Camcorders
Problem for Camcorders
Generic problem for all Camcorders
Aiptek AHD 100 720P camcorder not wor...
By dhbr33716 on Jun 15, 2009
I have a Aiptek AHD 100 720P camcorder. It works fine until I link it with my computer. With the memory card in, the autoplay window comes up and nothing else (just keeps searching) but won't let me do anything else. If I take the card out and connect to the pc, the DCIM folder comes up, then the 100 media file and finally, a video file. However, double click on that and computer freezes as well. Any ideas?
Comments:
Jun 16, 2009
- Thank you for replying. My pc has windows XP SP2. My camcorder is not supposed to need a driver according to the website. When I coonect, it indicates that the software is loaded and ready to go but the problem still occurs.
Jun 23, 2009
- I tried it on another pc and it worked. The found new hardware wizard started but I cancelled it and then the computer automatically recognised the camcorder and allowed me to access the files stored on it. This is where mine gets stuck I think. On the camcorder I have about 5 files and when testing on an alternative pc it found them all and allowed me to play them. On mine it either does not open the file and freezes or if I ever do get the main file open it only shows one video file. The computer freezes until i unplug the USB connection.
Jun 24, 2009
- I have several times but get the same problem. When I try and delete it, it freezes, I unplug camera, it unfreeezes (but camera deleted), reboot and then same all over again.
Jun 24, 2009
- Thank you Yes, I will give it a go and let you know the outcome
Clarification Request
Posted by gewiz on Jun 15, 2009
the camcorder is using a generic camera driver, but that what's causing the problem.
http://www.aiptek.com/drivers/ahd/
does your PC meet the requirements ?
Windows XP SP2 or VISTA
Solution #1
posted on Jun 15, 2009
Somewhat Helpful)
satyanisha21
Rank: Wiz
Rating: 80%, 110 votes
try to run by installing the driver software of your camcorder. The searching do not find out because the computer do not know about the hardware. after installing the driver software, than only you can suceed..............and you can get the driver from any of the download website...... have a nice day :-)
Was this helpful?
Yes
No
Solution #2
posted on Jun 16, 2009
Not Rated)
gewiz
Rank: Wiz
Rating: 84%, 94 votes
That paricular camera does require a driver, I know because I write hardware drivers for various suppliers and that one is using a generic driver which can be buggy. It is poosible to try it on another PC ? I would be very interested to see whether it works, Regards GeWiz
Comments:
Jun 23, 2009
- Have you gone into the Device Manager and deleted the camera found ? then rebooted then connect the camera.
Jun 24, 2009
- ok that sounds like the generic driver that it loading is causing the problem , goto another PC, install the camera and make a note of the driver loaded and version info,
Now go back to you machine and check the driver loaded, if it's the same I would say the driver is corrupted or driver entries within the registery are corrupted, delete the driverfile within the system32 folder or wherever it located and delete out of device manager and reboot,
now here the trickly bit, if it a different to the other machine tell it to look in the location of the other driver , , if the driver has been deleted most likely it will ask you to insert the OS disk, this will solve the problem with the corrupted driver file,
I hope that makes sense.
REgards
GeWiz.
Was this helpful?
Yes
No
Popular Solutions for Camcorders
Questions and Unsolved Problems for Camcorders
Answer
I was going to purchase a Jazz Dv142 5MO Digital Camcorder, does anyone know if they are a good... (More)
Answer
is JVC model# gz-ms130bus a good choice and will it take good still pictures, what is the resolution... (More)
Answer
persistant "dew" error message. unable to load or play tapes. is there a way of overcoming...
Answer
The tape does not close on my HDR-HC5. I put the tape in and push it shut, but it will not close.... (More)
Describe your Camcorders problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Camcorder Experts
Top Camera & Camcorder Repairmen
in Newport, KY
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
