Question about Saeco Talea Giro Espresso Machine
Saeco talea ring plus error code 4 and 82 ??
Error messages are appearing
SOURCE: Saeco talea ring coffee machine reurning error code
Thanks Johnny,
the machine wont make coffee at all as it stands. Justn returns code 1 as soon as you push the button for coffee. Is the sensor optical or a microswitch? Can you tell me where the sensor is located so that we can have a go at cleaning it?
Posted on Nov 18, 2008
EsWorld
  • 1618 Answers
SOURCE: Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Posted on Jun 24, 2009
SOURCE: Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Posted on Jul 27, 2009
  • 20 Answers
SOURCE: Saeco Talea Ring Plus
Grinder motor is not working.When the machine do the self test on startup, it senses the grinder motor is in open circuit(error 1).
Have to replace the grinder motor.
Remove the coff beans hopper.then..front spout by pulling the knob off and undo the screws...lift the top cover up from the back to unclick then pull the front part towards you from the center then slide over the spout area. You will see the grinder is covered with rubber cover with 4 screws holding it...remove the screws and then push down the rubber protrution through hole to detach from the grinder.The grinder is yours.
Posted on Dec 23, 2009
  • 81 Answers
SOURCE: out of service [4] out of service [87]
Hi...itis not self testing..in otherword the motor in the gearbox is not working, either itis jammed with rust cuz' of leakage or motor is bad.
Posted on Jan 17, 2010
My Saeco Talea Touch machine stopped working this morning after a first cup of coffee. The error code on the screen said Restart to solve the problem (with a wrench key). I restarted the machine but the...
Had the wrench icon problem on a used Talea Touch that I bought.
Don't know how it started with the previous owner.
Solution - cleaned compressed coffee grounds from the grinder discharge. You need to manually spin the motor to clean all grounds from the rotation discharge gate.Also needed to probe and press the electrical connections to the motor. The brush spring and capacitors are press connected.
This solved the problem.
I've owned abnd repaired many Saeco machines. They are poorly designed and over priced.
None the less the majority of their problems can be fixed by simply cleaning the components.
Enjoy
MDR
Sep 08, 2011 | Saeco Talea Touch 14-Cup Coffee Maker
On my talea ring plus i get an error code 5. anybody knows what that is?
Error 5 is the water circuit is block, or airlock in the system that means you have to purge the air out.
Feb 11, 2010 | Saeco Talea Ring Plus Espresso Maker with...
Saeco Talea Ring Plus: often, water flows out of of water steam
The valve parts need to be replaced, if it is only happening when brewing coffee then there is so much pressure on the pump that it is forcing the valve open. First try adjusting the amount of coffee be added to the chamber for brewing.
Aug 23, 2009 | Coffee Makers & Espresso Machines
Seaco talea ring plus Q: what i have to do when
Press hot water button and open valve to run the pump.
Aug 22, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
HOW DO I GET THE INSTRUCTION MANUEL FOR A SAECO TALEA RING PLUS COFFE MACHINE?????
The French Saeco website has manuals (in English as well as French).
Try this url…
http://www.saeco.fr/en/manuali/manuali.html
HTH
Mar 16, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Saeco Talea Ring Plus not frothing milk
per il milk island asciugare bene la valvolina e tutti i fori del blocco di plastica che fa da montalatte devono essere perfettamente asciutti dare dei colpetti alla valvola per fare uscire eventuale acqua all interno.
MORENO
Feb 20, 2009 | Saeco Talea Ring Plus Espresso Maker with...
ok with a machine you have already for a while :
Putt descaling solution in the machine. unplu the machine and open the watere valve. Aftre about 2 days it should have desolved.
BUT>>>>>>>>>> what also can be is that the valve on the bottom of the water tank is not working.
Fill it a little and wiggle the valve until water comes out and than try again.
Priming normally goes.
Water in tank. push water button and open valve.
May 22, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Talea Giro Espresso Machine Logo
188 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
