Question about Memorex MD6451R Personal CD Player
Can't turn off hold button on cd player
Two cd in same slot won't eject
Try disconnecting the CD player from power,press and hold the open button and the connect and turn player on.Release button after it indicates open on the on player.Tap the top part of the player with your palm while pressing open button.
Hope this helps.Thanks!
Oct 16, 2011 | Audio Players & Recorders
I have a Craig portable CD player, and can't find my user manual. When I try to turn it on, the window says "Hold" and shuts it off.
Hi!
On the edge of your cd player is a button called HOLD. It's purpose is similar to keylock on a mobile phone, for not accidentally press a key during walking or jogging.
Please slide the hold button on the other position, that should solve the issue.
Hope it helped,
Bogdan
Sep 13, 2011 | Craig Personal CD Player
How do you set the clock on a Pioneer DEH-1600?
To set the clock, please follow the following steps
#1
Press and hold the "SRC/OFF" button on your Pioneer car CD player until the unit powers down. Note that the "SRC/OFF" button is located on the top left of the Pioneer car CD player.
#2
Press and hold the multi-control knob, located on the left side of the CD player. Hold the multi-control knob until the words "Clock Set" appear on the CD player's display.
#3
Turn the multi-control knob until the words "Clock Set" are highlighted. Press the multi-control knob on your Pioneer car CD player to enter the clock setting mode.
#4
Turn the multi-control knob to highlight the "Hours" option. Press and hold the multi-control knob until the hours-place digits begin to flash. Rotate the multi-control knob until the desired value is displayed. Press the multi-control knob on your Pioneer car CD player to save your changes.
#5
Turn the multi-control knob to highlight the "Minutes" option. Hold the multi-control knob until the minutes-place digits begin to flash. Rotate the multi-control knob until the desired minutes value is displayed. Press the multi-control knob to save your changes and end the clock-setting process.
Hope this might help
Thanks
Oct 07, 2010 | Pioneer DEH-1600 CD Player
-Hold button keeps displaying
The unit has a hold button that keeps you from accidentally activating the device when it's in a purse or backpack, which preserves battery power and also prevents changing tracks if buttons are accidentally pushed while in play mode. Look on the player for the hold button and turn it to the off position. I hope this helps and good luck!
Feb 17, 2010 | Philips eXp2461 Personal CD Player
Battery died and i put in the security code but now the cd player wont work
first, you have to obtain the serial number for the CD played. To obtain this, turn the CD player off, hold down the #1 and #6 buttons at the same time. While holding these buttons, turn the power on. The serial number will flash with 2 sequences of 4 numbers each (the serial number is a total of 8 digits). Call a Honda dealership with this serial number and they can provide you with the security code to access the CD player. Hope this helps.
Oct 27, 2009 | Honda Civic Cars & Trucks
Why does it say hold on my cd player when its closed ?
There is a "hold" button on the device that works like a key lock on your cell phone.
Find the hold button and switch it to the other position and you will be able to use your device normally.
Once you have put your CD player in a mode that you want, then you switch the hold button on so that you won't accidentally hit any buttons. You can then safely put the CD player in a pocket and not have to worry about it.
I hope this helps.
Aug 24, 2009 | Sony Walkman D-NF400 Personal CD Player
I just bought a suburban that has a after market dvd and tv setup in it. It still has the orignal cd play with a dvd player under it the avd 400 ta. I can not get any sound out of it. went thru all the...
hi there
open up your dash get 1 short RCA cable (red and white) male ends on them
now place the red and white RCA into the back of DVD in-dash player next step the aftermarket CD player should have 2 rca plugs that say aux put the other end red and white RCA cable that you just put into DVD unit into the aux inputs on back of CD player when this is done reinstall both units back into the dash now on your CD player press the source button till aux appears once this is done you will hear the DVD player sound...........now if you press the source button and no aux appears......hold down the source button till the CD player powers off...........once CD player is off hold down the F (function) button till beep or unit turns on a display use the skip buttons or F (function) button to go threw features once you get to aux turn aux to on now hold the source button down again till unit powers on normally once this is done press source button again till you find aux........if you get sound and the TV doesn't work let me know and ill guide you to get that running too (if there are no aux RCA plugs on the back of CD player) let me know (sometimes there is a headphone looking plug on back of CD units) if what i told you doesn't work let me know the brand of CD player you have so i can give you correct setups I'm only going by your in-dash DVD player right now
hope i was able to help get you sound
Mar 04, 2009 | Audiovox AVD400TA Mobile DVD Player -...
Other options
Shut it off and hold the function button
Dec 17, 2008 | Pioneer DEH-P6800MP CD Player
Go gear wont hold charge
There is a program that came with the installation Cd called Philips Device Manager. You can download it from www.usasupport.philips.com if you lost the CD. Use the Philips Device Manager to repair the player. If the device manager will not repair the player, then try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
May 17, 2008 | Philips GoGear HDD6330 MP3 Player
Stuck in hold mode
There is a slider button on the bottom of the cd player to take it out of HOLD.
Hope this helps!
Mar 04, 2008 | Sony Walkman D-EJ360 Personal CD Player
Memorex MD6451R Personal CD Player Logo
77 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
