Question about JVC Sirius KD-LH300 CD Player
Awm900 rv cd radio wont play cd ER08 displayed
Radio works fine but won't read the cd. Display screen shows ER08.
SOURCE: Error Codes
I've had a friend to stay who had this problem. I downloaded the user manual from the internet and the error code is not mentioned. I followed the procedure to reset the radio and this solved the problem.
Take the cover off the stereo and locate the small hole (towards the centre) which houses the reset switch. Insert something like a paper clip into the hole and hold for a few seconds. Then replace the cover and all should work. You'll loose all the radio presets.
Posted on Feb 17, 2009
SOURCE: I HAVE A JVC KD-G321 CAR RADIO/CD PLAYER
I had the same problem, the cd refused and radio plays good, with JVC KD G321. I have disconnected the switches behind the radio and also disconnected the antenne (do not forget the antenne) and it played the cd again.
Jan (my english is not so good, i hope my solution is better.
Posted on Sep 18, 2009
  • 436 Answers
SOURCE: My friend pulled a KD-G729 from his mother's car,
acc is missing. the truck requires a data module for the radio to work properly. I suggest you take to stereo install shop and have this added. it should then work great
Posted on Sep 27, 2009
dj_relly999
  • 4070 Answers
SOURCE: hi my cd player wont work it just makes a clicking
there might be a problem in the optical drive, you can try to see a technician to clean it or you may need to replace it for a new one
Posted on Feb 02, 2010
kenw392
  • 2226 Answers
SOURCE: since the cold weather my cd player wont work the
if you can remove the radio, you can try cleaning the laser lens, or possibly take it to a shop where it can be professionally cleaned. you can sometimes clean the laser with a qtip and rubbing alcohol if you can remove the top of the radio and can find the laser lens. the laser lens will be a bubble shape piece of glass inside the cd mechanism. be very gentle while cleaning the lens.
Posted on Jan 28, 2011
Digital display on onkyo tx-sv70pro not working radio plays ok.
Yes...the sun would have harm this but it would take a lot of sun. I am betting your display is just burned out. If you look hard enough you can find a replacement for the display. It is a plug and play board.
Apr 09, 2014 | Audio Players & Recorders
Radio display says "phone"
Try turning off your Bluetooth on your cell if that doesn't work unhook the battery for 15 mins
Dec 05, 2011 | Ford Expedition Cars & Trucks
My radio/CD player constantly says "ERR" and CD's won't play anymore. It doesn't show the time or the radio station either, just "ERR". I can hear it, like it's trying...
HI lisasmith566 IT is not a fuse problem .
the problem is your the CD part of the radio
must likely the cd is stock or more likely the cd drive motor is defective .
FIRST try pushing eject on radio and see CD comes out if not you need a new radio .
good luck vote
Jul 27, 2011 | 2003 Chevrolet Tracker
Cd player reads err on display
internal problem in radio,you would have to take it to a dealer to send out for you,
Jan 01, 2010 | 2000 Chrysler 300M
Factory radio won't play CD's, just shows an error code on radio display. Radio does work fine though.
you will need to send it to repair or just get new aftermarket radio and save yourself a lot of headaches
Apr 24, 2009 | Car Audio & Video
The radio and cd player work but cannot display anything
hi..make sure that u have turned on the
display button the set.once u have turned
off the display button in your set ur display
doesn't appear.This display option will be
available in the set.
check it out.
thank u.. rate me..
Feb 05, 2009 | 2005 Jeep Grand Cherokee
Eclipse CD2000 has no sound from a cd or sirius... radio works
If you have an amplifier hooked up make sure that the correct blue wire on the harness is connected. One of the wires is the remote amp turn-on, the other is for a power antenna. That would be why your radio plays through your speakers, the power antenna wire' when the source is set to radio, sends a 12 volt signal. That would turn on your amp if thats the way that its hooked up.
Nov 16, 2008 | Eclipse CD2000 CD Player
JVC Sirius KD-LH300 CD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
