tom 1xl) turning off
One hour is about the time the unit will run without a power source.
You need to check that the cigarette lighter is working. Check the car fuse.
Check the fuse (one of the six bumps) on the cigarette lighter plug has not blown.
Is the cigarette lighter / Tom Tom lead damaged in any way?
Peter
Mar 01, 2009 | Tomtom One XL GPS Receiver
Player would not come on
Have you tried pushing the reset button in the small hole next to where you plug the headphones in? I find this usually works if mine will not turn on or is frozen.
Sep 06, 2007 | Memorex MMP8565 MP3 Player
GE Portable Airconditioner - Model APN10AA Serial # GG509122
Ours was leaking water. After taking the covers off,cleaning it,and draining all the water out, I started getting the same problem with the light coming on every 7 minutes. I actually added some water to the system till it was too full and then drained it out through the plug. The light still came on every 7 minutes until I turned the unit off and then unplugged it for a few minutes. I plugged it back in, turned it on and reset the temperature. It seemed to reset itself and kept running normally. BB
Aug 07, 2007 | GE APN10AA Portable Air Conditioner
Steamist SM-46 4600 Logo
29 people viewed this question
Top Steamist Electrical Supplies Experts
Craig Butler
Craig Butler
ray gallant
Are you a Steamist Electrical Supply Expert? Answer questions, earn points and help others
