Canon ir3025 printing problem only printing landscape
Why will this only print landscape and not portrait
Great answer thank you - you just need to move the blue dial!!! :-)
Posted on Feb 05, 2015
  • 883 Answers
SOURCE: Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
Posted on May 31, 2007
SOURCE: Canon iR 3570
Open your top paper tray drawer and there should be a dial on the on the tray drawer (light blue). On there is different paper sizes. Turn it until you get "Ltr" and the paper is going up & down. This should fix the problem. We just had that same problem today and that's what the tech person told us. (Also, this dial only turns in one direction to the left). MMc
Posted on Nov 29, 2007
  • 7 Answers
SOURCE: print orientation
If you are printing from the included software, it has options for labels with vertical printing. If printing from a third party program, you can go to the dirver settings and change the printing orientation.
Posted on Dec 31, 2008
SOURCE: Canon MP610 Printer When automatic duplex
I haven't found a way to do this using the printer settings.
There is no (apparent) simple solution, but needing tp print a 56 page pdf form the only solution was to load the pdf into Adobe Acrobat and then in the 'document' pull down menu select 'rotate pages', then select '180 degrees' and also 'rotate even pages only'. This then prints OK.
The down side is that you need full Adobe Acrobat rather than just the reader.
I have been unable to rotate pages through 180 degrees in MS Word but it is possible using MS Publisher.
Misterfish
Posted on Feb 11, 2009
SOURCE: HP C7180 printer prints 1 p. LANDSCAPE, next p. PORTRAIT, etc.
I had the same problem. I uninstalled the printer on the offending computer, rebooted, reinstalled and it ironed itself out.
Posted on Mar 20, 2009
Print result sideways
It sounds like your printer is set to print landscape, instead of portrait mode. Next time you want to print, click on file(top left of screen), then print (don't just click on the little printer icon). This will open a new printer window where you can choose different setting. The option to change from landscape to portrait will be listed somewhere in that window. Once you have selected that feature and print it will stay that way unless you change it. You will have to check this setting in each computer program you use.
Jan 23, 2014 | Canon PIXMA MP160 All-In-One InkJet...
How so I do Landscape orientation on Canon Pixma MP500?
When you want to print a document Click on File (at top left hand corner of screen) - click on Print then click on Properties box - Layout tab then select Landscape.
The printer normally defaults to Portrait but sometimes you want to print Landscape. Use this method when you need to print in landscape mode.
Sep 07, 2012 | Canon Pixma MP500 All-In-One InkJet...
How to print landscape wirh canon mp520 i select landscape in printer set up but prints portrait
You have to set landscape in the printer settings on the computer not just the printer. It varies depending on which program you are using. For example microsoft word you would hit format->page settings landscape.
Jul 26, 2011 | Canon PIXMA MP520 InkJet Printer
Canon ir3045n - when printing the paper orientation has switched to landscape. How do we change it back to portrait?
Hello Donna,
To change the orientation of the printer from landscape to portrait follow these simple steps;
- open any document and go to print from the file menu
- when the printers settings window opens click 'properties'
- In the next up coming windows you can see menus like 'main, page setup, effects' profiles
maintenance etc.
- click 'page setup'
- There you can see 'page size' and 'orientation'
- change the 'orientation' from landscape to portrait
- click ok and print
Done : )
please rate if this solution was helpful for you, thanks you!
Jun 23, 2011 | Office Equipment & Supplies
Printing both landscape & portrait in one document
Yes, set the doc feeder for Auto Paper Selection APS
May 07, 2010 | Canon iR 2016i Black and White Copier
At college we have a w7200, how can we print across the paper rather than down it, for example a panoramic image across the width of the paper and say 20cm high
Try selecting LANDSCAPE as opposed to PORTRAIT by using the proper print menu in your application rather than the simple print icon from most tool-bars.
You can usually find it in the FILE menus
Apr 20, 2010 | Canon imagePROGRAF W7200 InkJet Printer
Can the canon pixma 860 print a sheet of paper in duplex mode
Hello !
Your printer prints 2-sided and you can change the orientation of output from portrait to landscape.
Hope this helps.
Oct 04, 2009 | Canon Office Equipment & Supplies
My suddenly prints every other page in landscape. What is the problem? Tom
It prints in portrait then landscape, portrait then landscape and so on. I use a laptop and desktop with this printer and both are doing it. 2 sided print has not been selected.
Aug 11, 2009 | HP Photosmart C5180 All-In-One InkJet...
164 people viewed this question
jasbo
jasbo
