Question about HHP IT3800 Handheld
TURN OFF SOUND ON HAND HELD SCANNER
I WANT TO MUTE THE SOUND THE HAND HELD SCANNER MAKES WHEN I SCAN A BOOK
Dear Staff: I have a Pro. 97 hand held scanner. I
Hi, my name is John. Press the FUNC and hold down the L/O button until it beeps twice......hope this was helpful..Rate this solution on the four thumbs-up......John
Sep 08, 2010 | Radio Shack Pro-97 Handheld Scanner
Hand held scaner
To enter a known frequency into the scanner's memory:
1. Power the scanner ON.
2. Press MAN to stop scanning.
3. Enter the number of the channel to be programmed (1 through 30) - OR - press the MAN key repeatedly to advance to the desired channel.
4. Enter the frequency including decimal point (ex: 146.25).
5. Press E to enter the info into memory.
6. Repeat steps 2 through 5 to program other channels.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Jul 05, 2010 | Uniden BC60XLT-1 Handheld Scanner
Duel trunking lites up stillno reception hand held scanner 1000 c
If the scanner is completely locked up, you need to reinitialize it, but be aware that this procedure will erase/delete all information that you've programmed into it. To initialize the scanner:
1. Turn off the scanner, then turn it on again. Multi-system
Trunking Scanner appears.
2. Press 0 while Multi-system Trunking Scanner appears.
3. Press 1.
4. Press ENT. Initializing please stand by. appears for about 5
seconds.
Do not turn off the scanner until the initalization is
complete. When the initialization is complete, M000
appears on the top line of the display. Bank 0 Ch 00
appears on the third line.
Need the complete manual for your scanner? You can download/print it here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-97_OwnersManual_ome20-527.pdf
For a comprehensive database of active frequencies and systems in your area, along with a lot of useful scanning data, visit:
Bill B
Apr 05, 2010 | Radio Shack Pro-97 Handheld Scanner
My Symbol scanner sits in a cradle, and the laser goes off and on, rather than remaining on full time. This is a problem, because when I pass a barcode under the unit, I have to wait until it flashes, and...
Yes Symbol LS2208 would be the best... it has an intellistand that enables presentation scanning and easy switching between hands free and hand held models..
Nov 16, 2009 | Symbol LS3478 Barcode Scanner
How do i adjust the squlech on my unidenbc12xlt hand held scanner
The actual setting will vary according to the strength of the signals you're receiving, so it may require adjustment as you move around. With the unit scanning, turn the squelch down slowly until scanning stops and you hear a hissing noise. They slowly bring the level up until scanning resumes.
Oct 29, 2009 | Uniden BC72XLT Handheld Scanner
Hand held pro 83 scanner
http://support.radioshack.com/manuals/ome20-501.pdf
May 30, 2009 | Radio Shack Pro-82 Scanner
CB92XLT hand held scanner keeps hissing and won't scan
Got the same issue man, you fix it? im checking mine over now, will let you know if i fix it. if you still need it.
Feb 14, 2009 | Uniden BC92XLT Handheld Scanner
I would like to remove some numbers from my in-phone phone book. I have a Panasonic hand held home phone model number KX-TGA549CS
I have the same phone:
1. go to the number in the phone book that you want to delete
2. simply push the clear button on the phone (also the mute button)
3. then select yes
ta-da! ^.^-
Jul 19, 2008 | Lands Phones
Hand held scanner
After a few minutes the scanner kicked into life and is now fully functional,have no idea why the problem occurred.Thankyou for your interest,regards Brian.
Mar 27, 2008 | Zebex Computers & Internet
HHP IT3800 Handheld Logo
57 people viewed this question
Top HHP Computers & Internet Experts
David Payne
David Payne
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
