Question about Joovy "Scooter X2 Double Stroller, Black"
Wheels get stuck, hard to turn
Wheels seem to get stuck and wont turn around corners easily
Are there cv joints on the front
constant velocity joints are for front wheel drive cars to transfer the power from the transmission/engine to the front drive wheels that turn around corners , your car is rear wheel drive , rear wheels do not turn around corners so it does not need any type of joints , its a straight drive axle , incidentally your car has the 3.o jaguar engine id bet since they were a deal ford did when obtaining jaguar (let them use them in there lux cars)
Jul 22, 2015 | 2001 Lincoln LS
Have a cub cadet and steering wheel keeps turning but not turning the wheels at all now
howdie sounds like the Gear Box is broken it might need replacing or ther is a shear Pin that is Broke in ther To stop it from moving so might need to be replaced as well
Apr 25, 2015 | Cub Cadet Garden
Wheels won't turn, runs and blades work
if by turn you mean they wont rotate, then check if parking break is on, if you mean you cant turn the steering wheel, or cant make make it go around corners, then check the linkage
Apr 20, 2013 | Cub Cadet Riding Lawn Garden Zero Turn...
1989 chevy 1500 wheels wont spin in any gear
check transmission fluid first if low level off --may need a fluid and filter change--internal gear problem
Jun 01, 2017 | Chevrolet 1500 Cars & Trucks
How to remove rear wheels on a 2004 mitsubishi endeavour the wheels seem stuck
if all lugs are off and wheels of ground (jack up)
clean hub surface and apply pen oil to hub
get heavy sledged hammer and hit rubber tire at outer area
while turning wheel it should come free corrosion build up is common
and somtimes hard to free up
be persistent
Apr 02, 2011 | 2004 Mitsubishi Endeavor
Steering column wont turn ignition is stuck
Rock Steering Wheel Back and Fourth While Turning KEY.
Or If the Wheels are Turned HARD in one direction you mest Turn Steer Wheel in THAT Direction While Turning KEY
Dec 23, 2009 | 1998 Dodge Caravan
Oreck upright hard to push
If hard to push, only a few things to check:
(1) Rear wheels will get hair or thread wrapped around axles, dust, etc. and be hard to turn. Make sure each wheel turns easily.
(2) Small wheels on newer models (since about 1997-98) toward front are worn, missing or have same problem as item 1.
(3) Brush roll not turning. The brush roll actually helps pull this unit along the floor, as it rotates in the "forward" direction. If the belt broke, and you do not realize it, it may suddenly seem harder to push.
Oct 11, 2009 | Oreck XL2000 Bagged Upright Vacuum
Squeaking on 1999 toyota corolla
Throughout my experience with Toyota's I have found that several times the hubcaps have made some weird noises. Try removing your hubcaps and driving your vehicle. If the noise still persists please let me know and I can ask u some questions and try to help you with your problem.
Aug 11, 2009 | GMC Jimmy Cars & Trucks
Robo kleen stopped working, motor starts but it does not move
Hello, I think I had the same problem with mine : the filterpump worked, but robot didn't move. I opened it up and the problem seemed to be that the pin which locks up the gear wheel to the axle of the front wheels had broken into three pieces. We inserted a new pin (nail, screw etc) and the Robo kleen works just fine again. Maybe you should check this is also the problemwith yours. Good luck !
Apr 09, 2009 | Smartpool Dolphin Robo - Kleen Above...
Stuck in 4wheel drive??? help :)
when driving in 4wd engagement there is a problem in that the torque in the axles and drive lines is not dissipated on hard surfaces as the wheels cannot slip ( great for snow ice mud gravel and the like but a no-no on hard non slip surfaces
yes reversing it will relieve it but if on hard surface ,winds it up again in reverse
better to simply drive two wheels onto the grass verge of the hard surface and then kick it into 2wd
if the diffs are limited slip diffs then the antislip action in the diffs will be pressed very hard together and will produce problems on turning corners
you may have success if you get all 4 wheels of the ground on a hoist and let the wheels spin and then try to engage 2wd
Mar 25, 2017 | 2006 Hummer H3
Joovy "Scooter X2 Double Stroller, Black" Logo
43 people viewed this question
Top Joovy Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Joovy Baby Gear Expert? Answer questions, earn points and help others
