Question about Canon MX882 All-In-One InkJet Printer
Canon pixma mx882 won't print red
Replaced all cartridges with Canon print cartridges. all red type comes out yellow. Blue comes out off colored
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Canon Expert
  • 307 Answers
Regarding your Canon MX882 printer's poor print quality (lack of color printing performance from Canon 225 or 226 ink cartridges), it sounds like your PRINTHEAD is either clogged (from dried ink) or has reached it's END-OF-LIFE, to help determine which please perform the following steps (if you have already performed a step, please continue to the next step in the order shown):
Canon Cartridge Troubleshooting: http://inkjet411.com/?page_id=1537
1.Go into the printer's maintenance/tools menu and print a print quality test (i.e. heading cleaning, nozzle test or similar) to help identify which color (of number of colors) is impacted.
NOTE: To help determine which color has run out, use the following suggestions in sequence until you are able to identify the empty color: 1) Generate a Print Quality Test Page from your printer control panel; a faded color band indicates empty. 2) To distinguish between a black and photo black cartridge, print a text document and/or a photo. Faded black in a text document indicates the black cartridge is empty; faded black in a photo indicates the photo black cartridge is empty. 3) To distinguish between cyan, yellow, and magenta click here: http://inkjet411.com/?page_id=146 A faded or missing color band indicates empty.
2.At the printer's control panel under the 'Maintenance' or 'Tools' menu, activate a 'CLEANING' or 'HEAD CLEANING' to prime the ink system. Then Run the Inkjet411 'Ink Recovery Test Print' from our Test Prints page to verify all colors are firing properly (all printers also provide some form of a Self Test page): http://inkjet411.com/?page_id=146
    3.Check your user's manual to see if there are any procedures on cleaning the service station/capping station assembly (this is where the carriage/cartridges 'park' when not in use). A dirty service station can cause all kinds of improper color output problems (assuming the printhead is working correctly of course). NOTE: May not be applicable for your model depending on the printer design.
    4.The Ink Absorber, if applicable depending on print model, may also be full which could also cause printing related issues (typically an error code will be displayed when the ink absorber is full)...here is a customer/yahoo response on this particular issue: http://answers.yahoo.com/question/index?qid=20130523085451AAE1TqW
    5.Refer to our print quality support page to ensure other variables are not causing the issue such as printer driver settings or operating system device conflict, etc: http://inkjet411.com/?page_id=1432
      6.If this does not remedy the problem, then one or more of the ink ports may be dry within the PRINTHEAD assembly (the ink cartridges physically connect to this electronic assembly). We suggest you either remove the printhead and perform a hot water flush for 2 minutes (in a sink) or using an eye-dropper, or similar, drip 5-10 milliliters (i.e. 1-2 teaspoons) of distilled water into the respective color ink port to help saturate the foam. http://inkjet411.com/?page_id=2804
      7.Reinstall ink cartridges and retest.
      Inkjet411 Suggested PRINTHEAD Cleaning Procedures:
      Canon Printhead Warm-Water Flush Procedure: http://inkjet411.com/?page_id=2804
      Epson Printhead Cleaning (Flush) Procedure: http://inkjet411.com/?page_id=2836
      3rd party PRINTHEAD CLEANING solutions (for additional reference only):
      http://www.youtube.com/watch?v=FL8QaFVwsEs(Canon)
      http://www.youtube.com/watch?v=ZheZf-vdho8 (Canon Printhead removal / water flush)
        http://www.youtube.com/watch?v=3kKULRjqaLg (Epson #1)
        http://www.youtube.com/watch?v=i78Tu3RVO3s (Epson #2)
        8.If the problem persists, then you may have a damaged PRINTHEAD (worst case scenario), unrelated to the refilled cartridges. The printhead is a separate electronic assembly (which the cartridges are installed into) and is responsible for firing the ink drops onto the paper. Over time and based on usage this assembly will eventually fail (typically lasts ~4,000 to 5000 printed pages on avg). Refer to video on how the PRINTHEAD functions: http://inkjet411.com/?page_id=2054
        PRINHEAD TECHNICAL NOTES:
        IIT (individual ink tank-based) printer models have an electronic PRINTHEAD within the base of the carriage assembly (responsible for pulling ink from the 4, 5 or 6 ink cartridges and then firing the ink droplets onto the paper) - these will eventually fail depending on print usage type and printer duty cycle (i.e. rated for approximately 10,000 printed pages over life, but the consumer average is typically closer ~4,000-5,000 thruput pages). The printhead is replaceable and can be ordered directly from the manufacturer or www.Amazon.com . For information on how the PRINTHEAD functions, please watch the following video: http://inkjet411.com/?page_id=2054
        Typically the printhead should not reach it's end-of-life until after a minimum of 8 or more complete sets of cartridge changes. While some printheads may last 10,000+ pages others may only last 2000 pages, actual results will vary. The printhead will eventually fail in time due to an internal micro-electronics failure, due to the following leading factors: general customer print usage and printer care, printer duty cycle (i.e. # pages printed per month), printing frequency (i.e. time between each print job), print mode (i.e. draft vs. normal) and content printed (i.e. photos vs plain pages) and color mode (black and white only vs. color/greyscale printing).
        Paper types used (i.e. plain paper, photo papers & matte/heavy bond papers) and paper edge curl (i.e. duration in printer and/or exposure to low relative humidity) can also quickly lead to premature printhead failures due to physical 'head strikes' of the paper edges making repeated contact with the printhead nozzle plate surfaces.
        CAUTION: the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors and permanent PRINTHEAD damage. We do NOT suggest refilling these types of ink cartridges.....refilling of original/genuine ink cartridges is only suggested!
        Canon 225/226 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=t1QDEDRZapY
        Please advise if the above suggestions do not help remedy the current issue. For any additional questions please contact us directly: Inkjet411help@gmail.com
        -Thank you
Posted on Apr 15, 2014
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
SOURCE: Printing error (Canon ip1800)
replaced ink cartridges..error message appears now telling me to re align printer..can you tell me how to do this
Posted on Oct 07, 2008
  • 4 Answers
SOURCE: canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Posted on Mar 06, 2009
  • 615 Answers
SOURCE: Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Posted on Mar 28, 2010
  • 232 Answers
SOURCE: I have a canon pixma IP6600D printer and just
Go to "start menu", then "settings", then "printers and faxes". Right click o your printer, then click on "properties". A window with numerous tabs will open. Go to "maintenance". Click on "deep cleaning" or "cleaning". That will clean the print head that is in your printer, and the colors should come out right.
If the printer hasn't been working for a while, you will need to repeat the cleaning process several times in order to get a satisfying result.
Do bare in mind that this process uses a lot of your ink.
Posted on Apr 01, 2010
How to make red color work in canon pixma mp287
make sure that there is red in the cartridge to use
Jan 07, 2017 | Canon Office Equipment & Supplies
Will not print in red
Aftermarket cartridges are easily the number one service issue in my shop. You have clogged the printhead. If you run `cleaning, color' (deep cleaning is NOT recommended), then the `nozzle check' to see results, you should see improvement with each color. If you don't, stop and take your unit in for service. It may need a new printhead.
Apr 02, 2014 | Canon MX882 All-In-One InkJet Printer
* After refile ink yellow color does not print at all.(ip 2772) * How to setup CIS system for canon Pixma ip 2772. which contains PG810/CL811 cartridges ?
I refilled Canon cartridge CL-811. I filled all 3 colors. Magenta Cyan Yelloware flowing well,. Even if I wipe the cart on paper tissue, 3 colors are coming out (pink magenta and Yellow).but while printing yellow colour isnot printing,. Any idea how I can fix the problem?
Jan 20, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Jul 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon MX882 All-In-One InkJet Printer Logo
215 people viewed this question
old marine
old marine
