Got 3 lights flashing on front of washer and it won't start model A128qs
Wont start has 3 lights on the front
  • 298 Answers
SOURCE: I have a maytag NEPTURE
you can try to reset it by unpluging for about 15-20 mins to let it reset itself. hope that works.
Posted on Dec 21, 2010
  • 548 Answers
SOURCE: Indesit model widl106 won't start. Lights flash.
capacitor on motor or windings on motor burnt out
Posted on Mar 22, 2012
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
    Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
    Posted on Sep 25, 2012
    BADBOYJAY
    • 264 Answers
    SOURCE: hotpoint ultima model 962g the drum won't turn and f10 flashes on panel
    that's your motor brushs need to replace them
    Posted on Oct 19, 2012
    richroth
    • 9472 Answers
    SOURCE: Kenmore front loader washing machine won't start
    You will need to replace the door lock. Here is the part to order.
    To replace the lock, remove the band securing the boot to the front panel and fold back the door boot. Now you can access and replace the lock. Let me know if you should need further help.
    Posted on Nov 05, 2012
    The start button keeps blinking, WONT LET ME DO ANYTHING
    Cycle light flashes, but machine wont start - Kenmore Elite ...
    https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
    iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
    GE Washer Start button flashing - DoItYourself.com Community Forums
    www.doityourself.com/.../386041-ge-washer-start-button-flashing.html
    Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
    Oct 29, 2015 | Washing Machines
    Light flashing won start
    Common error with front loaders is the door interlock. Make sure the door is positively closed. A gentle open hand push at the erea of the door lock often gets a machine started.
    Regards
    John
    Jan 30, 2014 | Kenmore Elite 45986 Front Load Washer
    Hoover nextra washing machine door wont lock / cycle start
    sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
    Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
    Replaced the whole top panel. now start lights only flash wont start washer
    You might have blown a fuse on the circuit board or fried a transistor on the board
    Oct 07, 2012 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
    see this causes and fix it. God bless you
    Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
    Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
    User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
    Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
    Line Fuse If the washer won't start the line fuse might have blown.
    Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
    Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
    Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
    Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
    Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
    Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    29 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
