Question about Epson LX-350 9-Pin Serial Impact Dot Matrix Narrow Carriage Printer, 347 cps 10 cpi, Bi-directional Parallel IEEE-1284, USB 2.0, Serial
Not printing generic driver
Driver download?
on the HP support website find the exact or generic PCL5 or 6 driver and install it.Windows 7, 8 and 10 should be able to auto install the PCL generic printing driver. Regards, Mike
Feb 23, 2016 | HP LaserJet 1020 Printer
HP Officejet 4315 All-in-one I am a Mac user and I cannot do duplex printing or two sided printing
Mac uses a generic driver for all printers. have you verified that duplex printing is check under the printer options?
System Prefs -> Print & Fax -> select the printer, Options and supplies -> driver.
NOTE: if it says print using "Generic postscript driver" you will need to install the manufacturer driver for the printer to get the option to turn on the duplex printing.
May 23, 2011 | HP OfficeJet 4315 All-In-One InkJet...
Zebra TLP 2844 does not print anything.Not even paintbrush (print) is not doing anything.I have tried everything an programmer could think of. All that it does it spews out some empty labels. IT IS NOT A...
Are you trying to program in ZPL? if you are then you don't need a driver, send the code directly to the port and it will print. I would firstly reset the defaults to make sure there are no corruptions in the settings. Just in case you not sure, press and hold the feed button, the green light will flash 1 then 2 etc on the 4th flash let the button go and it will calibrate and reset to the factory defaults.
Mar 16, 2010 | Zebra TLP 2844-Z Thermal Label Printer
My Zebra LP-2844-Z won't print, says spooling, printing, deleting
try this--open the control panel then open system & maint then admin tools. open services then find the print spooler svc and right click then restart. close all jobs and print windows first then try again
May 15, 2009 | Zebra LP 2844-Z Thermal Label Printer
TO Print the image using IPL.
I've printed images over 500kb. Can you print a small image? If not, perhaps the driver is the problem.
If you're trying to send a text file of IPL commands to the printer, set up a Generic Text printer driver, to to send the file as ascii characters instead of as a graphic image. You can set this up in addition to your Intermec driver.
Go to Printers and Faxes, Add Printer, Next, Select the Port, Select "Generic" Manufacturer, "Generic / Text Only" Printer, and give it a name like "Text". Cycle the printer power to clear previous attempts, then print the file to this printer name.
Aug 22, 2008 | Intermec EasyCoder 3400 Thermal Label...
"Generic / Text Only" driver printer and cyrillic
Unfortunately printing Cyrillic(Russian) is driver dependent and your application can only use generic/text driver.
Aug 05, 2008 | Epson TM-U220 Matrix Printer
Problem setting up TM-U220
print the self-test, push the feed botton while powering on...
you can see there the serial interface...
baud rate, data bits, parity, stop bit etc...
then go to the printer and faxes,
right click the epson driver and click properties...
go to the ports window...
click on the epson tm u220 reciept.
click configure port...
adjust the baud rate as same as in the self test...
it works...
May 22, 2008 | Epson TM-U220 Matrix Printer
Generic / Text Only (To File) printer driver cutting off at 85 columns wide
I found a solution to my problem above. In the Generic / Text Only driver I chose a page setup of "ledger" (as opposed to letter, legal, etc.) and that produced the correct output with all of the columns.
Apr 18, 2008 | Office Equipment & Supplies
Epson LX-350 9-Pin Serial Impact Dot Matrix Narrow Carriage Printer, 347 cps 10 cpi, Bi-directional Parallel IEEE-1284, USB 2.0, Serial Logo
67 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
