Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
How to fix pioneer djm 600 mixer
Wont power up
  • 4 Answers
SOURCE: pioneer djm-600
the rcas need to be resoldered
Posted on Nov 03, 2007
marsrover
  • 682 Answers
SOURCE: djm 600
start with connections and try to clean fader with lubricant contact cleaner from radio shack or any electronics store.
Posted on Sep 23, 2008
SOURCE: my pioneer djm 600 mixer
replace the whole heaphone jack!! Replace it with a new metal 1/4 in. 3 piont jack that you find at any radio shack for a couple bux(these are also the same type of metal 1/4 in jack you'd find on an Allen&Heath brand mixer). The factory one on pioneers is a cheap plastic (Sony ,I believe) peices of **** ,and they always go out or brake. It's not hard to do it yurself though. As long as you can solder and have some apptitude for basic electronix ,you can do it yurself. You'll have to remove all the plastic knobs. then remove the 6 screws on the top plate; the four corners and the sides from the top panel. Don't forget the 2 on the outside of the crossfader ,and the 2 at the top for the mic xlr plug in. Then the top panel/plate should come off easily. This should expose the heaphone jack and enable you to remove it. There's a cheap plastic nut holding the jack on ,remove that and gently pull out the headphone jack till the wire slack catches. cut/snip the wires as close to the headphone jack as possible ,noting their placement! Remove sum jacketing from the ends of the wires ,and solder them back into place on the new metal heaphone jack make shure to test the jack out before putting everything back together!!. Follow the forehand instructions backwards and wahlah. You'll probly never have to replace the headphone jack for the rest of the life of the mixer. I've had the same 500 for 5 years now. The headphone jack went out on it in the first 6 months I had it. I replaced it my self and its werked fine and minorly trouble free for years past. I had to retighten the top nuts once or twice over the years ,but no biggy. Hope this helps! good luck
Posted on Oct 25, 2008
djproaudio
  • 515 Answers
SOURCE: Pioneer DJM-600 black Professional DJ power on but not working!!
So you get power to the unit, but no sound coming out? How about through the headphones, do you get sound coming out of the headphones?
Are all the volumes and gains raised up? All the eq's are up? Check the back of the mixer, there is a master gain volume - where the connections are - make sure this is up also.
If nothing, then you'll need professional help at this point.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Posted on Dec 18, 2008
SOURCE: how do i fix my pioneer djm 500 mixer when i
Just done the same thing. Remove the screws on the top of the
case and then all knobs, faders etc. One you have exposed the
inside of the mixer you will see a fuse where the power enters the
case. Replace the fuse with a 800ma 20mm fuse and this will fix it.
Posted on Dec 07, 2009
DJM 500 Mixer not turning on
Seems that the power supply is down.
If your not a technician, visit one or bring it to your local dealer.
regards,
Gerard
Mar 14, 2010 | Pioneer DJM-600 Silver Professional DJ...
Pioneer DJM 600 mixer keeps blowing ic 557 fuse on power supply board
I repair DJM 600 for many years. :) The reason for the burning of IC 557 (+8V H 600mA ) is invalid amplifier for headphones!!!
Replace IC 310 and IC 312 (in big mainboard), and replace
IC 557with original fuse 600mA
!!!!!CHECK YOUR HEADPHONES!!!!!! This is the cause burning amps.!!!!!
DJ Iskren
Oct 03, 2009 | Pioneer DJM-600 Silver Professional DJ...
How do i fix my pioneer djm 500 mixer when i changed the voltage while the power supply was in. without looking at the back of the mixer where it said "caution do not change voltage while power supply is...
Sep 16, 2009 | Pioneer DJM-600 Silver Professional DJ...
PIONEER DJM 600 . NO POWER.
I have the same problem, One day I open the djm-600 for replace the jack whole (easy), then of this when i close the mixer my pioneer died, but when I push the power button I can listen a little sound like ¿voltage running? Please Help !!!
Thanks
pd: sorry for my bad english
Nov 17, 2008 | Pioneer DJM-600 Silver Professional DJ...
Djm 600
Sep 10, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pionner efx 500
send out from mixer---------to pioneer in---------from pioneer out-----to return in mixer.
May 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
75 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
