Question about RCA DRC8030N
VHS -DVD RCA Flashes in blue color
Hi.. I would want to know whichever long time, I require to receive my information. My RCA. DVD Record VCR. Stand for casks: Serial. 5501000337. Similar DRC.8300N- because I Copy from VHS-DVD it flashes, in blue color in the monitor, and the same it leaves in DVD. I Pay $.9.95 with VISA for one E-mail I dont recib nothing. for make the SetUp Sincerely Alfredo
  • 253 Answers
If i understand your statement, you are having an issue copying either VHS to DVD or vice versa, most media today has built in copyright protection to prevent what you are trying to do, there are PC softwares to bypass these, but you will have to hook the player to your PC using a TV Tuner, or an Application called VHS to DVD or something similar,
Posted on Jun 15, 2009
I am supposed to be able to record from VHS to DVD and yet I am unable to do so. I asked the question yesterday and did not receive and answer.
Not knowing what components you have makes it difficult to assist you. As a general note, HDMI provides the best connection for video and audio.
HOWEVER, the HDMI source can talk through the cable to the connected device. A cable box, seeing that something other than a TV is connected to it, will turn off the signal rendering the connected device useless.
To get around the problem, cable the devices together using component video and audio cables (5 cables are required). They are typically colored red and white for audio and green, blue and red for video.
Oct 05, 2014 | Televison & Video
Progressive Scan
Try these steps:
Locate the output jacks DVD player. Sometimes they are standard female RCA A/V jacks, like those found on the front of many VCRs. Others are more tricky, having a small jack that looks like a stereo headphones plug. These camcorders require a special cord that converts a 1/8" stereo signal into RCA A/V male plugs.
  1. Using the proper cord, connect your PLAYER to the VCR's RCA A/V input jacks, usually found on the front or back of your VCR.
  2. Turn on your VCR and TV, so you can see the input from the camcorder. You might have to select "Input 1/2", "Line 1/2", or "VIDEO" depending on your VCR model. You should now see whatever is on your camcorder displayed on your television.
  3. Press "Record" on your VCR, then press "Play" on your camcorder. That's it!
Sep 07, 2008 | Samsung DVD-VR357
I have an RCA VCR model VR651HF that still works great. I can record shows without a problem as long as I'm not trying to watch a dvd. I recently bought a Sony dvd player model DVP SR200. I have my cable...
The sequence should go from the wall to the VCR then the VCR to the RF modulator then from the RF modulator to the TV and this should allow you to record a TV program and watch a DVD at the same time.
Feb 25, 2011 | RCA VR651HF VHS VCR
Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
Jun 30, 2009 | Quasar VHQ400 VHS VCR
Recording 3 digit channels
With the VCR connected to DirecTV, you're not picking the channel with the VCR anymore. You're picking the channel on the DirecTV receiver, and the VCR will record on channel 3 or 4 (if you've hooked the receiver up using the RF output to the VCR) or through its line (A/V) inputs if you're using those. The tuning range of the VCR is completely unimportant.
With your new system, though, there's one big drawback. Since the VCR is always set for channel 3 or 4, or its line input, and you're changing channels on the DirecTV receiver, you can't program the VCR to record several different channels if you go out. You won't be home to change channels on the receiver, so the only channel you'll be able to record is whichever one you've selected before you go out. Remember the VCR is taping the output of the satellite receiver, and not the satellite channel directly. If you record on some channel other than the receiver's output channel, there won't be anything there. All you'll get is snow or a blank screen.
Mar 31, 2009 | RCA VR706HF VHS VCR
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Want to transfer vhs tape to dvd
not sure why you would need an rca to s-video adapter, almost every dvd recorder and vhs has rca input and ouput.
anyway here is the basics to record from vhs to dvd you would connect the OUTPUT video (yellow) and right and left audio OUTPUT (red and white) to the dvd recorders INPUTS.
Dec 29, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
VCR WON'T RECORD
you may have the outputs hooked up correctly however you may need to set the inputs to the selected type of cable you are using. S video 1 cable or video input witch is an rca adapter yellow in color. you will find these setting in the "setup section" on the remote set up button will get you there and then input or source.
Dec 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
RCA DRC8030N Logo
133 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
